1 | /*commands
2 | * 1) cc<0x01>e - TURN ON relay 1
3 | * 2) cc<0x02>e - TURN ON relay 2
4 | * 3) cc<0x03>e - TURN ON relay 3
5 | * 4) cc<0x04>e - TURN ON relay 4
6 | * 5) cc<0x05>e - TURN OFF relay 1
7 | * 6) cc<0x06>e - TURN OFF relay 2
8 | * 7) cc<0x07>e - TURN OFF relay 3
9 | * 8) cc<0x08>e - TURN OFF relay 4
10 | * 9) cc<0x09>e - READ AIN2-2
11 | * 10) cc<0x1A>e - READ AIN2-1
12 | * 11) cc<0x1B>e - READ AIN1-3
13 | * 12) cc<0x1V>e - READ AIN1-2
14 | * 13) cc<0x1D>e - READ DIGITAL INPUTS
15 | * erste Stelle gibt Adresse der Platine an*/
16 |
17 | #include <avr/eeprom.h>
18 | #include <ctype.h>
19 | #include <stdlib.h>
20 | #include <avr/pgmspace.h>
21 | #include "avr/io.h"
22 | #include<string.h>
23 | #include <avr/interrupt.h>
24 | #include <util/delay.h>
25 |
26 | //target//
27 | const char target='c';
28 |
29 | volatile char var;
30 | volatile char flag_address=0;
31 | const unsigned char address=0x05;
32 | volatile char buffer[8];
33 | volatile unsigned char test;
34 | volatile char string_analog[10]="0000000000";
35 | unsigned char i=0;
36 | #define command_on flag_register = 0xFF
37 | #define command_off flag_register = 0x00
38 | int digital(void);
39 | int action (void);
40 | void Print(char Text[80]);
41 | void PrintLine();
42 | void PORT_Init();
43 | void USART_Init( unsigned int ubrr);
44 | unsigned char UART_Receive();
45 | void UART_Transmit(unsigned char Data);
46 | void PrintLn(char Text[80]);
47 | volatile unsigned char u=0;
48 | volatile unsigned char abba;
49 | volatile char result[10]="0000000000";
50 | volatile long rezultat=0;
51 | unsigned char i;
52 | volatile char p,d;
53 | volatile char v[10];
54 |
55 | unsigned char flag_register=0;
56 |
57 | #define __AVR_ATmega16__ 1
58 |
59 | #define FOSC 8000000 /* in Hz */
60 | #define BAUD 9600
61 | #define MYUBRR ((FOSC/16/BAUD)-1)
62 |
63 | char Txt[80];
64 | unsigned char Action = 0;
65 | volatile uint16_t adcval;
66 | volatile struct status {
67 |
68 | unsigned command:1;
69 | unsigned end:1;
70 | unsigned addres:1;
71 | }status_bits;
72 |
73 | //
74 | char *masiv[]={
75 |
76 | "C<0x01>E",
77 | "C<0x02>E",
78 | "C<0x03>E",
79 | "C<0x04>E",
80 | "C<0x05>E",
81 | "C<0x06>E",
82 | "C<0x07>E",
83 | "C<0x08>E",
84 | "C<0x09>E",
85 | "C<0x1A>E",
86 | "C<0x1B>E",
87 | "C<0x1V>E",
88 | "C<0x1D>E"
89 | };
90 |
91 | /* Print new line to the Hyper Terminal */
92 | void PrintLine()
93 | {
94 | UART_Transmit(10);
95 | UART_Transmit(13);
96 | }
97 |
98 | /* PORT_Init */
99 | void PORT_Init()
100 | {
101 | PORTA = 0b00000000;
102 | DDRA = 0b00001111;
103 |
104 | PORTB = 0b00000000;
105 | DDRB = 0b11111000;
106 |
107 | PORTC = 0b00000000;
108 | DDRC = 0b11111111;
109 |
110 | PORTD = 0b00000000;
111 | DDRD = 0b11100010;
112 | }
113 |
114 | /* USART_Init */
115 | void USART_Init( unsigned int ubrr)
116 | {
117 | /* Set baud rate */
118 | UCSRA = 0x00;
119 | /* Enable receiver and transmitter */
120 | UCSRB = (1<<RXEN)|(1<<TXEN)|(1<<RXCIE);
121 | /* Set frame format: 8data, 1stop bit */
122 | UCSRC = 0b10000110;
123 |
124 | UBRRH = (unsigned char)(ubrr>>8);
125 | UBRRL = (unsigned char)ubrr;
126 | }
127 |
128 | /* Read ANALOG inputs */
129 | void analog(unsigned char channel) {
130 | //-- funktioniert--
131 | }
132 |
133 | /* Read DIGITAL inputs */
134 | int digital(void) {
135 | //-- funktioniert--
136 | }
137 |
138 | /* action finction */
139 | int action ()
140 | {
141 | char i=0;
142 | result[0]=0;
143 |
144 | for(i=0;i<10;i++) {result[i]=result[i+1];}
145 | result[8]='\0';
146 |
147 | for(unsigned char zar=0;zar<13;zar++) {
148 |
149 | if(!(strcasecmp(result,masiv[zar])))
150 | {
151 | switch(zar) {
152 | case 0:PORTA|=0b00001000;break;
153 | case 1:PORTA|=0b00000100;break;
154 | case 2:PORTA|=0b00000010;break;
155 | case 3:PORTA|=0b00000001;break;
156 | case 4:PORTA&=0b11110111;break;
157 | case 5:PORTA&=0b11111011;break;
158 | case 6:PORTA&=0b11111101;break;
159 | case 7:PORTA&=0b11111110;break;
160 | case 8:analog(4);break;
161 | case 9:analog(5);break;
162 | case 10:analog(6);break;
163 | case 11:analog(7);break;
164 | case 12:digital();break;
165 | }
166 | }
167 | }
168 | for(unsigned char per=0;per<10;per++)
169 | {result[per]='\0';}
170 | SREG|=0b10000000;
171 | test=0;
172 | return 0;
173 | }
174 |
175 | /* UART Recieve Interrupt */
176 | ISR(USART_RXC_vect)
177 | {
178 | result[u++]=UDR;
179 |
180 | if(u==9) {
181 |
182 | result[9]='\0';
183 | u=0;
184 | SREG&=0b01111111;
185 | var = eeprom_read_byte ((const uint8_t *)(0x00));
186 | if(result[0]==var)
187 | {
188 | PrintLine();
189 | test=1;
190 | UCSRA&=0b01111111;
191 | return;
192 | }
193 |
194 | SREG|=0b10000000;
195 | }
196 | UCSRA&=0b01111111;
197 | return 0;
198 | }
199 |
200 | /* UART Receive */
201 | unsigned char UART_Receive()
202 | {
203 | if (UCSRA & 0b10000000)
204 | return UDR;
205 | else
206 | return 0;
207 | }
208 |
209 | /* UART Transmit */
210 | void UART_Transmit(unsigned char Data)
211 | {
212 |
213 | /* Wait for empty transmit buffer */
214 |
215 | while ( !( UCSRA & (1<<UDRE)) ){}
216 | /* Put data into buffer, sends the data */
217 | UDR = Data;
218 | }
219 | /**************** M A I N ******************/
220 | int main(void)
221 | {
222 | eeprom_is_ready();
223 | eeprom_write_byte ((uint8_t *)(0x00), (uint8_t)(target));
224 | PORT_Init();
225 | USART_Init (MYUBRR);
226 | test=0;
227 | PrintLine();
228 | sei();
229 |
230 | while(1){
231 | if (test!=0)
232 | {
233 | action();
234 | test=0;
235 | }
236 | }
237 | return 0;
238 | }
