1 | #define F_CPU 3686400
2 | #include <avr\io.h>
3 | //---------------------------------------------------------------------------------
4 | // TWI-Funktionssammlung
5 | #ifndef TWI_CLOCK
6 | #define TWI_CLOCK 100000 // Geschwindigkeit des TWI-Busses
7 | #endif
8 | // TWCR - Control-Register-Bits
9 | #define _TWINT 0b10000000
10 | #define _TWEA 0b01000000
11 | #define _TWSTA 0b00100000
12 | #define _TWSTO 0b00010000
13 | #define _TWWC 0b00001000
14 | #define _TWEN 0b00000100
15 | #define _TWIE 0b00000001
16 | uint8_t twiAdr = 0xD0;
17 | void twiInitMaster(uint8_t twiAdr);
18 | #include <util\delay.h>
19 | #include <util\delay.h>
20 |
21 | //------------------------------------------------------------------------
22 | // twiInitMaster
23 | //------------------------------------------------------------------------
24 | void twiInitMaster(uint8_t twiAdr)
25 | {
26 | // Clock
27 | TWBR=((F_CPU/TWI_CLOCK)-16)*2;
28 | // TWI-Status-Register (Vorteiler)
29 | TWSR=0;
30 | // Bus-Addr
31 | TWAR=twiAdr;
32 | // Enable
33 | TWCR=_TWINT|_TWEN;
34 | }
35 | //------------------------------------------------------------------------
36 | // Start TWI (ohne Interrupt)
37 | //------------------------------------------------------------------------
38 | void twiStart()
39 | {
40 | uint8_t x=TWCR;
41 | x&=_TWEN|_TWIE; // nur Beibehalten von Enable und InterruptJ/N
42 | TWCR=x|_TWINT|_TWSTA;
43 | // warten bis fertig
44 | while( !(TWCR & _TWINT))
45 | {}
46 | }
47 | //------------------------------------------------------------------------
48 | // Stopp TWI (ohne Interrupt)
49 | //------------------------------------------------------------------------
50 | void twiStop()
51 | {
52 | uint8_t x=TWCR;
53 | x&=_TWEN|_TWIE; // nur Beibehalten von Enable und InterruptJ/N
54 | TWCR=x|_TWINT|_TWSTO;
55 | }
56 | //------------------------------------------------------------------------
57 | // Write Byte per TWI (ohne Interrupt)
58 | // PE: data = zu sendende Daten
59 | // ackn = wenn !=0 wird Acknowledge (=TWEA) gesetzt
60 | //------------------------------------------------------------------------
61 | void twiWriteByte(uint8_t data, uint8_t ackn)
62 | {
63 | TWDR=data; // Daten bereitlegen
64 | // Befehl zusammenstellen
65 | uint8_t x=TWCR;
66 | x&=_TWEN|_TWIE; //nur Beibehalten von Enable und InterruptJ/N
67 | x|=_TWINT;
68 | if(ackn)
69 | x|=_TWEA; // evt. TWEA setzen, für Datenanforderung
70 | TWCR=x; // senden
71 | // warten bis fertig
72 | while( !(TWCR & _TWINT))
73 | {}
74 | }
75 | //------------------------------------------------------------------------
76 | // Read Byte per TWI (ohne Interrupt)
77 | // PE: ackn = wenn !=0 wird Acknowledge (=TWEA) gesetzt
78 | // PA: Data
79 | //------------------------------------------------------------------------
80 | int twiReadByte(uint8_t ackn)
81 | {
82 | // Befehl zusammenstellen
83 | uint8_t x=TWCR;
84 | x&=_TWEN|_TWIE; //nur Beibehalten von Enable und InterruptJ/N
85 | x|=_TWINT;
86 | if(ackn)
87 | x|=_TWEA; // evt. TWEA setzen, für Datenanforderung
88 | TWCR=x; // senden
89 | // warten bis fertig
90 | while( !(TWCR & _TWINT))
91 | {}
92 | return TWDR;
93 | }
94 |
95 | //-------------------------------------------------------------------------
96 | // rtcGetRtcData
97 | //-------------------------------------------------------------------------
98 | uint8_t rtcGetRtcData(uint8_t Register)
99 | {
100 | // Adresse senden
101 | twiStart();
102 | twiWriteByte(twiAdr,0);
103 | twiWriteByte(Register,1);
104 | // Daten lesen
105 | twiStart();
106 | twiWriteByte(twiAdr+1,1);
107 | uint8_t b = (uint8_t)twiReadByte(0);
108 | twiStop();
109 | return b;
110 | }
111 | //-------------------------------------------------------------------------
112 | // rtcGetSeconds
113 | //-------------------------------------------------------------------------
114 | uint8_t rtcGetSeconds()
115 | {
116 | return rtcGetRtcData(0) & 0x7F;
117 | }
118 | //-------------------------------------------------------------------------
119 | // rtcGetMinute
120 | //-------------------------------------------------------------------------
121 | uint8_t rtcGetMinute()
122 | {
123 | return rtcGetRtcData(1);
124 | }
125 | //-------------------------------------------------------------------------
126 | // rtcGetHour
127 | //-------------------------------------------------------------------------
128 | uint8_t rtcGetHour()
129 | {
130 | return rtcGetRtcData(2) & 0x3F;
131 | }
132 | //-------------------------------------------------------------------------
133 | // rtcWaitMs
134 | //-------------------------------------------------------------------------
135 | void rtcWaitMs(int miliSec)
136 | {
137 | _delay_loop_2( 1*(F_CPU/(1000/4)) * miliSec); // 4 Zyklen warteschleife
138 | }
139 |
140 | //--------------------------------------------------------------------
141 | // myWait_ms - Warte-Routine für x-Millisekunden (0-255)
142 | // ein Millisekundenzyklus dauert 1,052 ms
143 | // PE: Anzahl der zu wartenden Milisekunden
144 | //--------------------------------------------------------------------
145 | void myWait_ms(uint8_t dauer_ms)
146 | {
147 | __asm__ volatile (
148 | "myWait_ms_0%=:\n"
149 | "push %0\n"
150 | "ldi %0,1\n"
151 | "myWait_ms_3%=:\n"
152 | "push %0\n"
153 | "ldi %0,5\n"
154 | "myWait_ms_2%=:\n"
155 | "push %0\n"
156 | "ldi %0,255\n"
157 | "myWait_ms_1%=:\n"
158 | "dec %0 \n"
159 | "brne myWait_ms_1%=\n"
160 | "pop %0 ; Register wiederherstellen\n"
161 | "dec %0 \n"
162 | "brne myWait_ms_2%=\n"
163 | "pop %0 ; Register wiederherstellen\n"
164 | "dec %0 \n"
165 | "brne myWait_ms_3%=\n"
166 | "pop %0 ; Register wiederherstellen\n"
167 | "dec %0 \n"
168 | "brne myWait_ms_0%=\n"
169 | :
170 | :"d" (dauer_ms)
171 | );
172 | }
173 |
174 | //---------------------------------------------------------------------------
175 | void waitMs(int miliSec)
176 | {
177 | _delay_loop_2( 1*(F_CPU/(1000/4)) * miliSec); // 4 Zyklen warteschleife
178 | }
179 |
180 | //------------------------------------------------------------------------
181 | // Initialisierungen
182 | //------------------------------------------------------------------------
183 | void init()
184 | {
185 | twiInitMaster(twiAdr);
186 | }
187 |
188 | //------------------------------------------------------------------------
189 | // Zahlensystem-Wandler
190 | //------------------------------------------------------------------------
191 |
192 | int dectobcd(int dec)
193 | {
194 | int BCD;
195 | BCD = (((dec / 10) * 16) + (dec % 10));
196 | return BCD;
197 | }
198 |
199 | int bcdtodec(int BCD)
200 | {
201 | int dec;
202 | dec = ((((BCD >> 4)&0b111)*10)+(BCD&0b1111));
203 | return dec;
204 | }
205 |
206 | //------------------------------------------------------------------------
207 | // Einstellung der Zeit
208 | //------------------------------------------------------------------------
209 |
210 | void define_time(int stunde, int minute, int sekunde)
211 | {
212 | twiStart();
213 | twiWriteByte(twiAdr,0);
214 | twiWriteByte(0,1);
215 | sekunde = dectobcd(sekunde);
216 | twiWriteByte(sekunde,1);
217 | minute = dectobcd(minute);
218 | twiWriteByte(minute,1);
219 | stunde = dectobcd(stunde);
220 | twiWriteByte(stunde,1);
221 | twiStop();
222 | }
223 |
224 | //------------------------------------------------------------------------
225 | // Ein/Ausschalten des Relais
226 | //------------------------------------------------------------------------
227 |
228 | int switcher(int stunde_on, int stunde_off)
229 | {
230 | int stunde = 0;
231 | stunde = rtcGetHour();
232 | stunde = bcdtodec(stunde);
233 | if ((stunde>=stunde_on) && (stunde<stunde_off))
234 | {
235 | PORTC = 0x08;
236 | }
237 | else
238 | {
239 | PORTC = 0x00;
240 | }
241 | }
242 |
243 | /////////////////////////////////////////////////////////////////////////////
244 | // Main-Funktion
245 | /////////////////////////////////////////////////////////////////////////////
246 | main()
247 | {
248 | //Variablen-Initialisierung
249 | int zeit1,zeit2;
250 |
251 | init(); // Initialisierungen
252 |
253 | //Zur Zeiteinstellung Kommentare entfernen!
254 | /*zeit1 = rtcGetHour();
255 | zeit2 = rtcGetMinute();
256 |
257 |
258 | if ((zeit1==0)&&(zeit2==0))
259 | {
260 | define_time(8,19,31);
261 | }*/
262 |
263 | // Alternativ: direkte Überschreibung
264 | // define_time(10,10,15);
265 |
266 | DDRC = 0x08;
267 |
268 | while (true) // Mainloop-Begin
269 | {
270 | switcher(11,13);
271 | _delay_ms(1000);
272 | }
