1 | /*
2 | * TASTER_LED.c
3 | *
4 | *
5 | *
6 | */
7 | #ifndef F_CPU
8 | #define F_CPU 1000000 // processor clock frequency
9 | #warning kein F_CPU definiert
10 | #endif
11 | #define REPEAT_MASK (1<<PD0 ) // repeat: key1, key2
12 | #define REPEAT_START 50 // after 500ms
13 | #define REPEAT_NEXT 20 // every 200ms
14 | #include <avr/io.h>
15 | #include <avr/interrupt.h>
16 |
17 |
18 | volatile uint8_t key_state; // debounced and inverted key state:
19 | // bit = 1: key pressed
20 | volatile uint8_t key_press; // key press detect
21 |
22 | volatile uint8_t key_rpt; // key long press and repeat
23 |
24 |
25 | ISR( TIMER0_OVF_vect ) // every 10ms
26 | {
27 | static uint8_t ct0, ct1, rpt;
28 | uint8_t i;
29 |
30 | TCNT0 = (uint8_t)(int16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms
31 |
32 | i = key_state ^ ~PIND; // key changed ?
33 | ct0 = ~( ct0 & i ); // reset or count ct0
34 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
35 | i &= ct0 & ct1; // count until roll over ?
36 | key_state ^= i; // then toggle debounced state
37 | key_press |= key_state & i; // 0->1: key press detect
38 |
39 | if( (key_state & REPEAT_MASK) == 0 ) // check repeat function
40 | rpt = REPEAT_START; // start delay
41 | if( --rpt == 0 ){
42 | rpt = REPEAT_NEXT; // repeat delay
43 | key_rpt |= key_state & REPEAT_MASK;
44 | }
45 | }
46 |
47 | ///////////////////////////////////////////////////////////////////
48 | //
49 | // check if a key has been pressed. Each pressed key is reported
50 | // only once
51 | //
52 | uint8_t get_key_press( uint8_t key_mask )
53 | {
54 | cli(); // read and clear atomic !
55 | key_mask &= key_press; // read key(s)
56 | key_press ^= key_mask; // clear key(s)
57 | sei();
58 | return key_mask;
59 | }
60 |
61 | ///////////////////////////////////////////////////////////////////
62 | //
63 | // check if a key has been pressed long enough such that the
64 | // key repeat functionality kicks in. After a small setup delay
65 | // the key is reported being pressed in subsequent calls
66 | // to this function. This simulates the user repeatedly
67 | // pressing and releasing the key.
68 | //
69 | uint8_t get_key_rpt( uint8_t key_mask )
70 | {
71 | cli(); // read and clear atomic !
72 | key_mask &= key_rpt; // read key(s)
73 | key_rpt ^= key_mask; // clear key(s)
74 | sei();
75 | return key_mask;
76 | }
77 |
78 | ///////////////////////////////////////////////////////////////////
79 | //
80 | // check if a key is pressed right now
81 | //
82 | uint8_t get_key_state( uint8_t key_mask )
83 |
84 | {
85 | key_mask &= key_state;
86 | return key_mask;
87 | }
88 |
89 | ///////////////////////////////////////////////////////////////////
90 | //
91 | uint8_t get_key_short( uint8_t key_mask )
92 | {
93 | cli(); // read key state and key press atomic !
94 | return get_key_press( ~key_state & key_mask );
95 | }
96 |
97 | ///////////////////////////////////////////////////////////////////
98 | //
99 | uint8_t get_key_long( uint8_t key_mask )
100 | {
101 | return get_key_press( get_key_rpt( key_mask ));
102 | }
103 |
104 | int main( void )
105 | {
106 | PORTB = 0xFF;
107 | DDRB = 0xFF;
108 |
109 | DDRD =0x00; // configure key port for input
110 | PORTD =0x00; // and turn on pull up resistors
111 |
112 | TCCR0 = (1<<CS02)|(1<<CS00); // divide by 1024
113 | TCNT0 = (uint8_t)(int16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms
114 | TIMSK |= 1<<TOIE0; // enable timer interrupt
115 |
116 | sei();
117 |
118 | while(1){
119 | if( get_key_short( 1<<PD0 ))
120 | PORTB ^= 1<<PB0;
121 |
122 |
123 | // if( get_key_long( 1<<PD0 ))
124 | // PORTB ^= 1<<PB1;
125 |
126 |
127 |
128 |
129 |
130 |
131 | //if( get_key_press( 1<<KEY2 get_key_rpt( 1<<KEY2 )){
132 | //uint8_t i = LED_PORT;
133 |
134 | //i = (i & 0x07) | ((i << 1) & 0xF0);
135 | //if( i < 0xF0 )
136 | // i |= 0x08;
137 | //LED_PORT = i;
138 | //}
139 | }
140 | }
