1 | -- Listing 5.15
2 | library ieee;
3 | use ieee.std_logic_1164.all;
4 | use ieee.numeric_std.all;
5 | entity ch05_15_16_watch is
6 | port(
7 | clk: in std_logic;
8 | go, clr: in std_logic;
9 | d2, d1, d0: buffer std_logic_vector(3 downto 0)
10 | --bcd0, bcd1, bcd2: out std_logic_vector(6 downto 0)
11 |
12 | );
13 | end ch05_15_16_watch;
14 |
15 | architecture cascade_arch of ch05_15_16_watch is
16 | constant DVSR: integer:=5000000;
17 |
18 | component bin_to_sseg
19 | port(
20 | bin0: in std_logic_vector(3 downto 0);
21 | bin1: in std_logic_vector(3 downto 0);
22 | bin2: in std_logic_vector(3 downto 0);
23 | sseg0: out std_logic_vector(6 downto 0);
24 | sseg1: out std_logic_vector(6 downto 0);
25 | sseg2: out std_logic_vector(6 downto 0)
26 | );
27 | end component;
28 |
29 | signal ms_reg, ms_next: unsigned(22 downto 0);
30 | signal d2_reg, d1_reg, d0_reg: unsigned(3 downto 0);
31 | signal d2_next, d1_next, d0_next: unsigned(3 downto 0);
32 | signal d1_en, d2_en, d0_en: std_logic;
33 | signal ms_tick, d0_tick, d1_tick: std_logic;
34 | signal bin0, bin1, bin2 : std_logic_vector(3 downto 0);
35 | begin
36 | -- register
37 | process(clk)
38 | begin
39 | if (clk'event and clk='1') then
40 | ms_reg <= ms_next;
41 | d2_reg <= d2_next;
42 | d1_reg <= d1_next;
43 | d0_reg <= d0_next;
44 | end if;
45 | end process;
46 |
47 | -- next-state logic
48 | -- 0.1 sec tick generator: mod-5000000
49 | ms_next <=
50 | (others=>'0') when clr='1' or
51 | (ms_reg=DVSR and go='1') else
52 | ms_reg + 1 when go='1' else
53 | ms_reg;
54 | ms_tick <= '1' when ms_reg=DVSR else '0';
55 | -- 0.1 sec counter
56 | d0_en <= '1' when ms_tick='1' else '0';
57 | d0_next <=
58 | "0000" when (clr='1') or (d0_en='1' and d0_reg=9) else
59 | d0_reg + 1 when d0_en='1' else
60 | d0_reg;
61 | d0_tick <= '1' when d0_reg=9 else '0';
62 | -- 1 sec counter
63 | d1_en <= '1' when ms_tick='1' and d0_tick='1' else '0';
64 | d1_next <=
65 | "0000" when (clr='1') or (d1_en='1' and d1_reg=9) else
66 | d1_reg + 1 when d1_en='1' else
67 | d1_reg;
68 | d1_tick <= '1' when d1_reg=9 else '0';
69 | -- 10 sec counter
70 | d2_en <=
71 | '1' when ms_tick='1' and d0_tick='1' and d1_tick='1' else
72 | '0';
73 | d2_next <=
74 | "0000" when (clr='1') or (d2_en='1' and d2_reg=9) else
75 | d2_reg + 1 when d2_en='1' else
76 | d2_reg;
77 |
78 | -- output logic
79 | d0 <= std_logic_vector(d0_reg);
80 | d1 <= std_logic_vector(d1_reg);
81 | d2 <= std_logic_vector(d2_reg);
82 |
83 | bin0 <= d0;
84 | bin1 <= d1;
85 | bin2 <= d2;
86 |
87 | binary_unit : entity work.bin_to_sseg
88 | port map(bin0 => bin0, bin1 => bin1, bin2 => bin2);
89 | -- bcd_unit : entity work.bin_to_sseg
90 | -- port map(sseg0 => bcd0, sseg1 => bcd1, sseg2 => bcd2);
91 |
92 |
93 | end cascade_arch;
94 |
95 |
96 | -- Listing 4.12
97 | library ieee;
98 | use ieee.std_logic_1164.all;
99 | entity bin_to_sseg is
100 | port(
101 | bin0: in std_logic_vector(3 downto 0);
102 | bin1: in std_logic_vector(3 downto 0);
103 | bin2: in std_logic_vector(3 downto 0);
104 | sseg0: out std_logic_vector(6 downto 0);
105 | sseg1: out std_logic_vector(6 downto 0);
106 | sseg2: out std_logic_vector(6 downto 0)
107 | );
108 | end bin_to_sseg;
109 |
110 | architecture arch of bin_to_sseg is
111 | begin
112 | with bin0 select
113 | sseg0 <=
114 | "1000000" when "0000",
115 | "1111001" when "0001",
116 | "0100100" when "0010",
117 | "0110000" when "0011",
118 | "0011001" when "0100",
119 | "0010010" when "0101",
120 | "0000010" when "0110",
121 | "1111000" when "0111",
122 | "0000000" when "1000",
123 | "0010000" when "1001",
124 | "0001000" when "1010", --a
125 | "0000011" when "1011", --b
126 | "1000110" when "1100", --c
127 | "0100001" when "1101", --d
128 | "0000110" when "1110", --e
129 | "0001110" when others; --f
130 |
131 | with bin1 select
132 | sseg1 <=
133 | "1000000" when "0000",
134 | "1111001" when "0001",
135 | "0100100" when "0010",
136 | "0110000" when "0011",
137 | "0011001" when "0100",
138 | "0010010" when "0101",
139 | "0000010" when "0110",
140 | "1111000" when "0111",
141 | "0000000" when "1000",
142 | "0010000" when "1001",
143 | "0001000" when "1010", --a
144 | "0000011" when "1011", --b
145 | "1000110" when "1100", --c
146 | "0100001" when "1101", --d
147 | "0000110" when "1110", --e
148 | "0001110" when others; --f
149 |
150 |
151 | with bin2 select
152 | sseg2 <=
153 | "1000000" when "0000",
154 | "1111001" when "0001",
155 | "0100100" when "0010",
156 | "0110000" when "0011",
157 | "0011001" when "0100",
158 | "0010010" when "0101",
159 | "0000010" when "0110",
160 | "1111000" when "0111",
161 | "0000000" when "1000",
162 | "0010000" when "1001",
163 | "0001000" when "1010", --a
164 | "0000011" when "1011", --b
165 | "1000110" when "1100", --c
166 | "0100001" when "1101", --d
167 | "0000110" when "1110", --e
168 | "0001110" when others; --f
169 | end arch;
