1 | // perform system reset
2 |
3 | enc28j60WriteOp(ENC28J60_SOFT_RESET, 0, ENC28J60_SOFT_RESET);
4 | // check CLKRDY bit to see if reset is complete
5 | delay(50);
6 | while(!(enc28j60Read(ESTAT) & ESTAT_CLKRDY));
7 | // do bank 0 stuff
8 | // initialize receive buffer
9 | // 16-bit transfers, must write low byte first
10 | // set receive buffer start address
11 | NextPacketPtr = RXSTART_INIT;
12 | enc28j60Write(ERXSTL, RXSTART_INIT&0xFF);
13 | enc28j60Write(ERXSTH, RXSTART_INIT>>8);
14 | // set receive pointer address
15 | enc28j60Write(ERXRDPTL, RXSTART_INIT&0xFF);
16 | enc28j60Write(ERXRDPTH, RXSTART_INIT>>8);
17 | // set receive buffer end
18 | // ERXND defaults to 0x1FFF (end of ram)
19 | enc28j60Write(ERXNDL, RXSTOP_INIT&0xFF);
20 | enc28j60Write(ERXNDH, RXSTOP_INIT>>8);
21 | // set transmit buffer start
22 | // ETXST defaults to 0x0000 (beginnging of ram)
23 | //uart_puts("- enc28j60init - Schreibe erstes nibble - 03\n");
24 | enc28j60Write(ETXSTL, TXSTART_INIT&0xFF);
25 | //uart_puts("- enc28j60init - Schreibe zweites nibble - 03\n");
26 | enc28j60Write(ETXSTH, TXSTART_INIT>>8);
27 | // do bank 2 stuff
28 | // enable MAC receive
29 | enc28j60Write(MACON1, MACON1_MARXEN|MACON1_TXPAUS|MACON1_RXPAUS);
30 | // bring MAC out of reset
31 | enc28j60Write(MACON2, 0x00);
32 | // enable automatic padding and CRC operations
33 | enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, MACON3, MACON3_PADCFG0|MACON3_TXCRCEN|MACON3_FRMLNEN);
34 | // set inter-frame gap (non-back-to-back)
35 | enc28j60Write(MAIPGL, 0x12);
36 | enc28j60Write(MAIPGH, 0x0C);
37 | // set inter-frame gap (back-to-back)
38 | enc28j60Write(MABBIPG, 0x12);
39 | // Set the maximum packet size which the controller will accept
40 | enc28j60Write(MAMXFLL, MAX_FRAMELEN&0xFF);
41 | enc28j60Write(MAMXFLH, MAX_FRAMELEN>>8);
42 | // do bank 3 stuff
43 | // write MAC address
44 | // NOTE: MAC address in ENC28J60 is byte-backward
45 | enc28j60Write(MAADR5, ENC28J60_MAC0);
46 | enc28j60Write(MAADR4, ENC28J60_MAC1);
47 | enc28j60Write(MAADR3, ENC28J60_MAC2);
48 | enc28j60Write(MAADR2, ENC28J60_MAC3);
49 | enc28j60Write(MAADR1, ENC28J60_MAC4);
50 | enc28j60Write(MAADR0, ENC28J60_MAC5);
51 | // no loopback of transmitted frames
52 | enc28j60PhyWrite(PHCON2, PHCON2_HDLDIS);
53 | // switch to bank 0
54 | enc28j60SetBank(ECON1);
55 | // enable interrutps
56 | enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, EIE, EIE_INTIE|EIE_PKTIE);
57 | // enable packet reception
58 | enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, ECON1, ECON1_RXEN);
