1 | //Header einbinden
2 | #include <avr/io.h>
3 | #include <util/delay.h>
4 | #include <stdint.h>
5 | #include <avr/interrupt.h>
6 |
7 |
8 | //Prototypen der Funktionen
9 | void initialisiere_I2C (void);
10 | void sendeDaten_Master(unsigned char data);
11 | unsigned char empfangeDaten_Master(void);
12 | void sleep_ms (uint16_t ms);
13 |
14 | //Variable deklarieren
15 | volatile int master = 1;
16 | volatile int transmit = 1;
17 |
18 | volatile unsigned char data = 0xFF;
19 | char test;
20 |
21 | int SLA_W = 0x90; //0b10010000 -> SLA = 0x48 -> nach links shiften und 0/1 anhaengen
22 | int SLA_R = 0x91; //0b10010001
23 |
24 | //TWI Defines: TWI an Port C angeschlossen
25 | #define TWI_DDR DDRC
26 | #define TWI_PORT PORTC
27 | #define SCL PC0
28 | #define SDA PC1
29 |
30 | //TWI Defines: TWI an Port B angeschlossen
31 | #define Temp_DDR DDRB
32 | #define Temp_PORT PORTB
33 | #define EnTemp PB0
34 |
35 |
36 | int main(void)
37 | {
38 | //Ports als Ausgang setzen
39 | TWI_DDR |= (1 << SDA);
40 | TWI_DDR |= (1 << SCL);
41 |
42 | //Ports als Ausgang setzen
43 | Temp_DDR |= (1 << EnTemp);
44 |
45 | //Ports auf high setzen
46 | Temp_PORT &= ~(1<<EnTemp);
47 |
48 | initialisiere_I2C();
49 |
50 | //Interrupts aktivieren
51 | sei();
52 |
53 | if (master == 1)
54 | {
55 | if (transmit == 1)
56 | {
57 | sendeDaten_Master(0x00);
58 | }
59 | else
60 | {
61 | empfangeDaten_Master();
62 | }
63 | }
64 |
65 | while(1)
66 | {
67 | ; //leere Endlosschleife
68 | }
69 | }
70 | void initialisiere_I2C (void)
71 | {
72 | //Bit Rate 100,000kHz
73 | TWBR=0x20;
74 | //analog comparator initialisieren
75 | ACSR=0x80;
76 | //Schnittstelle aktivieren
77 | TWCR= (1<<TWIE)|(1<<TWEN);
78 | //Prescaler auf 1 --> TWSR = 0x0
79 | TWSR &= ~(1<<TWPS0);
80 | TWSR &= ~(1<<TWPS1);
81 | //SCL Frequenz = 250000
82 | }
83 |
84 |
85 | void sendeDaten_Master(unsigned char data)
86 | {
87 | //Start Condition senden
88 | TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN)|(1<<TWIE);
89 | }
90 | unsigned char empfangeDaten_Master(void)
91 | {
92 | //Start Condition senden
93 | TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN)|(1<<TWIE);
94 | return data;
95 | }
96 |
97 |
98 | ISR(TWI_vect)
99 | {
100 | if (master == 1)
101 | {
102 | if (transmit == 1)
103 | {
104 | switch (TWSR)
105 | {
106 | //Status pruefen -> START gesendet
107 | case 0x08:
108 | TWDR = SLA_W;
109 | //TWINT und TWEN setzen, Start und Stop loeschen
110 | TWCR = (1<<TWINT) | (1<<TWEN)|(1<<TWIE);
111 | break;
112 |
113 | //Status pruefen -> ACK (SLA+W) erhalten
114 | case 0x18:
115 | //Daten senden
116 | TWDR = data;
117 | TWCR = (1<<TWINT) | (1<<TWEN)| (1<<TWIE);
118 | break;
119 |
120 | //Status pruefen -> NACK (SLA+W) erhalten
121 | case 0x20:
122 | // ERROR(); -> Fehlermeldung
123 | test = 0x0;
124 | break;
125 |
126 | //Status pruefen -> ACK fuer Daten erhalten
127 | case 0x28:
128 | //Uebertragung beenden
129 | TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO)| (1<<TWIE);
130 | break;
131 |
132 | //Status pruefen -> NACK (Daten) erhalten
133 | case 0x30:
134 | // ERROR(); -> Fehlermeldung
135 | break;
136 | }
137 | } else if (transmit == 0)
138 | {
139 | switch (TWSR)
140 | {
141 | //Status pruefen -> START gesendet
142 | case 0x08:
143 | TWDR = SLA_R;
144 | TWCR = (1<<TWINT) | (1<<TWEN)| (1<<TWIE);
145 | break;
146 |
147 | //Status pruefen -> ACK (SLA+R) erhalten
148 | case 0x40:
149 | //Daten empfangen
150 | data = TWDR;
151 | TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWEA) | (1<<TWIE);
152 | break;
153 |
154 | //Status pruefen -> NACK (SLA+R) erhalten
155 | case 0x48:
156 | // ERROR(); -> Fehlermeldung
157 | break;
158 |
159 | //Status pruefen -> ACK fuer Daten erhalten
160 | case 0x50:
161 | //Uebertragung beenden
162 | TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
163 | break;
164 |
165 | //Status pruefen -> NACK (Daten) erhalten
166 | case 0x58:
167 | // ERROR(); -> Fehlermeldung
168 | break;
169 | }
170 | } else
171 | {
172 | // ERROR(); -> Fehlermeldung
173 | }
174 | }
175 | }
