1 | #include <stdint.h>
2 | #include <avr/io.h>
3 | #include <avr/delay.h>
4 | #include <avr/interrupt.h>
5 |
6 | #ifndef F_CPU
7 | #define F_CPU 1000000 // processor clock frequency
8 | #warning kein F_CPU definiert
9 | #endif
10 |
11 | #define KEY_DDR DDRD
12 | #define KEY_PORT PORTD
13 | #define KEY_PIN PIND
14 | #define KEY0 0
15 | #define KEY1 1
16 | #define KEY2 2
17 | #define ALL_KEYS (1<<KEY0 | 1<<KEY1 | 1<<KEY2)
18 |
19 | #define REPEAT_MASK (1<<KEY1 | 1<<KEY2) // repeat: key1, key2
20 | #define REPEAT_START 50 // after 500ms
21 | #define REPEAT_NEXT 20 // every 200ms
22 |
23 | #define LED_DDR DDRB
24 | #define LED_PORT PORTB
25 | #define LED0 1
26 | #define LED1 2
27 | #define LED2 3
28 |
29 | volatile uint8_t key_state; // debounced and inverted key state:
30 | // bit = 1: key pressed
31 | volatile uint8_t key_press; // key press detect
32 |
33 | volatile uint8_t key_rpt; // key long press and repeat
34 |
35 |
36 | ISR( TIMER0_OVF_vect ) // every 10ms
37 | {
38 | static uint8_t ct0, ct1, rpt;
39 | uint8_t i;
40 |
41 | TCNT0 = (uint8_t)(int16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms
42 |
43 | i = key_state ^ ~KEY_PIN; // key changed ?
44 | ct0 = ~( ct0 & i ); // reset or count ct0
45 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
46 | i &= ct0 & ct1; // count until roll over ?
47 | key_state ^= i; // then toggle debounced state
48 | key_press |= key_state & i; // 0->1: key press detect
49 |
50 | if( (key_state & REPEAT_MASK) == 0 ) // check repeat function
51 | rpt = REPEAT_START; // start delay
52 | if( --rpt == 0 ){
53 | rpt = REPEAT_NEXT; // repeat delay
54 | key_rpt |= key_state & REPEAT_MASK;
55 | }
56 | }
57 |
58 | ///////////////////////////////////////////////////////////////////
59 | //
60 | // check if a key has been pressed. Each pressed key is reported
61 | // only once
62 | //
63 | uint8_t get_key_press( uint8_t key_mask )
64 | {
65 | cli(); // read and clear atomic !
66 | key_mask &= key_press; // read key(s)
67 | key_press ^= key_mask; // clear key(s)
68 | sei();
69 | return key_mask;
70 | }
71 |
72 | ///////////////////////////////////////////////////////////////////
73 | //
74 | // check if a key has been pressed long enough such that the
75 | // key repeat functionality kicks in. After a small setup delay
76 | // the key is reported being pressed in subsequent calls
77 | // to this function. This simulates the user repeatedly
78 | // pressing and releasing the key.
79 | //
80 | uint8_t get_key_rpt( uint8_t key_mask )
81 | {
82 | cli(); // read and clear atomic !
83 | key_mask &= key_rpt; // read key(s)
84 | key_rpt ^= key_mask; // clear key(s)
85 | sei();
86 | return key_mask;
87 | }
88 |
89 | ///////////////////////////////////////////////////////////////////
90 | //
91 | // check if a key is pressed right now
92 | //
93 | uint8_t get_key_state( uint8_t key_mask )
94 |
95 | {
96 | key_mask &= key_state;
97 | return key_mask;
98 | }
99 |
100 | ///////////////////////////////////////////////////////////////////
101 | //
102 | uint8_t get_key_short( uint8_t key_mask )
103 | {
104 | cli(); // read key state and key press atomic !
105 | return get_key_press( ~key_state & key_mask );
106 | }
107 |
108 | ///////////////////////////////////////////////////////////////////
109 | //
110 | uint8_t get_key_long( uint8_t key_mask )
111 | {
112 | return get_key_press( get_key_rpt( key_mask ));
113 | }
114 |
115 | int main( void )
116 | { volatile int counter=0;
117 | LED_PORT = 0x00;
118 | LED_DDR = 0xFF;
119 |
120 | // Configure debouncing routines
121 | KEY_DDR &= ~ALL_KEYS; // configure key port for input
122 | KEY_PORT |= ALL_KEYS; // and turn on pull up resistors
123 |
124 | TCCR0 = (1<<CS02)|(1<<CS00); // divide by 1024
125 | TCNT0 = (uint8_t)(int16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms
126 | TIMSK |= 1<<TOIE0; // enable timer interrupt
127 |
128 | sei();
129 |
130 | while(1){
131 | if( get_key_short( 1<<KEY1 ))
132 | counter++;
133 |
134 |
135 | if( get_key_long( 1<<KEY1 ))
136 | counter=0;
137 |
138 |
139 | if(counter==0)
140 | LED_PORT = 0x00;
141 |
142 |
143 | if(counter==1)
144 | LED_PORT |= 1<<LED0;
145 |
146 |
147 | if(counter==2)
148 | LED_PORT |= (1<<LED0)| (1<<LED1);
149 |
150 |
151 | if(counter==3)
152 | LED_PORT |= (1<<LED0)| (1<<LED1) | (1<<LED2);
153 | _delay_ms(500);
154 | LED_PORT ^= (1<<LED0)| (1<<LED1) | (1<<LED2);
155 |
156 |
157 | }
158 | }
