Hallo
ich habe versucht für das PIC18 Explorer Board eine lcd.c Datei für
meine Bedürfnisse umzuschreiben und wollte erstmal einen Prototype
testen.
1 | #include "delays.h"
2 |
3 | #define LCD_CS (LATAbits.LATA2)
4 | #define LCD_CS_TRIS (TRISAbits.TRISA2)
5 | #define LCD_RESET (LATFbits.LATF6)
6 | #define LCD_RESET_TRIS (TRISFbits.TRISF6)
7 |
8 | #define SPI_SCK_TRIS (TRISCbits.TRISC3)
9 | #define SPI_SDO_TRIS (TRISCbits.TRISC5)
10 | #define SPI_CON1 (SSP1CON1)
11 | #define SPI_CON1bits (SSP1CON1bits)
12 | #define SPI_BUF (SSPBUF)
13 | #define SPI_STAT (SSP1STAT)
14 | #define SPI_STATbits (SSP1STATbits)
15 | #define SPI_IF (PIR1bits.SSPIF) //Übertragung / Empfang erfolgreich
16 | #define SPI_TRMT (TXSTAbits.TRMT) //Transmit Shift Register 0 = full 1 = empty
17 |
18 |
19 | void init_SPI(void){
20 | SPI_SCK_TRIS = 0;
21 | SPI_SDO_TRIS = 0;
22 |
23 | SPI_CON1 = 0x22;
24 | SPI_STATbits.CKE = 1;
25 | SPI_IF = 0;
26 | }
27 |
28 | void initPORTA(void){
29 | LCD_CS = 0;
30 | SPI_BUF = 0x40;
31 | while(!SPI_IF);
32 | SPI_IF = 0;
33 |
34 | SPI_BUF = 0x00;
35 | while(!SPI_IF);
36 | SPI_IF = 0;
37 |
38 | SPI_BUF = 0x00;
39 | while(!SPI_IF);
40 | SPI_IF = 0;
41 |
42 | LCD_CS = 1;
43 | }
44 |
45 | void writePORTA(unsigned char b){
46 | LCD_CS = 0;
47 | SPI_BUF = 0x40;
48 | while(!SPI_IF);
49 | SPI_IF = 0;
50 |
51 | SPI_BUF = 0x12;
52 | while(!SPI_IF);
53 | SPI_IF = 0;
54 |
55 | SPI_BUF = b;
56 | while(!SPI_IF);
57 | SPI_IF = 0;
58 |
59 | LCD_CS = 1;
60 | }
61 |
62 | void initPORTB(void){
63 | LCD_CS = 0;
64 | SPI_BUF = 0x40;
65 | while(!SPI_IF);
66 | SPI_IF = 0;
67 |
68 | SPI_BUF = 0x01;
69 | while(!SPI_IF);
70 | SPI_IF = 0;
71 |
72 | SPI_BUF = 0x00;
73 | while(!SPI_IF);
74 | SPI_IF = 0;
75 |
76 | LCD_CS = 1;
77 | }
78 |
79 | void writePORTB(unsigned char b){
80 | LCD_CS = 0;
81 | SPI_BUF = 0x40;
82 | while(!SPI_IF);
83 | SPI_IF = 0;
84 |
85 | SPI_BUF = 0x13;
86 | while(!SPI_IF);
87 | SPI_IF = 0;
88 |
89 | SPI_BUF = b;
90 | while(!SPI_IF);
91 | SPI_IF = 0;
92 |
93 | LCD_CS = 1;
94 | }
95 |
96 | void LCD_Befehl(unsigned char b){
97 | writePORTA(0x00);
98 | Delay10TCYx(20);
99 | Delay10TCYx(20);
100 | Delay10TCYx(20);
101 | writePORTB(b);
102 | Delay100TCYx(10);
103 | writePORTA(0x40);
104 | Delay100TCYx(10);
105 | Delay100TCYx(10);
106 | writePORTA(0x00);
107 | }
108 |
109 | void LCD_Data(unsigned char b){
110 | writePORTA(0x80);
111 | Delay100TCYx(10);
112 | writePORTB(b);
113 | Delay100TCYx(10);
114 | writePORTA(0xC0);
115 | Delay100TCYx(10);
116 | Delay100TCYx(10);
117 | writePORTA(0x00);
118 | TXREG = b; //carriage return
119 | while(!SPI_TRMT); //wait for data TX
120 | SPI_TRMT = 0;
121 | }
122 |
123 | void LCD_Line1(void){
124 | LCD_Befehl(0x80);
125 | }
126 | void LCD_Line2(void){
127 | LCD_Befehl(0xc0);
128 | }
129 | void LCD_Clear(void){
130 | LCD_Befehl(0x01);
131 | }
132 | void LCD_init(void){
133 | LCD_CS_TRIS = 0;
134 | LCD_CS = 1;
135 | Delay10TCYx(20);
136 | Delay10TCYx(20);
137 | Delay10TCYx(20);
138 |
139 | LCD_RESET_TRIS = 0;
140 | LCD_RESET = 0;
141 | Delay10TCYx(20);
142 | Delay10TCYx(20);
143 | LCD_RESET = 1;
144 |
145 | init_SPI();
146 | initPORTA();
147 | initPORTB();
148 |
149 | Delay10TCYx(20);
150 | Delay10TCYx(20);
151 | LCD_Befehl(0x3c); //0011NFxx
152 |
153 | Delay10TCYx(20);
154 | Delay10TCYx(20);
155 | LCD_Befehl(0x0c); //Display off
156 |
157 | Delay10TCYx(20);
158 | Delay10TCYx(20);
159 | LCD_Befehl(0x01); //Display clear
160 |
161 | Delay10TCYx(20);
162 | Delay10TCYx(20);
163 | LCD_Befehl(0x06);} //Entry Mode
die main dazu:
1 | #include <stdio.h>
2 | #include <stdlib.h>
3 | #include <p18f8722.h>
4 | #include "lcd.c"
5 |
6 | #pragma config OSC = HSPLL
7 | #pragma config FCMEN = OFF
8 | #pragma config IESO = OFF
9 | #pragma config PWRT = OFF
10 | #pragma config BOREN = OFF
11 | #pragma config WDT = OFF
12 | #pragma config MCLRE = ON
13 | #pragma config LVP = OFF
14 | #pragma config XINST = OFF
15 |
16 | void main(void) {
17 | LCD_init();
18 | while(1){
19 | LCD_Line1();
20 | LCD_Data('H');
21 | LCD_Data('e');
22 | LCD_Data('l');
23 | LCD_Data('l');
24 | LCD_Data('l');
25 | LCD_Data(' ');
26 | LCD_Data('W');
27 | LCD_Data('o');
28 | LCD_Data('r');
29 | LCD_Data('l');
30 | LCD_Data('d');
31 | LCD_Line2();
32 | LCD_Data('Y');
33 | LCD_Data('E');
34 | LCD_Data('A');
35 | LCD_Data('H');
36 | }
37 |
38 | }
Der Compiler MPLAB X IDE v1.6 - C18(v3.44)
(habs erst mit dem xc8 versucht der macht aber probleme mit der
delays.h)
bringt die Fehlermeldung:
1 | Error - symbol 'init_SPI' has multiple definitions.
2 | Errors : 1
3 |
4 | make[2]: Leaving directory `C:/Users/Tim/Documents/Microchip/LCD-selfmade-0.1.X'
5 | make[1]: Leaving directory `C:/Users/Tim/Documents/Microchip/LCD-selfmade-0.1.X'
6 | make[2]: *** [dist/default/production/LCD-selfmade-0.1.X.production.hex] Error 1
7 | make[1]: *** [.build-conf] Error 2
8 | make: *** [.build-impl] Error 2
9 |
10 | BUILD FAILED (exit value 2, total time: 2s)
hab nun alles 5 mal angeschaut ich finde nirgends eine doppelte
definition?
sieht die jemand oder einen anderen fehler?
mfg
tim
