1 | /*
2 | * File: main.c
3 | * Author: Lena
4 | *
5 | * Created on 4. August 2013, 23:25
6 | */
7 | // PIC18F2523 Configuration Bit Settings
8 |
9 | #include <xc.h>
10 |
11 | // CONFIG1H
12 | #pragma config OSC = HS // Oscillator Selection bits (HS oscillator)
13 | #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
14 | #pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
15 |
16 | // CONFIG2L
17 | #pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
18 | #pragma config BOREN = SBORDIS // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
19 | #pragma config BORV = 3 // Brown Out Reset Voltage bits (Minimum setting)
20 |
21 | // CONFIG2H
22 | #pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
23 | #pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
24 |
25 | // CONFIG3H
26 | #pragma config CCP2MX = PORTC // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
27 | #pragma config PBADEN = ON // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
28 | #pragma config LPT1OSC = OFF // Low-Power Timer1 Oscillator Enable bit (Timer1 configured for higher power operation)
29 | #pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
30 |
31 | // CONFIG4L
32 | #pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
33 | #pragma config LVP = ON // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
34 | #pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
35 |
36 | // CONFIG5L
37 | #pragma config CP0 = OFF // Code Protection bit (Block 0 (000800-001FFFh) not code-protected)
38 | #pragma config CP1 = OFF // Code Protection bit (Block 1 (002000-003FFFh) not code-protected)
39 | #pragma config CP2 = OFF // Code Protection bit (Block 2 (004000-005FFFh) not code-protected)
40 | #pragma config CP3 = OFF // Code Protection bit (Block 3 (006000-007FFFh) not code-protected)
41 |
42 | // CONFIG5H
43 | #pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
44 | #pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
45 |
46 | // CONFIG6L
47 | #pragma config WRT0 = OFF // Write Protection bit (Block 0 (000800-001FFFh) not write-protected)
48 | #pragma config WRT1 = OFF // Write Protection bit (Block 1 (002000-003FFFh) not write-protected)
49 | #pragma config WRT2 = OFF // Write Protection bit (Block 2 (004000-005FFFh) not write-protected)
50 | #pragma config WRT3 = OFF // Write Protection bit (Block 3 (006000-007FFFh) not write-protected)
51 |
52 | // CONFIG6H
53 | #pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
54 | #pragma config WRTB = OFF // Boot Block Write Protection bit (Boot block (000000-0007FFh) not write-protected)
55 | #pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
56 |
57 | // CONFIG7L
58 | #pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000800-001FFFh) not protected from table reads executed in other blocks)
59 | #pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (002000-003FFFh) not protected from table reads executed in other blocks)
60 | #pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (004000-005FFFh) not protected from table reads executed in other blocks)
61 | #pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (006000-007FFFh) not protected from table reads executed in other blocks)
62 |
63 | // CONFIG7H
64 | #pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) not protected from table reads executed in other blocks)
65 |
66 |
67 |
68 |
69 | #define LED LATAbits.LA4
70 | #define LED2 LATCbits.LC0
71 |
72 | int led_state = 0;
73 |
74 | void delay( int ms );
75 |
76 | //Zeitverzögerung
77 | void delay( int ms ) {
78 | int i=0;
79 | //1 ms = 4000 Befehlstakte (16 MHz Quarz / 4)
80 | for( i=0; i<ms; i++ ) {
81 | _delay(4000);
82 | }
83 | }
84 |
85 | //void interrupt isr_high(void);
86 |
87 | void interrupt isr_high(void) {
88 | if(led_state == 0)
89 | {
90 | LED = 1;
91 | led_state = 1;
92 | } else {
93 | LED = 0;
94 | led_state = 0;
95 | }
96 | INTCONbits.INT0F = 0;
97 | INTCON3bits.INT2F = 0;
98 | }
99 |
100 |
101 | void main(void) {
102 |
103 |
104 |
105 | //Port A
106 | LATA = 0x00; //Pegel
107 | TRISA = 0x00; //Alle Pins von Port A sind Ausgänge
108 | // ANSELA = 0x00; //Alle Pins von Port A sind digitale I/O's
109 | //Port B
110 | LATB = 0x00;
111 | TRISB = 0xFF; //Alle Pins von Port B sind Eingänge
112 | // ANSELB = 0x00; //Alle Pins von Port A sind digitale I/O's
113 | //Port C
114 | LATC = 0x00;
115 | TRISC = 0xF0; //RC0..RC3 = Ausgänge, RC4..RC7 = Eingänge
116 | // ANSELC = 0x30; //nur RC4 und RC5 sind analoge Eingänge
117 |
118 | RCONbits.IPEN = 1; //Interrupts können Prioritäten haben
119 | INTCONbits.GIE_GIEH = 1; //Interrupts können hohe P. haben
120 | INTCONbits.GIEL = 1;
121 | INTCONbits.INT0IE = 1;
122 | INTCON3bits.INT2IE = 1;
123 | INTCON2bits.INTEDG0 = 1; //Interrupt on rising edge
124 | INTCON2bits.INTEDG2 = 1; //Interrupt on rising edge
125 | INTCON3bits.INT2IP = 1;
126 |
127 |
128 |
129 | while(1)
130 | {
131 | if(INTCON3bits.INT2F == 0) LED2 = 1;
132 | delay(20);
133 | LED2 = 0;
134 | delay(20);
135 | }
136 |
137 |
138 |
139 | }
