1 | #include "msp430.h"
2 |
3 | #define LCM_DIR P2DIR
4 | #define LCM_OUT P2OUT
5 |
6 | //
7 |
8 | #define LCM_PIN_RS BIT0 // P2.0
9 | #define LCM_PIN_EN BIT1 // P2.1
10 | #define LCM_PIN_D7 BIT5 // P2.5
11 | #define LCM_PIN_D6 BIT4 // P2.4
12 | #define LCM_PIN_D5 BIT3 // P2.3
13 | #define LCM_PIN_D4 BIT2 // P2.2
14 |
15 |
16 |
17 | #define LCM_PIN_MASK ((LCM_PIN_RS | LCM_PIN_EN | LCM_PIN_D7 |
18 | LCM_PIN_D6 | LCM_PIN_D5 | LCM_PIN_D4))
19 |
20 | #define FALSE 0
21 | #define TRUE 1
22 |
23 | //
24 | // Routine Desc:
25 | //
26 | // This is the function that must be called
27 | // whenever the LCM needs to be told to
28 | // scan it's data bus.
29 | //
30 | // Parameters:
31 | //
32 | // void.
33 | //
34 | // Return
35 | //
36 | // void.
37 | //
38 | void PulseLcm()
39 | {
40 | //
41 | // pull EN bit low
42 | //
43 | LCM_OUT &= ~LCM_PIN_EN;
44 | __delay_cycles(200);
45 |
46 | //
47 | // pull EN bit high
48 | //
49 | LCM_OUT |= LCM_PIN_EN;
50 | __delay_cycles(200);
51 |
52 | //
53 | // pull EN bit low again
54 | //
55 | LCM_OUT &= (~LCM_PIN_EN);
56 | __delay_cycles(200);
57 | }
58 |
59 |
60 |
61 | //
62 | // Routine Desc:
63 | //
64 | // Send a byte on the data bus in the 4 bit mode
65 | // This requires sending the data in two chunks.
66 | // The high nibble first and then the low nible
67 | //
68 | // Parameters:
69 | //
70 | // ByteToSend - the single byte to send
71 | //
72 | // IsData - set to TRUE if the byte is character data
73 | // FALSE if its a command
74 | //
75 | // Return
76 | //
77 | // void.
78 | //
79 | void SendByte(char ByteToSend, int IsData)
80 | {
81 | //
82 | // clear out all pins
83 | //
84 | LCM_OUT &= (~LCM_PIN_MASK);
85 | //
86 | // set High Nibble (HN) -
87 | // usefulness of the identity mapping
88 | // apparent here. We can set the
89 | // DB7 - DB4 just by setting P1.7 - P1.4
90 | // using a simple assignment
91 | //
92 | LCM_OUT |= (ByteToSend & 0x3C);
93 |
94 | if (IsData == TRUE)
95 | {
96 | LCM_OUT |= LCM_PIN_RS;
97 | }
98 | else
99 | {
100 | LCM_OUT &= ~LCM_PIN_RS;
101 | }
102 |
103 | //
104 | // we've set up the input voltages to the LCM.
105 | // Now tell it to read them.
106 | //
107 | PulseLcm();
108 | //
109 | // set Low Nibble (LN) -
110 | // usefulness of the identity mapping
111 | // apparent here. We can set the
112 | // DB7 - DB4 just by setting P1.7 - P1.4
113 | // using a simple assignment
114 | //
115 | LCM_OUT &= (~LCM_PIN_MASK);
116 | LCM_OUT |= ((ByteToSend & 0x0F) << 4);
117 |
118 | if (IsData == TRUE)
119 | {
120 | LCM_OUT |= LCM_PIN_RS;
121 | }
122 | else
123 | {
124 | LCM_OUT &= ~LCM_PIN_RS;
125 | }
126 |
127 | //
128 | // we've set up the input voltages to the LCM.
129 | // Now tell it to read them.
130 | //
131 | PulseLcm();
132 | }
133 |
134 |
135 | //
136 | // Routine Desc:
137 | //
138 | // Set the position of the cursor on the screen
139 | //
140 | // Parameters:
141 | //
142 | // Row - zero based row number
143 | //
144 | // Col - zero based col number
145 | //
146 | // Return
147 | //
148 | // void.
149 | //
150 | void LcmSetCursorPosition(char Row, char Col)
151 | {
152 | char address;
153 |
154 | //
155 | // construct address from (Row, Col) pair
156 | //
157 | if (Row == 0)
158 | {
159 | address = 0;
160 | }
161 | else
162 | {
163 | address = 0x40;
164 | }
165 |
166 | address |= Col;
167 |
168 | SendByte(0x80 | address, FALSE);
169 | }
170 |
171 |
172 | //
173 | // Routine Desc:
174 | //
175 | // Clear the screen data and return the
176 | // cursor to home position
177 | //
178 | // Parameters:
179 | //
180 | // void.
181 | //
182 | // Return
183 | //
184 | // void.
185 | //
186 | void ClearLcmScreen()
187 | {
188 | //
189 | // Clear display, return home
190 | //
191 | SendByte(0x01, FALSE);
192 | SendByte(0x02, FALSE);
193 | }
194 |
195 |
196 | //
197 | // Routine Desc:
198 | //
199 | // Initialize the LCM after power-up.
200 | //
201 | // Note: This routine must not be called twice on the
202 | // LCM. This is not so uncommon when the power
203 | // for the MCU and LCM are separate.
204 | //
205 | // Parameters:
206 | //
207 | // void.
208 | //
209 | // Return
210 | //
211 | // void.
212 | //
213 | void InitializeLcm(void)
214 | {
215 | //
216 | // set the MSP pin configurations
217 | // and bring them to low
218 | //
219 | LCM_DIR |= LCM_PIN_MASK;
220 | LCM_OUT &= ~(LCM_PIN_MASK);
221 |
222 |
223 | //
224 | // wait for the LCM to warm up and reach
225 | // active regions. Remember MSPs can power
226 | // up much faster than the LCM.
227 | //
228 | __delay_cycles(100000);
229 |
230 |
231 | //
232 | // initialize the LCM module
233 | //
234 | // 1. Set 4-bit input
235 | //
236 | LCM_OUT &= ~LCM_PIN_RS;
237 | LCM_OUT &= ~LCM_PIN_EN;
238 |
239 | LCM_OUT = 0x20;
240 | PulseLcm();
241 |
242 | //
243 | // set 4-bit input - second time.
244 | // (as reqd by the spec.)
245 | //
246 | SendByte(0x28, FALSE);
247 |
248 | //
249 | // 2. Display on, cursor on, blink cursor
250 | //
251 | SendByte(0x0E, FALSE);
252 |
253 | //
254 | // 3. Cursor move auto-increment
255 | //
256 | SendByte(0x06, FALSE);
257 | }
258 |
259 |
260 | //
261 | // Routine Desc
262 | //
263 | // Print a string of characters to the screen
264 | //
265 | // Parameters:
266 | //
267 | // Text - null terminated string of chars
268 | //
269 | // Returns
270 | //
271 | // void.
272 | //
273 | void PrintStr(char *Text)
274 | {
275 | char *c;
276 |
277 | c = Text;
278 |
279 | while ((c != 0) && (*c != 0))
280 | {
281 | SendByte(*c, TRUE);
282 | c++;
283 | }
284 | }
285 |
286 |
287 | //
288 | // Routine Desc
289 | //
290 | // main entry point to the sketch
291 | //
292 | // Parameters
293 | //
294 | // void.
295 | //
296 | // Returns
297 | //
298 | // void.
299 | //
300 | void main(void)
301 | {
302 | WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
303 |
304 | InitializeLcm();
305 |
306 | ClearLcmScreen();
307 |
308 | PrintStr("Hello World!");
309 |
310 | while (1)
311 | {
312 | __delay_cycles(1000);
313 | }
314 |
315 | }
