1 | -- PI Control Process
2 | PiCtrl_pro: PROCESS(clk, reset_n) IS
3 | BEGIN
4 | if reset_n = '0' then -- asyn reset_n
5 | yout_sat_reg <= (others=> '0');
6 | Ki_Mantise_reg <= (others=> '0');
7 | Kp_expopnet_reg <= (others=> '0');
8 | Ki_exp_reg <= (others=> '0');
9 | ysum_reg <= (others=> '0');
10 | yi_alt <= (others=> '0');
11 | start_delay <= (others=> '0');
12 | op1_reg <= (others=> '0');
13 | op2_reg <= (others=> '0');
14 | -- ...
15 | elsif rising_edge(clk) then
16 | -- start: los!
17 | if ( start = '1' ) then -- Uebernahme gueltige Daten
18 | start_delay(0) <= '1';
19 | op1_reg <= Kp_mantise_inp;
20 | Kp_exponent_reg <= Kp_exponent_inp;
21 | Ki_exponent_reg <= Ki_exponent_inp;
22 | Ki_mantise_reg <= Ki_mantise_inp;
23 | else
24 | start_delay(0) <= '0';
25 | end if;
26 |
27 | -- clock enable Vorbereiten
28 | if start_delay(1) = '1' then start_delay(2) <= '1'; else start_delay(2) <= '0';end if ;
29 | if start_delay(2) = '1' then start_delay(3) <= '1'; else start_delay(3) <= '0';end if ;
30 | if start_delay(3) = '1' then start_delay(4) <= '1'; else start_delay(4) <= '0';end if ;
31 | if start_delay(4) = '1' then start_delay(5) <= '1'; else start_delay(5) <= '0';end if ;
32 | if start_delay(5) = '1' then start_delay(6) <= '1'; else start_delay(6) <= '0';end if ;
33 | if start_delay(6) = '1' then start_delay(7) <= '1'; else start_delay(7) <= '0';end if ;
34 | if start_delay(7) = '1' then start_delay(8) <= '1'; else start_delay(8) <= '0';end if ;
35 | if start_delay(8) = '1' then start_delay(9) <= '1'; else start_delay(9) <= '0';end if ;
36 | if start_delay(9) = '1' then start_delay(10)<= '1'; else start_delay(10) <= '0';end if ;
37 |
38 | -- Delay 1 Clock nach "Start"
39 | if start_delay(0) = '1' then
40 | start_delay(1) <= '1';
41 | AbsKpExp_r <= AbsKpExp_s;
42 | AbsKiExp_r <= AbsKiExp_s;
43 | else
44 | start_delay(1) <= '0';
45 | end if ;
46 | -- Regelabweichung mit Überlauf check und Korrektur
47 | if start_delay(1) = '1' then op2_reg <= DeltaMitOVcheck_s; end if;
48 | -- (kp_mantise * delta)
49 | if start_delay(2) = '1' then yp1_reg <= i32Tmp_s; end if; -- yp1_reg = DeltaMitOVcheck_s * Kp_mantise_inp
50 | -- mux
51 | if start_delay(3) = '1' then op1_reg <= Ki_man_reg; end if;
52 | -- ...
53 | -- ...
54 | -- "done" nach 12 Clock
55 | if start_delay(10) = '1' then
56 | done <= '1';
57 | y_out <= y_sat_tmp;
58 | else
59 | done <= '0';
60 | end if;
61 | end process;
62 |
63 | -- Absolutwertsbildung
64 | AbsKpExp_s <= Kp_exponent_reg when Kp_exponent_reg(15) = '0' else - Kp_exponent_reg;
65 | AbsKiExp_s <= Ki_exponent_reg when Ki_exponent_reg(15) = '0' else - Ki_exponent_reg;
66 |
67 | -- gemeinsame Multiplikation: (delta * Kp_mantise) oder (delta * Ki_mantise)
68 | i32Tmp_s <= op1_reg * op2_reg;
69 |
70 | -- Regelabweichung mit Überlauf check und Korrektur
71 | DeltaMitOVcheck_s <= OV_SUB16(ref_inp, act_inp); -- (ref - act)
72 |
73 | -- ..
74 | -- ..
75 | -- ..
