1 | #include <htc.h> /* HiTech General Includes */
2 | #include <stdint.h> /* For uint8_t definition */
3 | #include <stdbool.h> /* For true/false definition */
4 |
5 | #include <pic16f1513.h>
6 | #include "pic16f151x_api.h"
7 | #include "pic16f151x_defines.h"
8 | #include "interrupts.h"
9 |
10 | /******************************************************************************/
11 | /* Defines */
12 | /******************************************************************************/
13 |
14 | #define PORT_ID_A 0x0
15 | #define PORT_ID_B 0x1
16 | #define PORT_ID_C 0x2
17 | #define PORT_ID_E 0x3
18 |
19 | #define ADC_CHAN_NONE 0xff
20 |
21 | #define ADC_CHAN_RA0 0x0
22 | #define ADC_CHAN_RA1 0x1
23 | #define ADC_CHAN_RA2 0x2
24 | #define ADC_CHAN_RA3 0x3
25 | #define ADC_CHAN_RA4 ADC_CHAN_NONE
26 | #define ADC_CHAN_RA5 0x4
27 | #define ADC_CHAN_RA6 ADC_CHAN_NONE
28 | #define ADC_CHAN_RA7 ADC_CHAN_NONE
29 |
30 | #define ADC_CHAN_RB0 0xc
31 | #define ADC_CHAN_RB1 0xa
32 | #define ADC_CHAN_RB2 0x8
33 | #define ADC_CHAN_RB3 0x9
34 | #define ADC_CHAN_RB4 0xb
35 | #define ADC_CHAN_RB5 0xd
36 | #define ADC_CHAN_RB6 ADC_CHAN_NONE
37 | #define ADC_CHAN_RB7 ADC_CHAN_NONE
38 |
39 | #define ADC_CHAN_RC0 ADC_CHAN_NONE
40 | #define ADC_CHAN_RC1 ADC_CHAN_NONE
41 | #define ADC_CHAN_RC2 0xe
42 | #define ADC_CHAN_RC3 0xf
43 | #define ADC_CHAN_RC4 0x10
44 | #define ADC_CHAN_RC5 0x11
45 | #define ADC_CHAN_RC6 0x12
46 | #define ADC_CHAN_RC7 0x13
47 |
48 | #define ADC_CHAN_RE3 ADC_CHAN_NONE
49 |
50 | /* Port register struct */
51 | typedef struct
52 | {
53 | volatile unsigned char* pTris; /* Tristate Register */
54 | volatile unsigned char* pPort; /* State Register */
55 | volatile unsigned char* pAnsel;/* Analog Select Register */
56 | volatile unsigned char* pLat; /* Latch Register*/
57 | }portRegisterStr;
58 |
59 | /* Pin info struct*/
60 | typedef struct
61 | {
62 | bool canOut; /* Pin can be output? */
63 | bool canAnalogIn; /* Pin can be analog input? */
64 | uint8_t portId; /* ID of dedicated port */
65 | uint8_t bitOffs; /* Pin offset in port registers */
66 | uint8_t adcChId; /* ID of dedicated ADC channel */
67 | }pinInfoStr;
68 |
69 | /* List of ports */
70 | static const portRegisterStr portInfoArr[4] =
71 | {
72 | {&TRISA, &PORTA, &ANSELA, &LATA}, /* Port A */
73 | {&TRISB, &PORTB, &ANSELB, &LATB}, /* Port B */
74 | {&TRISC, &PORTC, &ANSELC, &LATC}, /* Port C */
75 | {&TRISE, &PORTE, 0, 0} /* Port E */
76 | };
77 |
78 | /* List of pins */
79 | static const pinInfoStr pinInfoArr[25] =
80 | {
81 | /* Port A */
82 | {true, true, PORT_ID_A, 0, ADC_CHAN_RA0}, /* Pin RA0 */
83 | {true, true, PORT_ID_A, 1, ADC_CHAN_RA1}, /* Pin RA1 */
84 | {true, true, PORT_ID_A, 2, ADC_CHAN_RA2}, /* Pin RA2 */
85 | {true, true, PORT_ID_A, 3, ADC_CHAN_RA3}, /* Pin RA3 */
86 | {true, false, PORT_ID_A, 4, ADC_CHAN_RA4}, /* Pin RA4 */
87 | {true, true, PORT_ID_A, 5, ADC_CHAN_RA5}, /* Pin RA5 */
88 | {true, false, PORT_ID_A, 6, ADC_CHAN_RA6}, /* Pin RA4 */
89 | {true, false, PORT_ID_A, 7, ADC_CHAN_RA7}, /* Pin RA5 */
90 | /* Port B */
91 | {true, true, PORT_ID_B, 0, ADC_CHAN_RB0}, /* Pin RB0 */
92 | {true, true, PORT_ID_B, 1, ADC_CHAN_RB1}, /* Pin RB1 */
93 | {true, true, PORT_ID_B, 2, ADC_CHAN_RB2}, /* Pin RB2 */
94 | {true, true, PORT_ID_B, 3, ADC_CHAN_RB3}, /* Pin RB3 */
95 | {true, true, PORT_ID_B, 4, ADC_CHAN_RB4}, /* Pin RB4 */
96 | {true, true, PORT_ID_B, 5, ADC_CHAN_RB5}, /* Pin RB5 */
97 | {true, false, PORT_ID_B, 6, ADC_CHAN_RB6}, /* Pin RB6 */
98 | {true, false, PORT_ID_B, 7, ADC_CHAN_RB7}, /* Pin RB7 */
99 | /* Port C */
100 | {true, false, PORT_ID_C, 0, ADC_CHAN_RC0}, /* Pin RC0 */
101 | {true, false, PORT_ID_C, 1, ADC_CHAN_RC1}, /* Pin RC1 */
102 | {true, true, PORT_ID_C, 2, ADC_CHAN_RC2}, /* Pin RC2 */
103 | {true, true, PORT_ID_C, 3, ADC_CHAN_RC3}, /* Pin RC3 */
104 | {true, true, PORT_ID_C, 4, ADC_CHAN_RC4}, /* Pin RC4 */
105 | {true, true, PORT_ID_C, 5, ADC_CHAN_RC5}, /* Pin RC5 */
106 | {true, true, PORT_ID_C, 6, ADC_CHAN_RC6}, /* Pin RC6 */
107 | {true, true, PORT_ID_C, 7, ADC_CHAN_RC7}, /* Pin RC7 */
108 | /* Port E */
109 | {false, false, PORT_ID_E, 3, ADC_CHAN_RE3}, /* Pin RE3 */
110 | };
111 |
112 | /* Timer 0 overflow indcation (set by irq callback)*/
113 | static bool timer0Irq = false;
114 |
115 | /*** Set Configuration words ***/
116 | /* Disable watchdog, select internal oscillator, disable MCLRE */
117 | /* Enable Brown-out reset*/
118 | __CONFIG(WDTE_OFF & FOSC_INTOSC & MCLRE_OFF & BOREN_ON);
119 | /* Enable low voltage programming, Set Brown-out high trip point*/
120 | __CONFIG(LVP_ON & BORV_HI);
121 |
122 | /* Callback function for timer 0 overflow*/
123 | void timer0Callback(void)
124 | {
125 | timer0Irq = true;
126 | }
127 |
128 | /* Waits for up to 256 us*/
129 | void picWait_us(uint8_t usVal)
130 | {
131 | TMR0 = ~usVal;
132 | INTCON |= _INTCON_TMR0IE_MASK;
133 | timer0Irq = false;
134 | while(!timer0Irq)
135 | ;
136 | }
137 |
138 | /* Init controller */
139 | void picInit()
140 | {
141 | /* Configure oscillator */
142 | /* Set Internal oscillator to 16 MHz */
143 | OSCCONbits.SCS = 0x2;
144 | OSCCONbits.IRCF = 0xf;
145 | /* Wait for clock stable flag */
146 | while(!(OSCSTAT & _OSCSTAT_HFIOFS_MASK))
147 | ;
148 |
149 | /**** Configure Timer 0 ****/
150 | /* Connect to internal instruction clock */
151 | OPTION_REG &= ~_OPTION_REG_TMR0CS_MASK;
152 | /* Enable timer prescaler */
153 | OPTION_REG &= ~_OPTION_REG_PSA_MASK;
154 | /* Set prescaler to "001" (1:4) */
155 | OPTION_REGbits.PS = 0x1;
156 |
157 | /**** Configure IRC ****/
158 | /* Global interrupt enable */
159 | INTCON |= _INTCON_GIE_MASK;
160 | /* Timer 0 interrupt enable */
161 | INTCON |= _INTCON_T0IE_POSN;
162 |
163 | /**** Configure internal voltage reference ****/
164 | /* Set voltage to 2.048V */
165 | FVRCONbits.ADFVR = 0x2;
166 | /* Fixed volatage enable */
167 | FVRCONbits.FVREN = 1;
168 |
169 | /**** Clear Port Register ****/
170 | PORTA = 0;
171 | PORTB = 0;
172 | PORTC = 0;
173 | PORTE = 0;
174 |
175 | /**** Configure ADC ****/
176 | /* Result format: right aligned */
177 | ADCON1 = _ADCON1_ADFM_MASK;
178 | /* Conversion clock: Fosc/64 */
179 | ADCON1bits.ADCS = 0x6;
180 | /* Reference voltage: internal vref */
181 | ADCON1bits.ADPREF = 0x3;
182 |
183 | /* Register callback function for timer 0 overflow */
184 | registerIsrCallback(timer0Callback);
185 | }
186 |
187 | /* Configure pin*/
188 | void picConfigPin(uint8_t pinId, uint8_t pinSet)
189 | {
190 | switch(pinSet)
191 | {
192 | /* Logical input */
193 | case LOGIC_IN:
194 | /* Set TRIS register bit to 1 (input) */
195 | *(portInfoArr[pinInfoArr[pinId].portId].pTris)
196 | |= (1<<pinInfoArr[pinId].bitOffs);
197 | break;
198 | /* Logical output */
199 | case LOGIC_OUT:
200 | /* Set TRIS register to 0 (output) */
201 | *(portInfoArr[pinInfoArr[pinId].portId].pTris)
202 | &= ~(1<<pinInfoArr[pinId].bitOffs);
203 | break;
204 | /* Analog input */
205 | case ANALOG_IN:
206 | /* Set TRIS register bit to 1 (input) */
207 | *(portInfoArr[pinInfoArr[pinId].portId].pTris)
208 | |= (1<<pinInfoArr[pinId].bitOffs);
209 | /* Set ANSEL register bit to 1 */
210 | *(portInfoArr[pinInfoArr[pinId].portId].pAnsel)
211 | |= (1<<pinInfoArr[pinId].bitOffs);
212 | break;
213 | default : ;
214 | }
215 | }
216 |
217 |
218 | /* Get adc value (0...1023) of selected pin */
219 | uint16_t picReadAdc(uint8_t pinId)
220 | {
221 | int16_t res = 0;
222 | uint8_t pin = pinId;
223 |
224 | /* Select adc channel */
225 | ADCON0bits.CHS = pinInfoArr[pin].adcChId;
226 |
227 | /* Enable adc */
228 | ADCON0bits.ADON = 1;
229 |
230 | /* Acquisition time */
231 | picWait_us(10);
232 |
233 | /* Start conversion */
234 | ADCON0bits.ADGO = 1;
235 |
236 |
237 | /* Wait for adc completion */
238 | while(ADCON0bits.ADGO)
239 | ;
240 |
241 | /* Read result high/low */
242 | res = ((int16_t)ADRESH << 8);
243 | res |= (int16_t)ADRESL;
244 |
245 | ADCON0bits.ADON = 0;
246 | return res;
247 | }
