VHDL inout Problem
Gast #3039923
ich habe einen CPLD mit 4 Pins (Mini-CPLD) und möchte darüber Lesen und
Schreiben.
Hier der Code:
entity TEST1 is
  Port
    DATA_INOUT  : inout STD_LOGIC_VECTOR (3 downto 0);
    CLK       : in STD_LOGIC
end TEST1;
architecture Behavioral of TEST1 is
  signal DATA_IN    : STD_LOGIC_VECTOR (3 downto 0);
  signal DATA_OUT  : STD_LOGIC_VECTOR (3 downto 0);
  signal COUNTER    : STD_LOGIC_VECTOR (3 downto 0);
  signal MAX_COUNT  : STD_LOGIC_VECTOR (3 downto 0);
  signal READ_DATA  : STD_LOGIC;
begin
  process (CLK)
  begin
    if rising_edge(CLK) then
23
      COUNTER <= STD_LOGIC_VECTOR(unsigned(COUNTER) + 1);
24
25
      if COUNTER = "0000" then
26
        READ_DATA <= '0';
27
        DATA_OUT <= "1010";
28
        if MAX_COUNT = "1111" then
29
          MAX_COUNT <= "0000";
30
        end if;
31
      else
32
        READ_DATA <= '1';
33
        MAX_COUNT <= DATA_IN;
34
      end if;
35
    end if;
36
  end process;
37
38
  process(READ_DATA, DATA_OUT)
39
  begin
40
    if READ_DATA = '1' then
41
      DATA_INOUT <= ( others => 'Z' );
42
      DATA_IN <= DATA_INOUT;
43
    else
44
      DATA_INOUT <= DATA_OUT;
45
    end if;
46
  end process;
47
48
end Behavioral;
Wenn ich das nun hiermit simuliere, dann geht DATA_INOUT auf konstante
'1001' und DATA_IN bzw. DATA_OUT bleiben chronisch auf 'undefined':
ENTITY tb_TEST1 IS
END tb_TEST1;
ARCHITECTURE behavior OF tb_TEST1 IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT TEST1
    PORT(
         DATA_INOUT : INOUT  std_logic_vector(3 downto 0);
         CLK : IN  std_logic
    END COMPONENT;
   --Inputs
   signal CLK : std_logic := '0';
  --BiDirs
   signal DATA_INOUT : std_logic_vector(3 downto 0);
   -- Clock period definitions
23
   constant CLK_period : time := 10 ns;
24
25
BEGIN
26
27
  -- Instantiate the Unit Under Test (UUT)
28
   uut: TEST1 PORT MAP (
29
          DATA_INOUT => DATA_INOUT,
30
          CLK => CLK
31
32
33
   -- Clock process definitions
34
   CLK_process :process
35
   begin
36
    CLK <= '0';
37
    wait for CLK_period/2;
38
    CLK <= '1';
39
40
   end process;
41
42
43
   -- Stimulus process
44
   stim_proc: process
45
   begin
46
      -- hold reset state for 100 ns.
47
      wait for 100 ns;
48
49
      wait for CLK_period*10;
50
51
      -- insert stimulus here
52
    DATA_INOUT <="1001" after 100 ns;
53
54
      wait;
55
   end process;
56
57
END;
Warum werden DATA_IN bzw. DATA_OUT nicht zugewiesen?
Danke Pit
Moderator (Firma: Titel) Persönliche Seite #3040771
bko schrieb:
> Welchen Wert hat "COUNTER" in deiner Simulation?
> Ich meine da fehlt entweder ein Reset oder ein init-wert.
Du meinst richtig. Denn "UUUU"+1 ergibt "UUUU".
Nimm zum zählen doch besser einen integer, dann wird das viel
übersichtlicher und du kannst auf "normale Zahlen" vergleichen. Oder
mach ihn wenigstens unsigned, wenn du den (impliziten) Überlauf nach
16 Takten brauchst. Dann steht da:
  signal COUNTER    : unsigned (3 downto 0) := "0000";
begin
  process (CLK)
  begin
      COUNTER <= COUNTER + 1;
        READ_DATA <= '0';
oder gar
  signal COUNTER    : integer range 0 to 15 := 0;
begin
  process (CLK)
  begin
      if counter<15 then counter <= counter + 1; -- falls Überlauf interessant
      else               counter <= 0;
      end if;
      if COUNTER = 0 then
        READ_DATA <= '0';
> Hier der Code:
Nimm zum Posten von VHDL-Code besser [vhdl] statt [pre]
Und: schreib Signalnamen klein, evtl. mit einem großen
Anfangsbuchstaben, DENN SONST BEKOMMST DU BALD DIE KRÄTZE ANS AUGE, UND
DU MUSST JEDES WORT ZWEIMAL LESEN, WEIL DAS GEHIRN DIESE DAUERNDE
GROSSSCHREIBEREI NICHT GEWÖHNT IST.
Gast #3041307
Erstmal Danke für die Tipps. Ich probiere das auch gleich mal alles aus.
Aber irgendwie werd ich das Gefühl nicht los, daß ich ein ganz anderes
Problem habe.
Folgendes ist Zweck der Übung:
Gegeben sind vier Pins, die als inout definiert sind. Innerhalb der
StateMAchine soll genau einmal von diesen Pins gelesen werden. Der
gelesene Wert soll gespeichert werden und dann innerhalb der
StateMAchine im weiteren Verlauf als Konstante verwendet werden.
Nachdem dieser Wert (die Konstante) gelesen wurde, schalten alle Pins
auf Ausgang, d.h. ab sofort werden über die Pins nur noch Werte
ausgegeben.
Mein Problem ist, egal was ich mache, entweder lese ich nur 'UUUU' von
den Pins oder die gewünschte Konstante wechselt den Wert, sobald ich
Anfange Werte über die Pins auszugeben.
Mein prinzipielles Vorgehen:
-STEP0 (Konstante einlesen):
INOUT <= "ZZZZ"
KONSTANTE <= INOUT
-STEP1 (Konstante verwenden):
if KONSTANTE = "1010" then
  INOUT <= "1111"
else
  INOUT <= "0000"
end if
Naja, wie gesagt da kommt nur Käse dabei raus.
Gast #3041334
Hey,
nur so am Rande, solltest du nicht VOR dem Auslesen der inouts diese auf
'Z' setzen? (mind. 1 takt vorher?) Wenn mich nicht alles täuscht
passiert das bei dir alles beim selben Takt, bzw beim READ_DATA'event
... Ich bin selber nicht so vertraut damit, ich simuliere es mal eben
Gast #3041374
Hmm, scheint auch so zu gehen. Kann mir jemand in einem Satz erklären
warum?
Bleiben wir aber beim Thema, also bei mir funktioniert es (es tut
zumindest etwas, ob es das Richtige ist... naja), sofern ich dem counter
nen Startwert gebe und in der Testbench mit 'H' und 'L' arbeite,
anstelle von '0' und '1'. Ich meine H/L bedeuten soviel wie externe
PullUps / Pulldowns, kollidiert also nicht mit einem entgegengesetztem
internen Zusatnd (wenn inout nicht als Eingang arbeitet). Glaube so war
das, oder?
Moderator (Firma: Titel) Persönliche Seite #3041616
Mein Glückwunsch, du hast die Latency entdeckt.
Das hier
        READ_DATA <= '1';
bedeutet in der Hardware:
Genau mit dem oder gar wegen dem nächsten Takt wird MAX_COUNT
eingelesen, und ein paar ps später (Signallaufzeit bis zum
Ausgangstreiber) wird der Eingang hochohmig geschaltet.
Läuft dein Zähler?
Wird der irgendwann mal "0000"?
Screenshot möglich?
Gast #3042623
Die gute Nachricht vorab: Es macht was ich will.
und
Ich dacht, es ist egal, ob ich da was initialisiere oder nicht, da ich
den Wert erst nach der ersten Zuweisung verwende. Falsch gedacht.
Das hilft, da ich nach dem Einlesen nur noch den Ausgangstreiber habe.
Änderung in der Testbench von
auf
DATA_INOUT <="1001" after 100 ns, "HHHH" after 200 ns;
Fragen bleiben trotzdem. So wie im folgenden habe ich es jetzt und so
funktioniert es.
process (CLK,...)
  if enable = '1' then
    if busy = '0' then
      if my_constant = 0 then
        my_constant <= to_integer(unsigned(data_in));
      end if;
      busy <= '1';
      data_read = '0';
    else --busy
      --StateMAchine mit verschiedenen data_out -Zuweisungen unter Verwendung von my_constant
    end if; --busy
  else --enable
    my_constant = 0;
    data_read = '1';
  end if; --enable
end process;
data_in <= data_inout;
23
24
process(data_read, data_out, data_inout)
25
begin
26
  if data_read = '1' then
27
    data_inout <= ( others => 'Z' );
28
  else
29
    data_inout <= data_out;
30
  end if;
31
end process;
Fragen bleiben trotzdem:
1. Wenn ich die Prüfung auf 'my_constant = 0' vor der Zuweisung von
my_constant weglasse, dann erhalte ich wieder nur Käse für my_constant.
Warum? Etwa deshalb, weil my_constant fest verdrahtet mit data_in ist?
Also nicht so wie beim Programmieren, wo nur bei der Zuweisung der Wert
geändert wird? Ich frage deshalb, weil der Zuweisungspfad ja in jedem
Fall nur einmal durchlaufen wird.
2. Wenn ich den zweiten Prozess wie folgt ändere, funktioniert das Ganze
auch (die Zeile 'data_in <= data_inout;' ist jetzt innerhalb des
Prozesses).
begin
  else
  end if;
end process;
Aber ich erhalte eine Warnung von wegen Latch und so und man sollte das
vermeiden. Wie relevant ist diese Warnung und was hat das zu bedeuten?
Und natürlich Danke für Eure Hilfe!
