1 | void Init_Key_Port()
2 | {
3 | /* All Ports input of the matrix keyboard */
4 | DDRE = ( (0<<DDE7) | (0<<DDE6) | (0<<DDE5) | (0<<DDE4));
5 | DDRD = ( (0<<DDD7) | (0<<DDD4) );
6 | DDRG = ( (0<<DDG3) | (0<<DDG0) );
7 | /* Pullup resistance active for keyboard ports*/
8 | PORTE = ( (1<<PE7) | (1<<PE6) | (1<<PE5) | (1<<PE4));
9 | PORTD = ( (1<<PD7) | (1<<PD4) );
10 | PORTG = ( (1<<PG3) | (1<<PG0) );
11 | }
12 |
13 | char key_press(int pos, int site)
14 | {
15 | cli();
16 | char number=0;
17 | int keycode, keyflag = 4;
18 | Init_Key_Port(); // make sure all keyboard ports are initialized
19 |
20 | /* check line D */
21 | PORTD = (0<<PD4); // PORT D4 at pullup desactive
22 | DDRD = (1<<DDD4); // PORT D4 in input
23 | keycode = 0x08 &0x0F; // line code
24 | /* check column */
25 | if ((PINE &(1<<PINE7)) == 0) ; // faking condition
26 | else if ((PINE &(1<<PINE5)) == 0) keycode += 0x10 &0xF0;
27 | else if ((PINE &(1<<PINE4)) == 0) keycode += 0x20 &0xF0;
28 | else if ((PINE &(1<<PINE6)) == 0) keycode += 0x40 &0xF0;
29 | else keyflag --;
30 | PORTD = (1<<PD4); // PORT D4 at pullup active
31 | DDRD = (0<<DDD4); // PORT D4 in output
32 |
33 | if (keyflag == 3)
34 | {
35 | /* check line C */
36 | PORTD = (0<<PD7); // PORT D7 at pullup desactive
37 | DDRD = (1<<DDD7); // PORT D7 in input
38 | keycode = 0x04 &0x0F; // line code
39 | /* check column */
40 | if ((PINE &(1<<PINE7)) == 0) ; // faking condition
41 | else if ((PINE &(1<<PINE5)) == 0) keycode += 0x10 &0xF0;
42 | else if ((PINE &(1<<PINE4)) == 0) keycode += 0x20 &0xF0;
43 | else if ((PINE &(1<<PINE6)) == 0) keycode += 0x40 &0xF0;
44 | else keyflag --;
45 | PORTD = (1<<PD7); // PORT D7 at pullup active
46 | DDRD = (0<<DDD7); // PORT D7 in output
47 | }
48 |
49 | if (keyflag == 2)
50 | {
51 | /* check line B */
52 | PORTG = (0<<PG0); // PORT G0 at pullup desactive
53 | DDRG = (1<<DDG0); // PORT G0 in input
54 | keycode = 0x02 &0x0F; // line code
55 | /* check column */
56 | if ((PINE &(1<<PINE7)) == 0) ; // faking condition
57 | else if ((PINE &(1<<PINE5)) == 0) keycode += 0x10 &0xF0;
58 | else if ((PINE &(1<<PINE4)) == 0) keycode += 0x20 &0xF0;
59 | else if ((PINE &(1<<PINE6)) == 0) keycode += 0x40 &0xF0;
60 | else keyflag --;
61 | PORTG = (1<<PG0); // PORT G0 at pullup active
62 | DDRG = (0<<DDG0); // PORT G0 in output
63 | }
64 |
65 | if (keyflag == 1)
66 | {
67 | /* check line A */
68 | PORTG = (0<<PG3); // PORT G3 at pullup desactive
69 | DDRG = (1<<DDG3); // PORT G3 in input
70 | keycode = 0x01 &0x0F; // line code
71 | /* check column */
72 | if ((PINE &(1<<PINE7)) == 0) ; // faking condition
73 | else if ((PINE &(1<<PINE5)) == 0) keycode += 0x10 &0xF0;
74 | else if ((PINE &(1<<PINE4)) == 0) keycode += 0x20 &0xF0;
75 | else if ((PINE &(1<<PINE6)) == 0) keycode += 0x40 &0xF0;
76 | else keyflag --;
77 | PORTG = (1<<PG3); // PORT G3 at pullup active
78 | DDRG = (0<<DDG3); // PORT G3 in output
79 | }
80 |
81 | /* Switch table which return the value of the pressed key */
82 | /****************************************************************************/
83 | /* Change the following code lines to attribute some action for each button */
84 | /****************************************************************************/
85 | switch (keycode)
86 | {
87 | case 0x21 : number = '0';
88 | break;
89 | case 0x18 : number = '1';
90 | break;
91 | case 0x28 : number = '2';
92 | up();
93 | break;
94 | case 0x48 : number = '3';
95 | break;
96 | case 0x14 : number = '4';
97 | break;
98 | case 0x24 : number = '5';
99 | break;
100 | case 0x44 : number = '6';
101 | break;
102 | case 0x12 : number = '7';
103 | Test_Interrupt();
104 | break;
105 | case 0x22 : number = '8';
106 | down();
107 | break;
108 | case 0x42 : number = '9';
109 | break;
110 | case 0x00 : number = 'N';
111 | break;
112 | case 0x81 : number = 'S';
113 |
114 | break;
115 | case 0x41 : number = 'E';
116 | break;
117 | }
118 |
119 | /* Interrupt Ports input */
120 | DDRE = ( (0<<DDE7) | (0<<DDE6) | (0<<DDE5) | (0<<DDE4));
121 | /* Ports output */
122 | DDRD = ( (1<<DDD7) | (1<<DDD4) );
123 | DDRG = ( (1<<DDG3) | (1<<DDG0) );
124 | /* Pullup resistance Interrupt Ports active */
125 | PORTE = ( (1<<PE7) | (1<<PE6) | (1<<PE5) | (1<<PE4));
126 | /* Pullup resistance output Ports inactive */
127 | PORTD = ( (0<<PD7) | (0<<PD4) );
128 | PORTG = ( (0<<PG3) | (0<<PG0) );
129 | sei();
130 | return number;
131 | }
