Hallo, bei meinem unten aufgeführen Programm soll bei einer steigenden Flanke an PortD Pin0 ein Interrupt ausgelöst werden und die LED an Pin14 des PortsD toggeln. Dies geschieht leider nicht. Im Dateianhang ist meine Lösung mit einem Interrupt an PortA Pin0. Damit funktioniert es. Was mach ich falsch? int main (void) { SystemInit(); GPIO_InitTypeDef GPIO_InitStructure; EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; // GPIOD Takt einschalten RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE); // Konfiguriere PD0 soll Interrupt auslösen GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_OType = GPIO_OType_OD; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOD, &GPIO_InitStructure); // GPIOD Takt einschalten /////RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE); // Konfiguriere PD14 toggelt bei Interrupt GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOD, &GPIO_InitStructure); SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOD, EXTI_PinSource0); EXTI_InitStructure.EXTI_Line = EXTI_Line0; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F; NVIC_Init(&NVIC_InitStructure); while(1) { } } void EXTI0_IRQHandler(void){ if(GPIO_ReadOutputDataBit(GPIOD, GPIO_Pin_14)){ GPIO_WriteBit(GPIOD, GPIO_Pin_14, RESET); }else{ GPIO_WriteBit(GPIOD, GPIO_Pin_14, SET); } EXTI_ClearITPendingBit(EXTI_Line0); }
Ich kann dir leider nur sagen, wie es auf meinem F1 geht... björn Pr schrieb: > RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE); Check das nochmal. Mögl. liegen die GPIO beim F4 tatsächlich auf der AHB1 Clock, beim F1 liegen sie auf der AHB2 Clock. Sollte bei dir aber stimmen, wenn überhaupt was auf den Ports geht. > SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOD, EXTI_PinSource0); Sicher, das das so heisst? Bei mir heisst das noch
1 | GPIO_EXTILineConfig(Port_Source,Pin_Source); |
björn Pr schrieb: > void EXTI0_IRQHandler(void){ > if(GPIO_ReadOutputDataBit(GPIOD, GPIO_Pin_14)){ > GPIO_WriteBit(GPIOD, GPIO_Pin_14, RESET); > }else{ > GPIO_WriteBit(GPIOD, GPIO_Pin_14, SET); > } > EXTI_ClearITPendingBit(EXTI_Line0); > } Ich habe hier im Forum irgendwo gelesen, das es vor IO Manipulationen im Interrupt sinnvoll ist, zuerst das INT Flag zu löschen, und erst dann an die Ports zu gehen. Habe ich bei mir so gemacht und geht.
Danke schön, Matthias! Mit dieser Zeile zusätzlich klappt es: RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
