1 | !SESSION 2013-08-09 14:21:46.829 -----------------------------------------------
2 | eclipse.buildId=4.3.0.I20130530-1430
3 | java.version=1.7.0_21
4 | java.vendor=Oracle Corporation
5 | BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
6 | Framework arguments: -product org.eclipse.platform.ide
7 | Command-line arguments: -product org.eclipse.platform.ide -data C:\Users\Mike\workspace/../runtime-EclipseApplication -dev file:C:/Users/Mike/workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
8 |
9 | !ENTRY org.eclipse.ui.workbench 4 2 2013-08-09 14:21:50.017
10 | !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
11 | !STACK 0
12 | java.lang.NullPointerException
13 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.getLastMigration(MigrationSupport.java:222)
14 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.baseChangedSinceLastPresentationOfWizard(MigrationSupport.java:183)
15 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.performMigration(MigrationSupport.java:69)
16 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler.earlyStartup(AutomaticUpdateScheduler.java:89)
17 | at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
18 | at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
19 | at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
20 | at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2552)
21 | at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
22 |
23 | !ENTRY org.eclipse.ui.workbench 4 2 2013-08-09 14:21:50.017
24 | !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
25 | !STACK 0
26 | java.lang.NullPointerException
27 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.getLastMigration(MigrationSupport.java:222)
28 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.baseChangedSinceLastPresentationOfWizard(MigrationSupport.java:183)
29 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.performMigration(MigrationSupport.java:69)
30 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler.earlyStartup(AutomaticUpdateScheduler.java:89)
31 | at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
32 | at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
33 | at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
34 | at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2552)
35 | at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
36 |
37 | !ENTRY org.eclipse.ui 4 0 2013-08-09 14:21:50.017
38 | !MESSAGE Error occurred during status handling
39 | !STACK 0
40 | java.lang.NullPointerException
41 | at org.eclipse.ui.internal.statushandlers.StatusHandlerRegistry.<init>(StatusHandlerRegistry.java:72)
42 | at org.eclipse.ui.internal.statushandlers.StatusHandlerRegistry.getDefault(StatusHandlerRegistry.java:91)
43 | at org.eclipse.ui.statushandlers.StatusManager.getStatusHandler(StatusManager.java:135)
44 | at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:189)
45 | at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:231)
46 | at org.eclipse.ui.statushandlers.StatusManager$StatusManagerLogListener.logging(StatusManager.java:305)
47 | at org.eclipse.core.internal.runtime.RuntimeLog.logToListeners(RuntimeLog.java:160)
48 | at org.eclipse.core.internal.runtime.PlatformLogWriter.logged(PlatformLogWriter.java:100)
49 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.safeLogged(ExtendedLogReaderServiceFactory.java:86)
50 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:205)
51 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:178)
52 | at org.eclipse.equinox.log.internal.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
53 | at org.eclipse.equinox.log.internal.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
54 | at org.eclipse.equinox.log.internal.LoggerImpl.log(LoggerImpl.java:54)
55 | at org.eclipse.core.internal.runtime.PlatformLogWriter.logging(PlatformLogWriter.java:43)
56 | at org.eclipse.core.internal.runtime.RuntimeLog.log(RuntimeLog.java:96)
57 | at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:71)
58 | at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:44)
59 | at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2552)
60 | at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
61 |
62 | !ENTRY org.eclipse.ui 4 4 2013-08-09 14:21:50.033
63 | !MESSAGE Unhandled Exception
64 |
65 | !ENTRY org.eclipse.ui 4 4 2013-08-09 14:21:50.033
66 | !MESSAGE Unhandled Exception
67 |
68 | !ENTRY org.eclipse.ui 4 0 2013-08-09 14:21:50.033
69 | !MESSAGE Error occurred during status handling
70 | !STACK 0
71 | java.lang.NullPointerException
72 | at org.eclipse.ui.internal.statushandlers.StatusHandlerRegistry.<init>(StatusHandlerRegistry.java:72)
73 | at org.eclipse.ui.internal.statushandlers.StatusHandlerRegistry.getDefault(StatusHandlerRegistry.java:91)
74 | at org.eclipse.ui.statushandlers.StatusManager.getStatusHandler(StatusManager.java:135)
75 | at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:189)
76 | at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:231)
77 | at org.eclipse.ui.statushandlers.StatusManager$StatusManagerLogListener.logging(StatusManager.java:305)
78 | at org.eclipse.core.internal.runtime.RuntimeLog.logToListeners(RuntimeLog.java:160)
79 | at org.eclipse.core.internal.runtime.PlatformLogWriter.logged(PlatformLogWriter.java:100)
80 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.safeLogged(ExtendedLogReaderServiceFactory.java:86)
81 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:205)
82 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:178)
83 | at org.eclipse.equinox.log.internal.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
84 | at org.eclipse.equinox.log.internal.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
85 | at org.eclipse.equinox.log.internal.LoggerImpl.log(LoggerImpl.java:54)
86 | at org.eclipse.core.internal.runtime.Log.log(Log.java:62)
87 | at org.eclipse.ui.internal.WorkbenchPlugin.log(WorkbenchPlugin.java:818)
88 | at org.eclipse.ui.internal.EarlyStartupRunnable.handleException(EarlyStartupRunnable.java:81)
89 | at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:75)
90 | at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:44)
91 | at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2552)
92 | at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
93 |
94 | !ENTRY org.eclipse.equinox.p2.ui.sdk.scheduler 4 0 2013-08-09 14:21:50.033
95 | !MESSAGE Unable to execute early startup code for an extension
96 | !STACK 0
97 | java.lang.NullPointerException
98 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.getLastMigration(MigrationSupport.java:222)
99 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.baseChangedSinceLastPresentationOfWizard(MigrationSupport.java:183)
100 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.performMigration(MigrationSupport.java:69)
101 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler.earlyStartup(AutomaticUpdateScheduler.java:89)
102 | at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
103 | at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
104 | at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
105 | at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2552)
106 | at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
107 |
108 | !ENTRY org.eclipse.equinox.p2.ui.sdk.scheduler 4 0 2013-08-09 14:21:50.033
109 | !MESSAGE Unable to execute early startup code for an extension
110 | !STACK 0
111 | java.lang.NullPointerException
112 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.getLastMigration(MigrationSupport.java:222)
113 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.baseChangedSinceLastPresentationOfWizard(MigrationSupport.java:183)
114 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.migration.MigrationSupport.performMigration(MigrationSupport.java:69)
115 | at org.eclipse.equinox.internal.p2.ui.sdk.scheduler.AutomaticUpdateScheduler.earlyStartup(AutomaticUpdateScheduler.java:89)
116 | at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
117 | at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
118 | at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
119 | at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2552)
120 | at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
121 |
122 | !ENTRY org.eclipse.ui 4 0 2013-08-09 14:21:50.033
123 | !MESSAGE Error occurred during status handling
124 | !STACK 0
125 | java.lang.NullPointerException
126 | at org.eclipse.ui.internal.statushandlers.StatusHandlerRegistry.<init>(StatusHandlerRegistry.java:72)
127 | at org.eclipse.ui.internal.statushandlers.StatusHandlerRegistry.getDefault(StatusHandlerRegistry.java:91)
128 | at org.eclipse.ui.statushandlers.StatusManager.getStatusHandler(StatusManager.java:135)
129 | at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:189)
130 | at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:231)
131 | at org.eclipse.ui.statushandlers.StatusManager$StatusManagerLogListener.logging(StatusManager.java:305)
132 | at org.eclipse.core.internal.runtime.RuntimeLog.logToListeners(RuntimeLog.java:160)
133 | at org.eclipse.core.internal.runtime.PlatformLogWriter.logged(PlatformLogWriter.java:100)
134 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.safeLogged(ExtendedLogReaderServiceFactory.java:86)
135 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:205)
136 | at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:178)
137 | at org.eclipse.equinox.log.internal.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
138 | at org.eclipse.equinox.log.internal.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
139 | at org.eclipse.equinox.log.internal.LoggerImpl.log(LoggerImpl.java:54)
140 | at org.eclipse.core.internal.runtime.Log.log(Log.java:62)
141 | at org.eclipse.ui.internal.WorkbenchPlugin.log(WorkbenchPlugin.java:822)
142 | at org.eclipse.ui.internal.EarlyStartupRunnable.handleException(EarlyStartupRunnable.java:81)
143 | at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:75)
144 | at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:44)
145 | at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2552)
146 | at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
