1 | static OS_TCB AppTaskStartTCB;
2 | static CPU_STK AppTaskStartStk[APP_TASK_START_STK_SIZE];
3 |
4 | static void AppTaskStart (void *p_arg);
5 |
6 | static OS_TMR Tmr;
7 | void Fnct(void);
8 |
9 |
10 | int main(void)
11 | {
12 | OS_ERR err;
13 |
14 | /* Setup STM32 system (clock, PLL and Flash configuration) */
15 | BSP_IntDisAll(); /* Disable all interrupts. */
16 |
17 | OSInit(&err); /* Init uC/OS-III. */
18 |
19 | OSTaskCreate((OS_TCB *)&AppTaskStartTCB, /* Create the start task */
20 | (CPU_CHAR *)"App Task Start",
21 | (OS_TASK_PTR)AppTaskStart,
22 | (void *)0,
23 | (OS_PRIO )APP_TASK_START_PRIO,
24 | (CPU_STK *)&AppTaskStartStk[0],
25 | (CPU_STK *)&AppTaskStartStk[APP_TASK_START_STK_SIZE / 10],
26 | (OS_STK_SIZE)APP_TASK_START_STK_SIZE,
27 | (OS_MSG_QTY )0,
28 | (OS_TICK )0,
29 | (void *)0,
30 | (OS_OPT )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
31 | (OS_ERR *)&err);
32 |
33 | OSStart(&err); /* Start multitasking (i.e. give control to uC/OS-III). */
34 | return (0);
35 | }
36 |
37 | static void AppTaskStart (void *p_arg)
38 | {
39 | CPU_INT32U cpu_clk_freq;
40 | CPU_INT32U cnts;
41 | OS_ERR err;
42 |
43 | (void)p_arg;
44 |
45 | BSP_Init(); /* Initialize BSP functions */
46 | CPU_Init(); /* Initialize the uC/CPU services */
47 |
48 | cpu_clk_freq = BSP_CPU_ClkFreq(); /* Determine SysTick reference freq. */
49 | cnts = cpu_clk_freq / (CPU_INT32U)10000; //OSCfg_TickRate_Hz; /* Determine nbr SysTick increments */
50 | OS_CPU_SysTickInit(cnts); /* Init uC/OS periodic time src (SysTick). */
51 |
52 | #if OS_CFG_STAT_TASK_EN > 0u
53 | OSStatTaskCPUUsageInit(&err); /* Compute CPU capacity with no task running */
54 | #endif
55 |
56 | CPU_IntDisMeasMaxCurReset();
57 |
58 | OSTmrCreate((OS_TMR *)&Tmr,
59 | (CPU_CHAR *)"Timer",
60 | (OS_TICK )10,
61 | (OS_TICK )100,
62 | (OS_OPT )OS_OPT_TMR_PERIODIC,
63 | (OS_TMR_CALLBACK_PTR)Fnct,
64 | (void *)0,
65 | (OS_ERR *)&err);
66 |
67 | CPU_BOOLEAN status;
68 | status = OSTmrStart((OS_TMR *)&Tmr, &err);
69 |
70 | while (DEF_TRUE)
71 | {
72 | Led_Toggle(1);
73 | }
74 | }
75 |
76 |
77 | void Fnct(void)
78 | {
79 | Led_Toggle(2);
80 | }
