1 | #include <stdlib.h>
2 | #include <avr/io.h>
3 | #include <stdio.h>
4 | #ifndef F_CPU
5 | # define F_CPU 1000000UL
6 | #endif
7 | #include <util/delay.h>
8 | #include <util/twi.h>
9 |
10 | #include "iti_twi.h"
11 | #include "uart.h"
12 |
13 | extern void check3();
14 | uint16_t adc_get();
15 |
16 | // Please, DO NOT change anything above this line
17 |
18 | /**************************************************************************************************
19 | * TODO:
20 | *
21 | * Try to to carry out step-by-step the following tasks. At the end of each
22 | * task compile, flash and run the code to check whether it works.
23 | *
24 | * 1. Program the port B as digital output completing the functions led_init() and led_display()
25 | * Set CHECK to 1, and test the code!
26 | *
27 | * 2. Now perform an ADC conversion writing the code in the functions adc_init() and adc_get()
28 | * Set CHECK to 2, and test the code!
29 | *
30 | * 3. Get familiar with the I2C bus, writing the code to read and write a register on an external
31 | device; complete the functions twi_writeregister(...) and twi_readregister(...)
32 | * Set CHECK to 3, and test the code!
33 | *
34 | * 4. Finally, put all together!
35 | * Set CHECK to 0. Then, scroll down to the marked position and write a C-code that
36 | * performs the following operations. Then compile, flash and see everything working...hopefully!
37 | *
38 | * a. initialize all the require peripherals (LEDs, ADC, TWI)
39 | * while(1) {
40 | * b. read the ADC connected to the potentiometer
41 | * c. display its raw value on the led bar
42 | * d. write a formula to convert this value from the range 0..1023 into the range 15..50
43 | * e. use the last converted value (in the range 15..50) as obstacle collision threshold:
44 | * - below this value the LEDs on the display start blinking alerting
45 | * about the presence of a very close object!
46 | * (to make the led blinking, shut them off for 150 ms, then on again)
47 | * - use printf to display the actual distance on the monitor
48 | * }
49 | *
50 | * HINT: printf can help you while debugging your code
51 | *
52 | **************************************************************************************************/
53 |
54 |
55 | // Set the next constant to check your code. Then compile, flash and see what happens...
56 |
57 | #define CHECK 0
58 |
59 | //-------------------------------------------------------------------------------------------------
60 |
61 |
62 | /**
63 | * This function initializes the PORTB as digital output.
64 | * Port B is connected directly to the LEDs bar.
65 | * All the 8-bits are required as output.
66 | *
67 | *
68 | * Paramter:
69 | * -
70 | *
71 | * Return:
72 | * -
73 | */
74 | void led_init() {
75 | // TODO: Configure port B as digital output
76 | DDRB = 0xFF;
77 |
78 | }
79 |
80 | /**
81 | * This function sets the PORTB in order to drive the led bar. The number
82 | * of contiguous led to switch on is proportional to the value passed as paramter.
83 | * Such value has to be in the range 0-1023. All the leds are off only
84 | * when the input value == 0, while any other value will turn on a number
85 | * of leds proportional to the value itself. For example, if the value is 123
86 | * the led bar display the led0 on. If it is 300, led0 and led1 are on.
87 | * And so on...
88 | *
89 | * Paramter:
90 | * - uint16_t value, the number in the range 0-1023 to display on the led bar
91 | *
92 | * Return:
93 | * -
94 | */
95 | void led_display(uint16_t value) {
96 | // TODO:
97 | // 1. If the input value is 0, set port B to 0.
98 | // 2. Otherwise, set to digital one a contiguos number of bit -in the port B-
99 | // proportional to the input value.
100 | if(value == 0) PORTB = 0x00;
101 |
102 | else if((value <= 127) && (value > 0)) PORTB = (1<<PB0);
103 |
104 | else if((value <= 255) && (value > 127)) PORTB = (1<<PB0) | (1<<PB1);
105 |
106 | else if((value <= 383) && (value > 255)) PORTB = (1<<PB0) | (1<<PB1) | (1<<PB2);
107 |
108 | else if((value <= 511) && (value > 383)) PORTB = (1<<PB0) | (1<<PB1) | (1<<PB2) | (1<<PB3);
109 |
110 | else if((value <= 639) && (value > 511)) PORTB = (1<<PB0) | (1<<PB1) | (1<<PB2) | (1<<PB3) | (1<<PB4);
111 |
112 | else if((value <= 767) && (value > 639)) PORTB = (1<<PB0) | (1<<PB1) | (1<<PB2) | (1<<PB3) | (1<<PB4) | (1<<PB5);
113 |
114 | else if((value <= 895) && (value > 767)) PORTB = (1<<PB0) | (1<<PB1) | (1<<PB2) | (1<<PB3) | (1<<PB4) | (1<<PB5) | (1<<PB6);
115 |
116 | else if((value <= 1023) && (value > 895)) PORTB = (1<<PB0) | (1<<PB1) | (1<<PB2) | (1<<PB3) | (1<<PB4) | (1<<PB5) | (1<<PB6) | (1<<PB7);
117 |
118 | }
119 |
120 |
121 | /**
122 | * Initialize the ADC.
123 | *
124 | * Params:
125 | * -
126 | *
127 | * Return:
128 | * -
129 | */
130 | void adc_init() {
131 | // TODO:
132 | // 1. Enable the ADC by setting the bit ADEN in the register ADCSRA,
133 | // and configure the prescaler with a division factor of 128
134 | // selecting ADPS2:0 as mentioned in the Atmega16 datasheet.
135 |
136 | ADCSRA = (1<<ADEN) | (1<<ADPS0) | (1<<ADPS1) | (1<<ADPS2);
137 |
138 |
139 | // 2. Set REFS1:0 in the ADMUX register to select the supply voltage
140 | // (VCC) as reference voltage (AVCC) for the ADC: set REFS1:0 to 01
141 |
142 | ADMUX = (1<<REFS0) | (0<<REFS1);
143 |
144 | // 3. Perform a dummy reading to clear the ADC before the first real
145 | // reading, and ignore the result.
146 |
147 | adc_get();
148 | }
149 |
150 | /**
151 | * Get a value from the ADC.
152 | *
153 | * Params:
154 | * -
155 | *
156 | * Return:
157 | * - the raw value read on the ADC.
158 | */
159 | uint16_t adc_get() {
160 | // TODO:
161 | // 1. Set the bit ADSC to start a conversion, but be careful not to
162 | // alter other bits set before during the initialization!
163 |
164 | ADCSRA = (1<<ADSC);
165 |
166 | // 2. Wait until the ADSC bit is cleared up again: that means the
167 | // conversion is done.
168 |
169 | while(ADSC != 0);
170 |
171 | // 3. Return the value you can read in the register ADCW.
172 |
173 | return ADCW;
174 | }
175 |
176 | /**
177 | * Write a byte in a specific register of a TWI device.
178 | *
179 | * Params:
180 | * uint8_t twi_addr, the addresse of the TWI device to communicate with
181 | * uint8_t reg, the number of the register in the TWI device to write to
182 | * uint8_t data, data byte to be written
183 | *
184 | * Return:
185 | * - the status of the sending operation
186 | */
187 | uint8_t twi_writeregister(uint8_t twi_addr, uint8_t reg, uint8_t data) {
188 |
189 | uint8_t ret = 0;
190 |
191 | //TODO:
192 | // 1. Start the TWI communication, waiting until started
193 |
194 | twi_start();
195 |
196 | // 2. Write the address of the TWI device to communicate with
197 |
198 | twi_sla_w(twi_addr);
199 |
200 | // 3. Send the number of the register in the TWI device to write to
201 |
202 | twi_sla_r(reg);
203 |
204 | // 4. Send the data byte, saving the status of the operation in the variable ret
205 |
206 | twi_send(data);
207 | reg = twi_wait4TWINT();
208 |
209 | // 5. Stop the TWI communication, then return
210 |
211 | twi_stop();
212 |
213 | return ret;
214 | }
215 |
216 | /**
217 | * Read a byte from a specific register of a TWI device.
218 | *
219 | * Params:
220 | * uint8_t twi_addr, the addresse of the TWI device to communicate with
221 | * uint8_t reg, the number of the register in the TWI device to read from
222 | * uint8_t *data, pointer to a variable the incoming data is written to
223 | *
224 | * Return:
225 | * - the status of the reading operation
226 | */
227 | uint8_t twi_readregister(uint8_t twi_addr, uint8_t reg, uint8_t* data) {
228 |
229 | uint8_t ret = 0;
230 |
231 | //TODO:
232 | // 1. Start the TWI communication, waiting until started
233 |
234 | twi_start();
235 |
236 | // 2. Write the address of the TWI device to communicate with
237 |
238 | twi_sla_w(twi_addr);
239 |
240 | // 3. Send the number of the register in the TWI device to read from
241 |
242 | twi_sla_r(reg);
243 |
244 | // 4. Stop the communication
245 |
246 | twi_stop();
247 |
248 | // 5. Restart the TWI communication as before
249 |
250 | twi_rep_start();
251 |
252 | // 6. Put the read-address of the TWI device on the bus, remembering to set its LSB to 1
253 |
254 | twi_addr |= 0x01; // setzen des untersten bits
255 | twi_sla_w(twi_addr);
256 |
257 | // 7. Read the byte from the bus into the pointed variable data. Perform the reading without ACK!
258 | // Store in the variable ret the status of the reading operation.
259 |
260 | twi_read(0,data);
261 | ret = twi_wait4TWINT();
262 |
263 | // 8. Stop the TWI communication, then return
264 |
265 | twi_stop();
266 |
267 | return ret;
268 | }
269 |
270 |
271 |
272 | int main ( void ) {
273 | // Please, DO NOT edit the next 26 lines, or the CHECK will not work properly
274 | uart_init();
275 | #if CHECK == 1
276 | uint16_t val = 0;
277 | led_init();
278 | while(1) {
279 | led_display(val);
280 | val++;
281 | val &= 0x3FF;
282 | _delay_ms(1);
283 | }
284 | #elif CHECK == 2
285 | uint16_t raw;
286 | led_init();
287 | adc_init();
288 | while(1) {
289 | raw = adc_get();
290 | led_display(raw);
291 | _delay_ms(80);
292 | }
293 | #elif CHECK == 3
294 | led_init();
295 | twi_init();
296 | while(1) {
297 | check3();
298 | }
299 | #else
300 | // ********************************************************************
301 | // Put the code for the last task (4.) here:
302 |
303 | uint16_t adcValue = 0;
304 |
305 | // Initializing LED, ADC, TWI
306 |
307 | led_init();
308 | adc_init();
309 | twi_init();
310 |
311 | while(1){
312 |
313 | adcValue = adc_get();
314 | led_display(adcValue);
315 |
316 |
317 | }
318 |
319 |
320 | // ********************************************************************
321 | #endif
322 | return 0;
323 | }
