1  | #include <stdlib.h>
2  | #include <avr/io.h>
3  | #include <avr/interrupt.h>
4  | #include <avr/pgmspace.h>
5  | #include <util/crc16.h>
6  | #include <avr/eeprom.h>
7  | #include "uart.h"
8  | #include "lib_crc.h"
9  | #include <util/delay.h>
10  |
11  | /* define CPU frequency in Mhz here if not defined in Makefile */
12  | #ifndef F_CPU
13  | #define F_CPU 8000000UL
14  | #endif
15  |
16  |
17  | /* 9600 baud */
18  | #define UART_BAUD_RATE      9600
19  |
20  | uint8_t count =0;
21  | uint8_t timerdelay = 10;
22  | uint8_t t_overflow = 0;
23  | uint16_t ptherme EEMEM = 0000;
24  | void entprellung( volatile uint8_t *port, uint8_t maske ) {
25  |   uint8_t   port_puffer;
26  |   uint8_t   entprellungs_puffer;
27  |
28  |   for( entprellungs_puffer=0 ; entprellungs_puffer!=0xff ; ) {
29  |     entprellungs_puffer<<=1;
30  |     port_puffer = *port;
31  |     _delay_us(150);
32  |     if( (*port & maske) == (port_puffer & maske) )
33  |       entprellungs_puffer |= 0x01;
34  |   }
35  | }
36  |
37  | ISR (TIMER1_OVF_vect)
38  | {  if(count==timerdelay)
39  |   {
40  |     //PORTD ^= (1<<PD3); //Toggeln
41  |     count=0;
42  |     t_overflow = 1;
43  |     TIMSK &= ~(1<<TOIE1);
44  |   }
45  |   count++;
46  | }
47  |
48  | ISR (INT0_vect)
49  | {
50  |   entprellung( &PIND, (1<<PIND2) ); // ggf. Prellen abwarten
51  |     if( PIND & (1<<PIND2) )           // dann stabilen Wert einlesen
52  |     {
53  |       PORTD ^= (1<<PD3); //Toggeln
54  |
55  |       //key_pressed =1; // Taste wurde gedrückt
56  |
57  |     }
58  |     else
59  |     {
60  |
61  |       // mach was anderes
62  |     }
63  |
64  | }
65  |
66  |
67  |
68  | uint16_t CRC_ausgeben(uint8_t *werte,uint8_t j)
69  | {
70  | uint8_t i;
71  | uint16_t CRC_r = 0x0000;
72  | unsigned short crc =0xFFFF;
73  |
74  |   for(i=0;i<j; i++)
75  |        {
76  |          if(i==0)
77  |          CRC_r=update_crc_16(crc,werte[i]);
78  |          else
79  |            CRC_r=update_crc_16(CRC_r,werte[i]);
80  |        }
81  |   return CRC_r;
82  | }
83  |
84  |
85  |
86  |
87  |
88  | int main(void)
89  |  {
90  |
91  |      uint8_t sendstring[6];
92  |      uint8_t i;
93  |      uint16_t crc =0xFFFF;
94  |      uint16_t ergebnis;
95  |
96  |      uint8_t c;
97  |      uint8_t wr_typ = 0;
98  | //Initialisierung
99  |      //USART initialisieren
100  |      uart_init( UART_BAUD_SELECT(UART_BAUD_RATE,F_CPU) );
101  |
102  |      //interrupt an Pin INT0 konfigurieren
103  |         DDRD &= ~(1<< DDD2); //Eingang
104  |         PORTD |= (1<< PD2);
105  |         GICR |= (1<<INT0);
106  |      sei();
107  |      //PIN 3 Port D auf Ausgang
108  |          DDRD |= (1<<DDD3);
109  |          PORTD |= (1<<PD3); //Einschalten
110  |      // 16-bit Timer aktivieren Überlauf alle 8,388 Sekunden
111  |      TCCR1B |= (1<<CS12)| (1<<CS10);
112  |      TIMSK |= (1<<TOIE1);
113  | //Programmstart
114  |      timerdelay = 0; // 4 = ca. 30 Sekunden warten bis WR bereit
115  |
116  |      sendstring[0]=0x02;
117  |      sendstring[1]=0x04;
118  |      sendstring[2]=0x00;
119  |      sendstring[3]=0x00;
120  |      sendstring[4]=0x00;
121  |      sendstring[5]=0x02;
122  |      /*
123  |       * Transmit single character to UART
124  |       */
125  |      uart_putc('\r');  //<-- wird gesendet
126  |
127  |
128  |      ergebnis = CRC_ausgeben( sendstring,6);
129  |
130  |      i = ergebnis;
131  |      uart_putc(i);//<-- wird gesendet
132  |      i = ergebnis >> 8;
133  |      uart_putc(i);//<-- wird gesendet
134  |      // eeprom_busy_wait();
135  |      //eeprom_write_word(&ptherme, 0xffff);
136  |
137  | uart_putc('\r'); // <-- wird nicht gesendet
138  | //eeprom_busy_wait();
139  | //          ergebnis = eeprom_read_word(&ptherme);
140  |
141  | uart_putc('\r'); // <-- wird nicht gesendet
142  | uart_putc(ergebnis); // <-- wird nicht gesendet
143  | uart_putc(ergebnis>>8); // <-- wird nicht gesendet
144  |  PORTD ^= (1<<PD3); //Toggeln // LED geht aber aus, wurde während der Initialisierung eingeschaltet
