Wie der Betreff schon sagt versuche ich gerade mein PWM vom PIC12f1501
zu Initialisieren und wollte euch bitten, den Code kurz anzuschauen und
mir zusagen ob ich soweit richtig bin.
1 | #include <pic12f1501.h>
2 | #include <stdio.h>
3 | #include <stdlib.h>
4 | #include <delays.h>
5 |
6 |
7 | // PIC12F1501 Configuration Bit Settings
8 |
9 | #include <xc.h>
10 |
11 | // CONFIG1
12 | #pragma config FOSC = INTOSC // Oscillator Selection Bits (INTOSC oscillator: I/O function on CLKIN pin)
13 | #pragma config WDTE = OFF // Watchdog Timer Enable (WDT disabled)
14 | #pragma config PWRTE = ON // Power-up Timer Enable (PWRT enabled)
15 | #pragma config MCLRE = ON // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
16 | #pragma config CP = ON // Flash Program Memory Code Protection (Program memory code protection is enabled)
17 | #pragma config BOREN = OFF // Brown-out Reset Enable (Brown-out Reset disabled)
18 | #pragma config CLKOUTEN = OFF // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
19 |
20 | // CONFIG2
21 | #pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off)
22 | #pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
23 | #pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
24 | #pragma config LPBOR = OFF // Low-Power Brown Out Reset (Low-Power BOR is disabled)
25 | #pragma config LVP = OFF // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
26 |
27 |
28 |
29 | /*
30 | *
31 | */
32 | void main(void) {
33 |
34 | //INITIALIZING PORTA
35 | PORTA = 0x00;
36 | LATA = 0x00;
37 | ANSELA = 0x00;
38 | TRISA = 0x00;
39 |
40 |
41 | //INITIALIZING PWM
42 | // Fosc = 16000000 Hz
43 | // Fpwm = 10000.00 Hz
44 | // Duty Cycle = 50 %
45 |
46 | PWM1CON = 0x00;
47 | PWM2CON = 0x00;
48 | PWM3CON = 0x00;
49 | PWM4CON = 0x00;
50 |
51 | PR2 = 0x7C ;
52 |
53 | PWM1DCH = 0x00;
54 | PWM2DCH = 0x00;
55 | PWM3DCH = 0x00;
56 | PWM4DCH = 0x00;
57 |
58 | PWM1DCL = 0x3F;
59 | PWM2DCL = 0x3F;
60 | PWM3DCL = 0x3F;
61 | PWM4DCL = 0x3F;
62 |
63 | T2CON = 0x05 ;
64 |
65 |
66 |
67 | while(1);
68 |
69 | }
Bedanke mich schon im vorraus!!!
