1 | //---------------------------------------------------------------------------
2 |
3 | #include <vcl.h>
4 | #pragma hdrstop
5 |
6 | #include "Unit1.h"
7 | #include "stdafx.h"
8 | #include <windows.h>
9 | #include "FTCSPI.h"
10 |
11 | #define MAX_SPI_93LC56B_CHIP_SIZE_IN_WORDS 128
12 |
13 | // To communicate with the 93LC56(2048 word) EEPROM, the maximum frequency the clock can be set is 1MHz
14 | #define MAX_FREQ_93LC56B_CLOCK_DIVISOR 29 // defualt is 29 equivalent to 1MHz
15 |
16 | const BYTE SPI_EWEN_CMD = '\x9F'; // set up write enable command
17 | const BYTE SPI_EWDS_CMD = '\x87'; // set up write disable command
18 | const BYTE SPI_ERAL_CMD = '\x97'; // set up erase all command
19 |
20 | #define NUM_93LC56B_CMD_CONTOL_BITS 11 //Number of bits required for 93C56 Control operations
21 | #define NUM_93LC56B_CMD_CONTOL_BYTES 2
22 |
23 | #define NUM_93LC56B_CMD_DATA_BITS 16 // Number of bits required for 93C56 Data operations
24 | #define NUM_93LC56B_CMD_DATA_BYTES 2
25 |
26 | #define MAX_READ_DATA_WORDS_BUFFER_SIZE 65536 // Maximum Number of Data words
27 |
28 | typedef WORD ReadDataWordBuffer[MAX_READ_DATA_WORDS_BUFFER_SIZE];
29 | typedef ReadDataWordBuffer *PReadDataWordBuffer;
30 |
31 | #define DEV_DESC "Dual RS232-HS B" //"FT2232H MiniModule A"
32 |
33 | #define BUFSIZE (4*1024*1024) // 4MB - huge buffer to hold all the commands that are sent down the USB to the FT2232H
34 | #define BLOCKSIZE (8*1024) // We read/write chunks of 8kb to the cart
35 | #define NBLOCKS ((512*1024) / BLOCKSIZE)
36 | #define N_WAIT_CYCLES 96 // How many wait cycles for byte programming?
37 |
38 | #define FLASH_RESET 0
39 | #define FLASH_MANUFACTURER 1
40 | #define FLASH_DEVICECODE 2
41 | #define FLASH_WRITEBYTE 3
42 | #define FLASH_CHIPERASE 4
43 | #define FLASH_SECERASE 5
44 | #define FLASH_DEVICECODEEX 6
45 |
46 |
47 | // Command buffer
48 | BYTE cmdBuffer[BUFSIZE];
49 | int PosCmdBuf=0;
50 |
51 | // Data buffers
52 | BYTE datBuffer[BLOCKSIZE];
53 | BYTE verBuffer[BLOCKSIZE];
54 |
55 | // clock divider
56 | DWORD clock_divider=0;
57 |
58 | void CS_Low(void);
59 | void CS_High(void);
60 | void Power_Off(void);
61 | int Sync_To_MPSSE(void);
62 | int OpenDevice(void);
63 | void WriteCart(DWORD addr, BYTE dat, BYTE waitcycles);
64 | BYTE ReadCart(DWORD addr, DWORD nBytes);
65 | void FlushInBuffer(void);
66 | void FlushOutBuffer(void);
67 | void SetSpeed(BYTE speed);
68 | BYTE FlashProcess(int command, DWORD addr, BYTE data);
69 | BYTE ConvByt(BYTE byt);
70 |
71 |
72 |
73 |
74 | //---------------------------------------------------------------------------
75 | #pragma package(smart_init)
76 | #pragma resource "*.dfm"
77 | TForm1 *Form1;
78 | //---------------------------------------------------------------------------
79 | __fastcall TForm1::TForm1(TComponent* Owner)
80 | : TForm(Owner)
81 | {
82 | }
83 | //---------------------------------------------------------------------------
84 | void __fastcall TForm1::Button1Click(TObject *Sender)
85 | {
86 | FTC_STATUS Status = FTC_SUCCESS;
87 | DWORD dwNumHiSpeedDevices = 0;
88 | char szDeviceName[100];
89 | char szChannel[5];
90 | DWORD dwLocationID = 0;
91 | DWORD dwHiSpeedDeviceType = 0;
92 | DWORD dwHiSpeedDeviceIndex = 0;
93 | FTC_HANDLE ftHandle = 0;
94 | char szDeviceDetails[150];
95 | BYTE timerValue = 0;
96 | DWORD dwClockFrequencyHz = 0;
97 | BOOL bPerformCommandSequence = false;
98 | FTC_CHIP_SELECT_PINS ChipSelectsDisableStates;
99 | FTH_INPUT_OUTPUT_PINS HighInputOutputPins;
100 | FTH_LOW_HIGH_PINS HighPinsInputData;
101 | FTC_INIT_CONDITION WriteStartCondition;
102 | WriteControlByteBuffer WriteControlBuffer;
103 | WriteDataByteBuffer WriteDataBuffer;
104 | DWORD dwNumDataBytesToWrite = 0;
105 | FTC_WAIT_DATA_WRITE WaitDataWriteComplete;
106 | FTH_HIGHER_OUTPUT_PINS HighPinsWriteActiveStates;
107 | FTC_CLOSE_FINAL_STATE_PINS CloseFinalStatePinsData;
108 | DWORD dwDataWordInitValue = 0;
109 | DWORD dwDataWordValue = 0;
110 | DWORD dwWriteDataWordAddress = 0;
111 | DWORD dwControlLocAddress1 = 0;
112 | DWORD dwControlLocAddress2 = 0;
113 | FTC_INIT_CONDITION ReadStartCondition;
114 | DWORD dwReadDataWordAddress = 0;
115 | DWORD dwReadWordValue = 0;
116 | ReadDataWordBuffer ReadWordData;
117 | DWORD dwNumDataBytesReturned = 0;
118 | DWORD dwDataWordWritten = 0;
119 | DWORD dwCharCntr = 0;
120 | ReadDataByteBuffer ReadDataBuffer;
121 | DWORD dwReadDataIndex = 0;
122 | ReadCmdSequenceDataByteBuffer ReadCmdSequenceDataBuffer;
123 | int MsgBoxKeyPressed = 0;
124 | DWORD dwLoopCntr = 0;
125 |
126 | char szDllVersion[10];
127 | char szTitleErrorMessage[100];
128 | char szStatusErrorMessage[100];
129 | char szErrorMessage[200];
130 | char szMismatchMessage[100];
131 |
132 | //char channel[1];
133 | char tmp_Channel[5];
134 | unsigned char i;
135 |
136 | //if(RadioButton1->Checked) channel = "A";
137 | //if(RadioButton2->Checked) channel = "B";
138 |
139 | for (dwCharCntr = 0; (dwCharCntr < 100); dwCharCntr++)
140 | szMismatchMessage[dwCharCntr] = '\0';
141 |
142 | for (i = 0; (i < 5); i++)
143 | tmp_Channel[i] = '\0';
144 |
145 | // Get version of DLL file
146 | Status = SPI_GetDllVersion(szDllVersion, 10);
147 | if(Status==FTC_SUCCESS) Edit1->Text = ((AnsiString)szDllVersion);
148 |
149 | Status = SPI_GetNumHiSpeedDevices(&dwNumHiSpeedDevices);
150 | if(Status==FTC_SUCCESS) Edit2->Text = IntToStr((int)dwNumHiSpeedDevices);
151 | //ShowMessage("Qty of HiSpeedDevices : " + IntToStr((int)dwNumHiSpeedDevices));
152 |
153 | if ((Status == FTC_SUCCESS) && (dwNumHiSpeedDevices > 0))
154 | {
155 | do
156 | {
157 |
158 | // This gets the name and location identifier for any FTDI HiSpeed device connected to the host.
159 |
160 | Status = SPI_GetHiSpeedDeviceNameLocIDChannel(dwHiSpeedDeviceIndex, szDeviceName, 100, &dwLocationID, szChannel, 5, &dwHiSpeedDeviceType);
161 | tmp_Channel[0] = szChannel[0];
162 | if(tmp_Channel[0] == 'A') Edit3->Text = szDeviceName;
163 | if(tmp_Channel[0] == 'B') Edit4->Text = szDeviceName;
164 | dwHiSpeedDeviceIndex = dwHiSpeedDeviceIndex + 1; // Increment to look for other HiSpeed device connected to host.
165 |
166 | }
167 | while ((Status == FTC_SUCCESS) && (dwHiSpeedDeviceIndex < dwNumHiSpeedDevices) && (strcmp(szChannel, "B") != 0));
168 |
169 | if (Status == FTC_SUCCESS)
170 | {
171 | if (strcmp(szChannel, "B") != 0)
172 | Status = FTC_DEVICE_IN_USE;
173 | }
174 |
175 | if (Status == FTC_SUCCESS) {
176 |
177 | if (ftHandle != 0)
178 | {
179 | SPI_Close(ftHandle);
180 | ftHandle = 0;
181 | Status == FTC_SUCCESS;
182 | }
183 |
184 | // Opens a handle to the Hi Speed device and initializes the device to default state.
185 |
186 | Status = SPI_OpenHiSpeedDevice(szDeviceName, dwLocationID, szChannel, &ftHandle);
187 |
188 | if (Status == FTC_DEVICE_IN_USE)
189 | {
190 |
191 | if (ftHandle != 0)
192 | {
193 | SPI_Close(ftHandle);
194 | ftHandle = 0;
195 | Status == FTC_SUCCESS;
196 | }
197 | }
198 |
199 | if (Status == FTC_SUCCESS) {
200 |
201 | // Returns the device type, either FT2232H or FT4232H.
202 |
203 | Status = SPI_GetHiSpeedDeviceType(ftHandle, &dwHiSpeedDeviceType);
204 | if (Status == FTC_SUCCESS) {
205 |
206 | strcpy(szDeviceDetails, "Type = ");
207 |
208 | if (dwHiSpeedDeviceType == FT4232H_DEVICE_TYPE) // Is the device a FT4232H ?
209 | strcat(szDeviceDetails, "FT4232H");
210 |
211 | else if (dwHiSpeedDeviceType == FT2232H_DEVICE_TYPE) // Is the device a FT222H ?
212 | strcat(szDeviceDetails, "FT2232H");
213 |
214 | strcat(szDeviceDetails, ", Name = ");
215 | strcat(szDeviceDetails, szDeviceName);
216 |
217 | ShowMessage(szDeviceDetails);
218 |
219 | }
220 | }
221 | }
222 | }
223 |
224 | hier gehts weiter.....
