1 | C-Code
2 | #include <stdio.h>
3 | #include <string.h>
4 | #include "board.h"
5 | #include "sysclk.h"
6 | #include "exceptions.h"
7 | #include "uart.h"
8 | #include "pmc.h"
9 | #include "gpio.h"
10 | #include "can.h"
11 | #include "stdio_serial.h"
12 | #include "sn65hvd234.h"
13 | #include "conf_board.h"
14 | #include "conf_clock.h"
15 |
16 | //prototypes
17 | void showRegister(void);
18 |
19 |
20 | #define STRING_EOL "\r"
21 |
22 | #define STRING_HEADER "-- CAN Example --\r\n" \
23 | "-- "BOARD_NAME" --\r\n" \
24 | "-- Compiled: "__DATE__" "__TIME__" --"STRING_EOL
25 |
26 | #define CAN_MSG_TOGGLE_LED_0 0x11223344
27 | #define CAN_MSG_TOGGLE_LED_1 0xAABBCCDD
28 | #define CAN_MSG_DUMMY_DATA 0x55AAAA55
29 |
30 | /** CAN frame max data length */
31 | #define MAX_CAN_FRAME_DATA_LEN 8
32 |
33 | /** CAN0 Transceiver */
34 | sn65hvd234_ctrl_t can0_transceiver;
35 |
36 | /** CAN1 Transceiver */
37 | sn65hvd234_ctrl_t can1_transceiver;
38 |
39 | /** CAN0 Transfer mailbox structure */
40 | can_mb_conf_t can0_mailbox;
41 |
42 | /** CAN1 Transfer mailbox structure */
43 | can_mb_conf_t can1_mailbox;
44 |
45 | /** Receive status */
46 | volatile uint32_t g_ul_recv_status = 0;
47 | ]
48 |
49 | /**
50 | * \brief Default interrupt handler for CAN 1.
51 | */
52 |
53 | /*- - - - - - - - - - - - - - - - - - - - - - */
54 |
55 | void CAN1_Handler(void) // stellt sich tot
56 | {
57 | uint32_t ul_status;
58 | printf("\rDEBUG: \(1a\) in CAN1_Handler\r");
59 |
60 | ul_status = can_get_status(CAN1);
61 | printf("\rDEBUG: \(1a_a\) in CAN1_Handler\r");
62 | if (ul_status & GLOBAL_MAILBOX_MASK) {
63 | printf("\rDEBUG: \(1b\) in CAN1_Handler ul_status \& GLOBAL_MAILBOX_MASK\r");
64 | for (uint8_t i = 0; i < CANMB_NUMBER; i++) {
65 | ul_status = can_mailbox_get_status(CAN1, i);
66 | if ((ul_status & CAN_MSR_MRDY) == CAN_MSR_MRDY) {
67 | printf("\rDEBUG: \(1c\) in CAN1_Handler ul_status \& CAN_MSR_MRDY\r");
68 | can1_mailbox.ul_mb_idx = i;
69 | can1_mailbox.ul_status = ul_status;
70 | can_mailbox_read(CAN1, &can1_mailbox);
71 | g_ul_recv_status = 1;
72 | break;
73 | }
74 | }
75 | }
76 | }
77 | /*- - - - - - - - - - - - - - - - - - - - - - */
78 |
79 | /**
80 | * \brief Decode CAN messages.
81 | *
82 | * \param p_mailbox Pointer to CAN Mailbox structure.
83 | */
84 | static void decode_can_msg(can_mb_conf_t *p_mailbox)
85 | {
86 | int a;
87 | uint32_t ul_led_Ctrl = p_mailbox->ul_datal;
88 | if (p_mailbox->ul_datal == CAN_MSG_TOGGLE_LED_0) a=1;
89 |
90 |
91 | puts("CAN message:" STRING_EOL);
92 | if (ul_led_Ctrl == CAN_MSG_TOGGLE_LED_0) {
93 | puts(" Toggle LED 0" STRING_EOL);
94 | gpio_toggle_pin(LED0_GPIO); //PB27 PWM13 Arduino::13
95 | } else if (ul_led_Ctrl == CAN_MSG_TOGGLE_LED_1) {
96 | puts(" Toggle LED 1" STRING_EOL);
97 | gpio_toggle_pin(LED1_GPIO); //PC21 PWM9 Arduino::9
98 | }
99 | }
100 |
101 | /*- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - */
102 | /**
103 | * \brief Reset mailbox configure structure.
104 | *
105 | * \param p_mailbox Pointer to mailbox configure structure.
106 | */
107 | static void reset_mailbox_conf(can_mb_conf_t *p_mailbox)
108 | {
109 | p_mailbox->ul_mb_idx = 0;
110 | p_mailbox->uc_obj_type = 0;
111 | p_mailbox->uc_id_ver = 0;
112 | p_mailbox->uc_length = 0;
113 | p_mailbox->uc_tx_prio = 0;
114 | p_mailbox->ul_status = 0;
115 | p_mailbox->ul_id_msk = 0;
116 | p_mailbox->ul_id = 0;
117 | p_mailbox->ul_fid = 0;
118 | p_mailbox->ul_datal = 0;
119 | p_mailbox->ul_datah = 0;
120 | }
121 |
122 | #define TEST1_CAN_COMM_MB_IDX 0
123 | #define TEST1_CAN_TRANSFER_ID 0x07
124 | #define TEST1_CAN0_TX_PRIO 15
125 |
126 | /*- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - */
127 | /**
128 | * \brief Test the transmission from CAN0 Mailbox 0 to CAN1 Mailbox 0.
129 | */
130 | static void test_1(void)
131 | {
132 | can_reset_all_mailbox(CAN0);
133 | can_reset_all_mailbox(CAN1);
134 |
135 | printf("In Test1: CAN0 Mailbox 0 transmitting to CAN1 Mailbox 0\r");
136 |
137 |
138 |
139 | /* Init CAN1 Mailbox 0 to Reception Mailbox. */
140 | reset_mailbox_conf(&can1_mailbox);
141 | can1_mailbox.ul_mb_idx = TEST1_CAN_COMM_MB_IDX;
142 | can1_mailbox.uc_obj_type = CAN_MB_RX_MODE;
143 | can1_mailbox.ul_id_msk = CAN_MAM_MIDvA_Msk | CAN_MAM_MIDvB_Msk;
144 | can1_mailbox.ul_id = CAN_MID_MIDvA(TEST1_CAN_TRANSFER_ID);
145 | can_mailbox_init(CAN1, &can1_mailbox);
146 |
147 | /* Init CAN0 Mailbox 0 to Transmit Mailbox. */
148 | reset_mailbox_conf(&can0_mailbox);
149 | can0_mailbox.ul_mb_idx = TEST1_CAN_COMM_MB_IDX;
150 | can0_mailbox.uc_obj_type = CAN_MB_TX_MODE;
151 | can0_mailbox.uc_tx_prio = TEST1_CAN0_TX_PRIO;
152 | can0_mailbox.uc_id_ver = 0;
153 | can0_mailbox.ul_id_msk = 0;
154 | can_mailbox_init(CAN0, &can0_mailbox);
155 |
156 | /* Write transmit information into mailbox. */
157 | can0_mailbox.ul_id = CAN_MID_MIDvA(TEST1_CAN_TRANSFER_ID);
158 | can0_mailbox.ul_datal = CAN_MSG_TOGGLE_LED_0;
159 | can0_mailbox.ul_datah = CAN_MSG_DUMMY_DATA;
160 | can0_mailbox.uc_length = MAX_CAN_FRAME_DATA_LEN;
161 | can_mailbox_write(CAN0, &can0_mailbox);
162 |
163 | printf("DEBUG: Transmit information written into mailbox\r");
164 | //showRegister();
165 |
166 |
167 |
168 |
169 | /* Enable CAN1 mailbox 0 interrupt. */
170 | can_enable_interrupt(CAN1, CAN_IER_MB0);
171 |
172 | /* Send out the information in the mailbox. */
173 | can_global_send_transfer_cmd(CAN0, CAN_TCR_MB0);
174 |
175 | printf("\rDEBUG: \(1\) g_ul_recv_status = %d\r",g_ul_recv_status);
176 |
177 | //Ab hier passiert nix mehr weil Abarbeitung in Empfänger-ISR:
178 | while (!g_ul_recv_status); /////////////////////////////////////////////////////////////
179 |
180 | printf("DEBUG: \(2\) g_ul_recv_status = %d\r\r",g_ul_recv_status);
181 | printf("DEBUG: still in Test 1\r\r");
182 | if ((can1_mailbox.ul_datal == CAN_MSG_TOGGLE_LED_0) &&
183 | (can1_mailbox.uc_length == MAX_CAN_FRAME_DATA_LEN)) {
184 | puts("Test1 passed" STRING_EOL);
185 | decode_can_msg(&can1_mailbox);
186 | } else {
187 | puts("Test1 ERROR" STRING_EOL);
188 | }
189 | }
190 |
191 |
192 |
193 | /**
194 | * Configure UART for debug message output.
195 | */
196 | static void configure_console(void)
197 | {
198 | const usart_serial_options_t uart_serial_options = {
199 | .baudrate = CONF_UART_BAUDRATE,
200 | .paritytype = CONF_UART_PARITY
201 | };
202 |
203 | /* Configure console UART. */
204 | sysclk_enable_peripheral_clock(CONSOLE_UART_ID);
205 | stdio_serial_init(CONF_UART, &uart_serial_options);
206 | }
207 |
208 |
209 |
210 | /**
211 | * \brief can_example application entry point.
212 | *
213 | * \return Unused (ANSI-C compatibility).
214 | */
215 | int main(void)
216 | {
217 | uint32_t ul_sysclk;
218 | uint8_t uc_char;
219 |
220 | /* Initialize the SAM system. */
221 | sysclk_init();
222 | board_init();
223 |
224 | #ifdef CONF_BOARD_CAN0
225 | /* Configure the CAN0 TX and RX pins. */
226 | gpio_configure_pin(PIN_CAN0_RX_IDX, PIN_CAN0_RX_FLAGS);
227 | gpio_configure_pin(PIN_CAN0_TX_IDX, PIN_CAN0_TX_FLAGS);
228 | /* Configure the transceiver0 RS & EN pins. */
229 | gpio_configure_pin(PIN_CAN0_TR_RS_IDX, PIN_CAN0_TR_RS_FLAGS);
230 | gpio_configure_pin(PIN_CAN0_TR_EN_IDX, PIN_CAN0_TR_EN_FLAGS);
231 | #endif
232 |
233 | #ifdef CONF_BOARD_CAN1
234 | /* Configure the CAN1 TX and RX pin. */
235 | gpio_configure_pin(PIN_CAN1_RX_IDX, PIN_CAN1_RX_FLAGS);
236 | gpio_configure_pin(PIN_CAN1_TX_IDX, PIN_CAN1_TX_FLAGS);
237 | /* Configure the transceiver1 RS & EN pins. */
238 | gpio_configure_pin(PIN_CAN1_TR_RS_IDX, PIN_CAN1_TR_RS_FLAGS);
239 | gpio_configure_pin(PIN_CAN1_TR_EN_IDX, PIN_CAN1_TR_EN_FLAGS);
240 | #endif
241 |
242 |
243 |
244 |
245 |
246 | /* Configure UART for debug message output. */
247 | configure_console();
248 |
249 | /* Output example information. */
250 | puts(STRING_HEADER);
251 |
252 |
253 |
254 |
255 | //Test PB15 CAN1 RX
256 |
257 | while (0){
258 | // - - - - - - - - - - - - - - - - - - - - -
259 | //eine LED mit Taster einschalten, 01.03.2013
260 |
261 | pmc_enable_periph_clk(PIN_PUSHBUTTON_1_ID);
262 | pio_pull_up(PIN_PUSHBUTTON_1_PIO, PIN_PUSHBUTTON_1_MASK, PIO_PULLUP); //pmc_enable_periph_clk nicht vergessen!
263 |
264 | while (1) {
265 |
266 | if (!( pio_get(PIN_PUSHBUTTON_1_PIO, PIO_INPUT, PIN_PUSHBUTTON_1_MASK) ))
267 | gpio_set_pin_high(LED0_GPIO);
268 | else gpio_set_pin_low(LED0_GPIO);
269 | }
270 |
271 |
272 | // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
273 | }
274 |
275 |
276 |
277 |
278 |
279 |
280 |
281 | /* Initialize CAN0 Transceiver. */
282 | sn65hvd234_set_rs(&can0_transceiver, PIN_CAN0_TR_RS_IDX);
283 | sn65hvd234_set_en(&can0_transceiver, PIN_CAN0_TR_EN_IDX);
284 | /* Enable CAN0 Transceiver. */
285 | sn65hvd234_disable_low_power(&can0_transceiver);
286 | sn65hvd234_enable(&can0_transceiver);
287 |
288 | /* Initialize CAN1 Transceiver. */
289 | sn65hvd234_set_rs(&can1_transceiver, PIN_CAN1_TR_RS_IDX);
290 | sn65hvd234_set_en(&can1_transceiver, PIN_CAN1_TR_EN_IDX);
291 | /* Enable CAN1 Transceiver. */
292 | sn65hvd234_disable_low_power(&can1_transceiver);
293 | sn65hvd234_enable(&can1_transceiver);
294 |
295 | /* Enable CAN0 & CAN1 clock. */
296 | pmc_enable_periph_clk(ID_CAN0);
297 | pmc_enable_periph_clk(ID_CAN1);
298 |
299 | ul_sysclk = sysclk_get_cpu_hz();
300 | if (can_init(CAN0, ul_sysclk, CAN_BPS_1000K) && //1000K
301 | can_init(CAN1, ul_sysclk, CAN_BPS_1000K)) { //1000K
302 | puts("CAN initialization is completed." STRING_EOL);
303 |
304 | /* Disable all CAN0 & CAN1 interrupts. */
305 | can_disable_interrupt(CAN0, CAN_DISABLE_ALL_INTERRUPT_MASK);
306 | can_disable_interrupt(CAN1, CAN_DISABLE_ALL_INTERRUPT_MASK);
307 |
308 | /* Configure and enable interrupt of CAN1, as the tests will use receiver interrupt. */
309 | NVIC_EnableIRQ(CAN1_IRQn);
310 |
311 |
312 |
313 | /* Run tests. */
314 | //while (1) {
315 | // puts("Press any key to start test" STRING_EOL);
316 | // while (uart_read(CONSOLE_UART, &uc_char)) { };
317 | //}
318 |
319 | puts("Test1 beginnt" STRING_EOL);
320 | test_1();
321 | g_ul_recv_status = 0;
322 |
323 | puts("Test2 beginnt: Press any key to continue..."
324 | //...
325 | //... weitere Tests
326 |
327 | }
