1 | ----------------------------------------------------------------------------------
2 | -- Company:
3 | -- Engineer:
4 | --
5 | -- Create Date: 12:20:00 03/25/2013
6 | -- Design Name:
7 | -- Module Name: Farbansteuerung - Behavioral
8 | -- Project Name:
9 | -- Target Devices:
10 | -- Tool versions:
11 | -- Description:
12 | --
13 | -- Dependencies:
14 | --
15 | -- Revision:
16 | -- Revision 0.01 - File Created
17 | -- Additional Comments:
18 | --
19 | ----------------------------------------------------------------------------------
20 | library IEEE;
21 | use IEEE.STD_LOGIC_1164.ALL;
22 | use IEEE.STD_LOGIC_ARITH.ALL;
23 | use IEEE.STD_LOGIC_UNSIGNED.ALL;
24 |
25 |
26 | entity Farbansteuerung is
27 |
28 | PORT (
29 | REDout : OUT std_logic_vector (2 DOWNTO 0);
30 | BLUEout : OUT std_logic_vector (2 DOWNTO 0);
31 | GREENout : OUT std_logic_vector (2 DOWNTO 0);
32 | vz_inoutin : IN std_logic_vector (9 downto 0);
33 | hz_inoutin : IN std_logic_vector (9 downto 0);
34 | clk25in : IN std_logic;
35 | reset_freigabe_in : IN std_logic;
36 | kollision_out : OUT std_logic;
37 | bewegung_oben_in : IN std_logic_vector(9 downto 0);
38 | bewegung_unten_in : IN std_logic_vector(9 downto 0);
39 | bewegung_rechts_in : IN std_logic_vector(9 downto 0);
40 | bewegung_links_in : IN std_logic_vector(9 downto 0)
41 | --mauer_reset_out : OUT std_logic_vector (9 downto 0)
42 | );
43 |
44 | end Farbansteuerung;
45 |
46 | architecture Behavioral of Farbansteuerung is
47 |
48 | --signal mauer_reset: std_logic_vector (9 DOWNTO 0);
49 |
50 | signal kollision: std_logic := '0';
51 |
52 | begin
53 |
54 | process(clk25in,reset_freigabe_in)
55 |
56 |
57 | variable schwarz: std_logic_vector(1 downto 0) := "00";
58 | variable spielfigur_x : std_logic_vector(9 downto 0) := "0010001110"; -- + bewegung_rechts_in - bewegung_links_in;
59 | variable spielfigur_y : std_logic_vector(9 downto 0) := "0111101111"; -- - bewegung_oben_in + bewegung_unten_in;
60 |
61 | begin
62 |
63 | if (clk25in'EVENT AND clk25in = '1') then
64 |
65 |
66 |
67 | --mauer_reset <= "0010101011" + bewegung_rechts_in - bewegung_links_in;
68 |
69 |
70 | if(reset_freigabe_in = '1')then
71 | REDout <= "000";
72 | BLUEout <= "000";
73 | GREENout <= "000";
74 |
75 |
76 | if
77 | hz_inoutin < "0010010000" --81 positionierungseinstellung bildschirm 21/70
78 | or hz_inoutin > "1100010000" --784
79 | or vz_inoutin < "0000000011" --3
80 | or vz_inoutin > "1000001001" --521
81 |
82 | THEN
83 | REDout <= "000";
84 | BLUEout <= "000";
85 | GREENout <= "000";
86 |
87 |
88 | --spielfigur (blue)
89 | elsif
90 | (
91 | -- (hz_inoutin > "0010001110" + bewegung_rechts_in - bewegung_links_in) --142
92 | --AND (hz_inoutin < "0010101011" + bewegung_rechts_in - bewegung_links_in) --171
93 | --AND (vz_inoutin > "0111101111" - bewegung_oben_in + bewegung_unten_in) --495
94 | --AND (vz_inoutin < "1000001001" - bewegung_oben_in + bewegung_unten_in) --521
95 |
96 | -- (hz_inoutin = spielfigur_x) --27 "0000011011"
97 | -- AND (vz_inoutin = spielfigur_y) --24 "0000011000"
98 |
99 |
100 | (hz_inoutin > spielfigur_x + bewegung_rechts_in - bewegung_links_in)
101 | AND (hz_inoutin < spielfigur_x + bewegung_rechts_in - bewegung_links_in + "0000011011")
102 | AND (vz_inoutin > spielfigur_y - bewegung_oben_in + bewegung_unten_in)
103 | AND (vz_inoutin < spielfigur_y - bewegung_oben_in + bewegung_unten_in + "0000011000")
104 |
105 | )
106 |
107 | THEN
108 | REDout <= "000";
109 | BLUEout <= "111";
110 | GREENout <= "000";
111 |
112 |
113 | --Kollison--
114 |
115 | --ELSIF
116 | --(
117 | -- REDout = "000"
118 | -- AND BLUEout = "000"
119 | -- AND GREENout = "000"
120 | --)
121 |
122 | --THEN
123 | --schwarz <= "0000000001";
124 |
125 |
126 | --ELSE
127 | --schwarz <= "0000000000";
128 |
129 |
130 |
131 |
132 |
133 | ELSIF
134 | (
135 |
136 | schwarz = spielfigur_x + bewegung_rechts_in - bewegung_links_in - "0000000001"
137 | OR schwarz = spielfigur_x + bewegung_rechts_in - bewegung_links_in + "0000011100"
138 | OR schwarz = spielfigur_y - bewegung_oben_in + bewegung_unten_in
139 | OR schwarz = spielfigur_y - bewegung_oben_in + bewegung_unten_in + "0000011001"
140 |
141 | )
142 |
143 | THEN
144 | kollision <= '1';
145 |
146 |
147 | --ELSE
148 | --kollision <= '0';
149 |
150 |
151 |
152 | --Leveldesign
153 | --Hindernis (schwarz)
154 | --1
155 | ELSIF
156 | ( (hz_inoutin > "0011000001") --192
157 | AND (hz_inoutin < "0011001011") --203
158 | AND (vz_inoutin > "0001011010") --90
159 | AND (vz_inoutin < "1000001001") --521
160 | )
161 |
162 | --2
163 | OR
164 | ( (hz_inoutin > "0011111101") --253
165 | AND (hz_inoutin < "0100001000") --264
166 | AND (vz_inoutin > "0000100111") --39
167 | AND (vz_inoutin < "0101100000") --352
168 | )
169 |
170 | --3
171 | OR
172 | ( (hz_inoutin > "0011001010") --202
173 | AND (hz_inoutin < "0101000011") --323
174 | AND (vz_inoutin > "0110010011") --403
175 | AND (vz_inoutin < "0110011110") --414
176 | )
177 |
178 | --4
179 | OR
180 | ( (hz_inoutin > "0100111000") --312
181 | AND (hz_inoutin < "0101000011") --323
182 | AND (vz_inoutin > "0011010010") --210
183 | AND (vz_inoutin < "0110011110") --414
184 | )
185 |
186 | --5
187 | OR
188 | ( (hz_inoutin > "0100111000") --312
189 | AND (hz_inoutin < "1010011010") --666
190 | AND (vz_inoutin > "0011010010") --210
191 | AND (vz_inoutin < "0011011101") --221
192 | )
193 |
194 | --6
195 | OR
196 | ( (hz_inoutin > "1010001111") --655
197 | AND (hz_inoutin < "1010011010") --666
198 | AND (vz_inoutin > "0001011010") --90
199 | AND (vz_inoutin < "0011011101") --221
200 | )
201 |
202 | --7
203 | OR
204 | ( (hz_inoutin > "0100111011") --315
205 | AND (hz_inoutin < "1010011010") --666
206 | AND (vz_inoutin > "0001011010") --90
207 | AND (vz_inoutin < "0001100101") --101
208 | )
209 |
210 | --8
211 | OR
212 | ( (hz_inoutin > "0011111101") --253
213 | AND (hz_inoutin < "1001100111") --615
214 | AND (vz_inoutin > "0010010110") --150
215 | AND (vz_inoutin < "0010100001") --161
216 | )
217 |
218 | --9
219 | OR
220 | ( (hz_inoutin > "1011001010") --714
221 | AND (hz_inoutin < "1011010101") --725
222 | AND (vz_inoutin > "0000100111") --39
223 | AND (vz_inoutin < "0111010110") --470
224 | )
225 |
226 | --10
227 | OR
228 | ( (hz_inoutin > "0101110101") --373
229 | AND (hz_inoutin < "1011010101") --725
230 | AND (vz_inoutin > "0100001111") --271
231 | AND (vz_inoutin < "0100011010") --282
232 | )
233 |
234 | --11
235 | OR
236 | ( (hz_inoutin > "0101110101") --373
237 | AND (hz_inoutin < "0110000000") --384
238 | AND (vz_inoutin > "0100001111") --271
239 | AND (vz_inoutin < "0111010110") --470
240 | )
241 |
242 | --12
243 | OR
244 | ( (hz_inoutin > "0011111110") --354
245 | AND (hz_inoutin < "0110000000") --384
246 | AND (vz_inoutin > "0111001011") --459
247 | AND (vz_inoutin < "0111010110") --470
248 | )
249 |
250 | --13
251 | OR
252 | ( (hz_inoutin > "0111110100") --500
253 | AND (hz_inoutin < "0111111111") --511
254 | AND (vz_inoutin > "0101001101") --333
255 | AND (vz_inoutin < "1000001001") --521
256 | )
257 |
258 |
259 | THEN
260 | REDout <= "000";
261 | BLUEout <= "000";
262 | GREENout <= "000";
263 | schwarz := "01";
264 |
265 |
266 | --Ziel
267 | ELSIF
268 | ( (hz_inoutin > "1011010100") --724
269 | AND (hz_inoutin < "1100010010") --786
270 | AND (vz_inoutin > "0000100111") --39
271 | AND (vz_inoutin < "0001000001") --65
272 | )
273 |
274 |
275 | THEN
276 | REDout <= "000";
277 | BLUEout <= "000";
278 | GREENout <= "111";
279 |
280 |
281 | else
282 | REDout <= "111";
283 | BLUEout <= "111";
284 | GREENout <= "111";
285 | --Kollision--
286 | schwarz := "00";
287 | kollision <= '0';
288 |
289 |
290 | END IF;
291 | END IF;
292 | end if;
293 |
294 |
295 |
296 | end process;
297 |
298 | --mauer_reset_out <= mauer_reset;
299 | kollision_out <= kollision;
300 |
301 | end Behavioral;
