Artikel auf embdev.net meldet fehler "Error creating thumbnail"
OP Persönliche Seite #3236125
wenn ich den Artikel
http://embdev.net/articles/Tekway_MSO
aufrufe scheint die formatierung seltsam zu sein, dazu fehlen alle
Bilder. Stattdessen steht da ein Fehler:
Error creating thumbnail: Unable to save thumbnail to destination
Getestet als user/anon mit IE und Firefox.
(Firma: Nisch-Aufzüge) Persönliche Seite #3236247
wer lesen kann...
Error creating thumbnail: Unable to save thumbnail to destination  In
case the u-boot didn't downloaded anything it will still erase
  the Boot block and of course itself from NAND memory
  If so, the MSO will be unable to boot the next time you power cycle
it!
  Therefore, in case there was transmition error, simply try again to
  transfer the supervivi.bin. If necessary reboot PC - not MSO - or
  reconnect the USB cable.
 - when ready, power cycle the MSO. While booting the MSO up try
multiple times
  to hit space key, if the boot process have not stopped at following
screen
  power off MSO and try again until you see supervivi bootloader prompt:
Error creating thumbnail: Unable to save thumbnail to destination- if
so, type menu and hit Enter to see following supervivi menu:
Error creating thumbnail: Unable to save thumbnail to destinationError
- type in the supervivi bootloader menu "r" - this means restore,
immediately
  after choose in the dnw.exe menu "Usb Port->Transmit/Restore" and
select
  the fw_backup.bin file.
  NOTE: if you need too long for these steps dnw.exe and/or supervivi
will
  timeout here. Try then again. You should see now in the dnw.exe and
your
  terminal application the transfer/flashing progress:
creating thumbnail: Unable to save thumbnail to destinationAfter the
supervivi bootloader programmed the NAND with the fw_backup.bin file the
menu will be displayed again, just scroll back to see the flashing
status, here my example (note, my NAND have one bad block, not a big
deal):
Error creating thumbnail: Unable to save thumbnail to destination- when
ready remove the USB/UART cables, close dnw.exe and reboot MSO.
That's all, the DSO firmware has been restored and your MSO converted
back into DSO.
OP Persönliche Seite #3236288
Winfried J. schrieb:
> wer lesen kann...
das kann ich schon, ich mache dir aber ganz einfach.
Geh auf http://www.mikrocontroller.net/articles/Tekway_MSO
da sind jede menge bilder, in dem artikel hier
sind die aber weg
Du kannst auch "Edit" anklicken, dann wirst du auch die links zu den
bildern sehen, trotzdem sieht man die nicht und statt den bildern die
oben zitierte fehler mitten drin im artikel erscheint.
