1 |
2 | /**
3 | * ADCdisplay displays the value of the adc :-)
4 | * version 2 - uses ISR
5 | *
6 | * Outupt on a 2x16 LCD:
7 | * ----------------
8 | * ADC-Value
9 | * -> 223/222/224
10 | * ----------------
11 | * which is -> current / min / max
12 | *
13 | */
14 |
15 | #define F_CPU 16000000UL // Clock speed
16 |
17 | #define LED_RED 0b00000001 // PIN Register for the red led
18 | #define LED_GREEN 0b00000010 // PIN Register for the green led
19 |
20 | #include <stdlib.h>
21 | #include <avr/io.h>
22 | #include <avr/interrupt.h>
23 | #include <util/delay.h>
24 | #include "lcd.h"
25 |
26 | volatile int value = 0; // current value
27 | int last_value = 0; // value from the last messurement
28 | int biggest = 0; // max value
29 | int lowest = 1023; // min value
30 |
31 | char buf[4]; // a buffer for the value to disply
32 |
33 | /**
34 | * On the dev-board there are two
35 | * static led's a red one and a
36 | * green one.
37 | * This routine flashes one off
38 | * the static leds.
39 | * ---------------------------- //
40 | *
41 | */
42 | void blink_led(int led){ // toggle a PIN on PortB for any blink call
43 | PORTB |= led; // LED on
44 | _delay_ms(150);
45 | PORTB &= ~led; // toggle LED off
46 | _delay_ms(300);
47 | return;
48 | }
49 |
50 | /**
51 | * Interupt calld by change in
52 | * ADC register
53 | * ---------------------------- //
54 | *
55 | */
56 | ISR(ADC_vect)
57 | {
58 | blink_led(LED_GREEN); // tell that the conversation is done
59 | value = ADCW;
60 | }
61 |
62 | /**
63 | * Enable and configure
64 | * the analog-digital converter
65 | * ---------------------------- //
66 | *
67 | */
68 | void initADC(channel){
69 |
70 | TCNT0=0x00; // set timer.0 to initial 0
71 | TCCR0B = (1<<CS02); // start timer0 with /256 prescaler
72 |
73 | ADCSRA = (1<<ADEN) // enable ADC
74 | | (1<<ADIE) // enable interupt
75 | | (1<<ADATE)
76 | | (1<<ADPS2) // set 128 to the prescaller
77 | | (1<<ADPS1)
78 | | (1<<ADPS0);
79 |
80 | ADCSRB = ((1<<ADTS2) // set timer.0 overflow
81 | | (0<<ADTS1)
82 | | (0<<ADTS0));
83 |
84 | ADMUX = channel | (1<<REFS0); // set the channel
85 |
86 | }
87 |
88 | /**
89 | * Main routine
90 | * ---------------------------- //
91 | *
92 | */
93 | int main(void){
94 | DDRB = 0b00000011; // set up pin direction PortB as Output
95 | blink_led(LED_RED);
96 |
97 | lcd_init(LCD_DISP_ON); // initialize display, cursor off
98 |
99 | lcd_puts("*** WELCOME ***\n"); // welcome message
100 | lcd_puts(" - ADCV V.2 - ");
101 | _delay_ms(2000); // wait for 2sec
102 |
103 | lcd_clrscr(); // clear display and home cursor
104 | lcd_puts("ADC-Value\n"); // show the mode
105 | lcd_puts("->"); // show the indicator
106 |
107 |
108 | initADC(5);
109 |
110 | sei();
111 | while(1) { // Mainloop
112 | blink_led(LED_RED);
113 |
114 | if(value != last_value){ // if something has changes
115 |
116 | itoa(value, buf, 10); // convert the int to string buffer
117 |
118 | lcd_home(); // display cleanup
119 | lcd_gotoxy(2,1);
120 | lcd_puts(" ");
121 | lcd_home();
122 | lcd_gotoxy(2,1);
123 | lcd_puts(buf); // show current value
124 |
125 | if(value > biggest){ // get min and max
126 | biggest = value;
127 | }
128 | if(value < lowest){
129 | lowest = value;
130 | }
131 |
132 | lcd_puts("/");
133 | itoa(lowest, buf, 10);
134 | lcd_puts(buf); // show min
135 |
136 | lcd_puts("/");
137 | itoa(biggest, buf, 10);
138 | lcd_puts(buf); // show max
139 |
140 | last_value = value; // remember the last value
141 |
142 | }
143 | }
144 | }
