1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.NUMERIC_STD.ALL;
4 |
5 |
6 | entity PI_Cntr is
7 | Port ( clk : in STD_LOGIC;
8 | setpoint : in STD_LOGIC_VECTOR (31 downto 0);
9 | actualpoint : in STD_LOGIC_VECTOR (31 downto 0);
10 | output : out STD_LOGIC_VECTOR (31 downto 0)
11 | );
12 | end PI_Cntr;
13 |
14 |
15 | architecture Behavioral of PI_Cntr is
16 |
17 | ------------- Begin Cut here for COMPONENT Declaration ------ COMP_TAG
18 | COMPONENT float_sum
19 | PORT (
20 | a : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
21 | b : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
22 | operation : IN STD_LOGIC_VECTOR(5 DOWNTO 0);
23 | result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0)
24 | );
25 | END COMPONENT;
26 |
27 | COMPONENT float_mult
28 | PORT (
29 | a : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
30 | b : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
31 | result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0)
32 | );
33 | END COMPONENT;
34 |
35 |
36 | -- COMP_TAG_END ------ End COMPONENT Declaration ------------
37 |
38 | signal dt : STD_LOGIC_VECTOR(31 DOWNTO 0) := x"38d1b717"; -- 100us
39 | signal Kp : STD_LOGIC_VECTOR(31 DOWNTO 0) := x"3f800000"; -- 1
40 | signal Ki : STD_LOGIC_VECTOR(31 DOWNTO 0) := x"3c23d70a"; -- 0.01
41 | signal max : STD_LOGIC_VECTOR(31 DOWNTO 0) := x"42200000"; -- 40
42 | signal min : STD_LOGIC_VECTOR(31 DOWNTO 0) := x"c2200000"; -- - 40
43 |
44 | signal mult_a, mult_b, mult_r : STD_LOGIC_VECTOR(31 DOWNTO 0):= x"00000000";
45 | signal add_a, add_b, add_r : STD_LOGIC_VECTOR(31 DOWNTO 0):= x"00000000";
46 | signal oper : STD_LOGIC_VECTOR(5 DOWNTO 0) := "000000";
47 | signal integral : STD_LOGIC_VECTOR(31 DOWNTO 0):= x"00000000";
48 | signal error : STD_LOGIC_VECTOR(31 DOWNTO 0):= x"00000000";
49 | signal temp, temp2 : STD_LOGIC_VECTOR(31 DOWNTO 0):= x"00000000";
50 |
51 |
52 | signal cnt : integer range 0 to 15 := 0;
53 |
54 | begin
55 | C0 : float_sum PORT MAP ( a => add_a,
56 | b => add_b,
57 | operation => oper,
58 | result => add_r
59 | );
60 | C1 : float_mult PORT MAP ( a => mult_a,
61 | b => mult_b,
62 | result => mult_r
63 | );
64 |
65 |
66 | GEN: block
67 | begin
68 | process(clk)
69 | begin
70 | IF rising_edge(clk) THEN
71 | cnt <= cnt + 1;
72 | IF cnt = 0 THEN -- Berechnen Error
73 | add_a <= setpoint;
74 | add_b <= actualpoint;
75 | oper <= "000001";
76 | ELSIF cnt = 1 THEN
77 | error <= add_r;
78 | ELSIF cnt = 2 THEN
79 | mult_a <= dt; -- temp = error*dt
80 | mult_b <= error;
81 | ELSIF cnt = 3 THEN
82 | temp <= mult_r; -- Ergebnis der Multiplication wird in
83 | ELSIF cnt = 4 THEN -- integral = integral + temp
84 | add_a <= integral;
85 | add_b <= temp;
86 | oper <= "000000";
87 |
88 | mult_a <= Kp; -- temp2 = Kp * error
89 | mult_b <= error;
90 | ELSIF cnt = 5 THEN
91 | integral <= add_r;
92 | temp2 <= mult_r;
93 | ELSIF cnt = 6 THEN
94 | mult_a <= Ki; -- temp = Ki*Integral
95 | mult_b <= integral;
96 | ELSIF cnt = 7 THEN
97 | temp <= mult_r;
98 | ELSIF cnt = 8 THEN -- Pre_error = temp + temp2
99 | add_a <= temp;
100 | add_b <= temp2;
101 | oper <= "000000";
102 | ELSIF cnt = 9 THEN
103 | output <= add_r;
104 | cnt <= 0;
105 | END IF;
106 | END IF;
107 | END PROCESS;
108 | END BLOCK GEN;
109 |
110 | end Behavioral;
