1 | /*
2 | * Project name:
3 | Funkuhr
4 | * Copyright:
5 | (c) Peter Schumacher 2013.
6 | * Description:
7 | Funkuhr
8 | * Test configuration:
9 | MCU: PIC18F1320-I/P
10 | http://ww1.microchip.com/downloads/en/devicedoc/39605f.pdf
11 | dev.board: EasyPIC v7
12 | http://www.mikroe.com/eng/products/view/757/easypic-v7-development-system/
13 | internal Oscillator: 125 kHz
14 | external Oscillator: 32,768 kHz external Crystal
15 | Ext. Modules: DCF-77-Receiver
16 | http://ele.pgbesa.net/DCF77.pdf
17 | SW: mikroC PRO for PIC
18 | http://www.mikroe.com/eng/products/view/7/mikroc-pro-for-pic/
19 | */
20 |
21 |
22 | // LCD module connections
23 | sbit LCD_RS at LATA0_bit;
24 | sbit LCD_EN at LATA1_bit;
25 | sbit LCD_D4 at LATA2_bit;
26 | sbit LCD_D5 at LATA3_bit;
27 | sbit LCD_D6 at LATA4_bit;
28 | sbit LCD_D7 at LATB5_bit;
29 |
30 | sbit LCD_RS_Direction at TRISA0_bit;
31 | sbit LCD_EN_Direction at TRISA1_bit;
32 | sbit LCD_D4_Direction at TRISA2_bit;
33 | sbit LCD_D5_Direction at TRISA3_bit;
34 | sbit LCD_D6_Direction at TRISA4_bit;
35 | sbit LCD_D7_Direction at TRISB5_bit;
36 |
37 | #define Empfaenger LATA.F6
38 | #define Signal LATA.F7
39 |
40 | char s = 0; //Sekunde
41 | char m = 0; //Minute
42 | char h = 0; //Stunde
43 | char d = 0; //Tag
44 | char wd = 1; //Wochentag (Mo.-So.)
45 | char mt = 0; //Monat
46 | //Einzelne Ziffern für Ausgabestring
47 | char h1 = 0;
48 | char h2 = 0;
49 | char m1 = 0;
50 | char m2 = 0;
51 | char s1 = 0;
52 | char s2 = 0;
53 |
54 | char txt[9]; //Uhrzeit-String
55 |
56 | //oder:
57 | //char *txt = "00:00:00";
58 |
59 | char Freigabe = 0; //Funksignal wird empfangen
60 |
61 | void interrupt() {
62 | if(Freigabe == 0){
63 | Empfaenger = 1;
64 |
65 | if(Signal){
66 | LATB.F1 = 1; //Pin 9
67 | }
68 | else{
69 | LATB.F1 = 0; //Pin 9
70 | }
71 |
72 | Freigabe = 0;
73 | }
74 |
75 | s++;
76 | if(s == 60){
77 | s = 0;
78 | m++;
79 | }
80 | if(m == 60){
81 | m = 0;
82 | h++;
83 | }
84 | if(h == 24){
85 | h = 0;
86 | wd++;
87 | }
88 | TMR1IF_bit = 0;
89 | INT0IF_bit = 0; //Reset von: INT0 External Interrupt Flag bit
90 | }
91 |
92 | void main() {
93 |
94 | //OSCCON REGISTER
95 | IDLEN_bit = 0; //Run Mode enabled
96 | IRCF2_bit = 0; //internen Oszillator im OSCCON-Register auf 125 kHz setzen
97 | IRCF1_bit = 0;
98 | IRCF0_bit = 1;
99 |
100 | //Port A konfigurieren
101 | TRISA = 0; //Port A als Ausgänge definieren
102 | TRISA.F7 = 1; //Pin 4 von Port A als Eingang definieren
103 | PORTA = 0; //Anfangswert von Port A festlegen
104 |
105 | //Port B konfigurieren
106 | TRISB = 0; //Port B als Ausgänge definieren
107 | TRISB.F0 = 1; // Pin 0 von Port B als Eingang definieren
108 | PORTB = 0; //Anfangswert von Port B festlegen
109 |
110 | //LCD einrichten
111 | Lcd_Init();
112 | Lcd_Cmd(_LCD_CLEAR);
113 | Lcd_Cmd(_LCD_CURSOR_OFF);
114 |
115 | //INTCON REGISTER
116 | GIE_bit = 1; //Enables all unmasked interrupts
117 | PEIE_bit = 1; //Enables all unmasked peripheral interrupts
118 | INT0IE_bit = 1; //INT0 External Interrupt Enable bit (S1-Button at RB0)
119 | INT0IF_bit = 0; //Reset von: INT0 External Interrupt Flag bit
120 |
121 | //T1CON REGISTER
122 | TMR1ON_bit = 1; //Enables Timer1
123 | TMR1CS_bit = 1; //External clock from pin RB6/PGC/T1OSO/T13CKI/P1C/KBI2 (on the rising edge)
124 | T1SYNC_bit = 1; //Do not synchronize external clock input
125 | T1OSCEN_bit = 1; //Timer1 Oscillator Enable bit
126 | TMR1H = 0x80; //Timer1 ist ein 16bit Timer. Hier wrird das höhere Byte "vorgeladen" ("preload"), damit ein Interrupt genau nach jeder Sekunde kommt.
127 |
128 |
129 | do{
130 |
131 | LATB.F4 = 1;
132 |
133 | //Uhrzeit wird in String umgewandelt
134 | h1 = (h / 10) % 10;
135 | h2 = (h ) % 10;
136 | m1 = (m / 10) % 10;
137 | m2 = (m ) % 10;
138 | s1 = (s / 10) % 10;
139 | s2 = (s ) % 10;
140 | txt[0] = '0' + h1;
141 | txt[1] = '0' + h2;
142 | txt[2] = ':';
143 | txt[3] = '0' + m1;
144 | txt[4] = '0' + m2;
145 | txt[5] = ':';
146 | txt[6] = '0' + s1;
147 | txt[7] = '0' + s2;
148 | txt[8] = '\0'; //Strings: http://www.mikrocontroller.net/articles/String-Verarbeitung_in_C
149 |
150 | Lcd_Out(1, 1, txt);
151 |
152 | switch(wd){
153 | case(1): {Lcd_Out(1,15,"Mo"); break;}
154 | case(2): {Lcd_Out(1,15,"Di"); break;}
155 | case(3): {Lcd_Out(1,15,"Mi"); break;}
156 | case(4): {Lcd_Out(1,15,"Do"); break;}
157 | case(5): {Lcd_Out(1,15,"Fr"); break;}
158 | case(6): {Lcd_Out(1,15,"Sa"); break;}
159 | case(7): {Lcd_Out(1,15,"So"); break;}
160 | default: break;
161 | }
162 | Lcd_Cmd(_LCD_RETURN_HOME);
163 | }while(1);
164 | }
