1 | double Transmission(void)
2 | {
3 |
4 | double grad=0.0;
5 | vu8 d1=0;
6 | vu8 d2=0;
7 | double d1_double,d2_double;
8 | vu16 daten=0;
9 |
10 |
11 | /* Enable I2C1 ----------------------------------------------------*/
12 | I2C_Cmd(I2C1, ENABLE);
13 |
14 |
15 |
16 | /* I2C1 configuration: SMBus Host ------------------------------------------*/
17 | I2C_InitStructure.I2C_Mode = I2C_Mode_SMBusHost;
18 | I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
19 | I2C_InitStructure.I2C_OwnAddress1 = I2C1_SLAVE_ADDRESS7;
20 | I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
21 | I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
22 | I2C_InitStructure.I2C_ClockSpeed = ClockSpeed;
23 | I2C_Init(I2C1, &I2C_InitStructure);
24 |
25 |
26 | /* Enable I2C2 ARP */
27 | I2C_ARPCmd(I2C2, ENABLE);
28 |
29 | /* Enable I2C1 and I2C2 PEC Transmission */
30 | I2C_CalculatePEC(I2C1, ENABLE);
31 | I2C_CalculatePEC(I2C2, ENABLE);
32 |
33 | /*----- Transmission Phase -----*/
34 | /* Send I2C1 START condition */
35 | I2C_GenerateSTART(I2C1, ENABLE);
36 | /* Test on I2C1 EV5 and clear it */
37 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
38 | /* Send Slave address */
39 | I2C_Send7bitAddress(I2C1, SMBusDefaultHeader, I2C_Direction_Transmitter);
40 | /* Test on I2C1 EV6 and clear it */
41 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
42 |
43 | /* Get I2C2 SMBDEFAULT flag status */
44 | Status = I2C_GetFlagStatus(I2C2, I2C_FLAG_SMBDEFAULT); //wird evtl. nicht benötigt
45 | /* Send Command */
46 | I2C_SendData(I2C1, Command);
47 | /* Clear ADDR flag */
48 | I2C_ClearFlag(I2C2, I2C_FLAG_ADDR);
49 |
50 | /* Send I2C1 START condition */
51 | I2C_GenerateSTART(I2C1, ENABLE);
52 | /* Test on I2C1 EV5 and clear it */
53 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
54 | /* Send Slave address */
55 | I2C_Send7bitAddress(I2C1, SMBusDefaultHeader, I2C_Direction_Receiver);
56 | /* Test on I2C1 EV6 and clear it */
57 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
58 | /* Wait for I2C1 received data */
59 | while(!I2C_GetFlagStatus(I2C1, I2C_FLAG_RXNE));
60 | /* Store received data on I2C1 */
61 | ReceivedCommand = I2C_ReceiveData(I2C1); //LSB Byte
62 | d1= ReceivedCommand; //Zwischenspreicherung in vu8
63 | d1_double=(double)d1; //Konvertierung in double ; Konvertierung in int funktioniert nicht
64 |
65 | /* Wait for I2C1 received data */
66 | while(!I2C_GetFlagStatus(I2C1, I2C_FLAG_RXNE));
67 | /* Store received data on I2C1 */
68 | ReceivedCommand = I2C_ReceiveData(I2C1); //MSB Byte
69 | d2=ReceivedCommand;
70 | d2_double=(double)d2;
71 |
72 | //16Bit unsigned char
73 | daten =d1;
74 | daten|=(d2<<8);
75 |
76 | //Umrechnung in Grad Celsius
77 | grad=d2_double*256+d1_double;
78 | grad/=50.0;
79 | grad-=273.15;
80 |
81 | /* Enable Transfer PEC next for I2C1 */
82 | I2C_TransmitPEC(I2C1, ENABLE);
83 | /* Wait for I2C1 received data */
84 | while(!I2C_GetFlagStatus(I2C1, I2C_FLAG_RXNE));
85 | /* Store received PEC on I2C1 */
86 | PECValue = I2C_ReceiveData(I2C1);
87 | /* Test on I2C1 EV8 and clear it */
88 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED));
89 |
90 | /* Send I2C1 STOP Condition */
91 | I2C_GenerateSTOP(I2C1, ENABLE);
92 | /* Test on I2C1 EV4 and clear it */
93 | while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED ));
94 | /* Clear I2C1 STOPF flag */
95 | I2C_ClearFlag(I2C1, I2C_FLAG_STOPF);
96 |
97 | return grad;
98 | }
