AVR ISP MK II + avrdude + linux | Nur mit sudo möglich
Gast #3168286
Moin,
ich versuche soeben den AVR ISP mk II bei mir unter archlinux zum Laufen
zu bringen.
Wenn ich avrdude als root starte funktioniert es auch:
sudo avrdude -c avrispmkII -p m8 -P usb -v
 sudo avrdude -c avrispmkII -p m8 -P usb -v           :(
avrdude: Version 5.11.1, compiled on Apr  6 2013 at 19:33:35
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/root/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : avrispmkII
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200122622
         AVR Part                      : ATMEGA8
         Chip Erase delay              : 10000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
23
         StabDelay                     : 100
24
         CmdexeDelay                   : 25
25
         SyncLoops                     : 32
26
         ByteDelay                     : 0
27
         PollIndex                     : 3
28
         PollValue                     : 0x53
29
         Memory Detail                 :
30
31
                                  Block Poll               Page                       Polled
32
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
33
34
           eeprom         4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
35
           flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
36
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
37
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
38
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
39
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
40
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
41
42
         Programmer Type : STK500V2
43
         Description     : Atmel AVR ISP mkII
44
         Programmer Model: AVRISP mkII
45
         Hardware Version: 1
46
         Firmware Version Master : 1.22
47
         Vtarget         : 0.0 V
48
         SCK period      : 2.00 us
49
50
avrdude: stk500v2_command(): command failed
51
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: Target not detected
52
avrdude: initialization failed, rc=-1
53
         Double check connections and try again, or use -F to override
54
         this check.
55
56
57
avrdude done.  Thank you.
Ohne das "sudo" davor, funktioniert es aber nicht.
         User configuration file is "/home/user/.avrduderc"
         Using Port                    : usb
avrdude: usbdev_open(): did not find any USB device "usb"
Ich habe jedoch eine udev-Regel wie folgt erstellt:
SUBSYSTEM=="usb", ATTRS{idVendor]=="03eb", ATTRS{idProduct}=="2104", GROUP="users", MODE="0660"
Hat da jemand eine Idee ?
Viele Grüße
Gast #3168651
>Norbert schrieb:
> Falls du dich der Gruppe users gerade erst zugeordnet hast, bitte einmal
> abmelden und wieder anmelden.
> Ansonsten, was sagt denn 'ls -l /dev/usb' ?
> Und was sagt: 'groups'  ?
Bin schon immer in der Gruppe, da "users" unter Arch die Standardgruppe
ist.
groups enthält dementsprechend auch natürlich "users":
adm lp wheel log games video audio optical storage scanner power users vboxusers adbusers
'ls -l /dev/usb' sagt:
crw------- 1 root root 180, 0 17. Mai 21:46 hiddev0
crw------- 1 root root 180, 1 17. Mai 21:46 hiddev1
Wahrscheinlich Maus+Tastatur.
>g457 schrieb:
> Hast Du auch den udevd neu gestartet?
Mehrmals, oft genug aber auch das komplette System. Der Fehler besteht
schon einige Tage.
Gast #3169157
So, ich habe noch ein wenig rumgespielt, letztendlich sieht meine
udev-Rule aber immer noch exakt so aus, wie oben bereits gepostet.
Auf Einmal funktioniert es nun plötzlich, ich habe keine Ahnung warum.
Trotzdem danke für die Hilfe ! :D
#3216925
Als weitere Hilfe für Leute mit dem selben Problem:
die udev rules Datei schreibt man normalerweise im /etc/udev/rules.d
Aber ACHTUNG! Verzeichnis /lib/udev/rules.d/ kontrollieren. Da habe ich
eine .rules Datei mit veralteten Syntax (SYSTEM... anstatt ATTR{...)
gefunden. Dieser Datei hat dazu geführt, dass mein avr isp mkII nicht
wie in meinem richtigen rules Datei von udev eingestellt wurde.
Der Datei im /lib... gelöscht, der im /etc... kontrolliert und gelassen.
Danach udev restarten und Gerät aus und wieder eingesteckt.
Danach hat es einwandfrei und ohne super user mit avrdude funktioniert.
Hoffentlich hilft es euch weiter!
