1 | /usr/local/arduino-1.0.5/hardware/tools/avrdude -C /usr/local/arduino-1.0.5/hardware/tools/avrdude.conf -F -patmega328p -cavrispmkII -P/dev/ttyUSB0 -Uflash:w:dist/Debug/Arduino-Linux-x86/firmware.hex:i
2 |
3 | avrdude: AVR device initialized and ready to accept instructions
4 |
5 | Reading | ################################################## | 100% 0.01s
6 |
7 | avrdude: Device signature = 0x1e950f
8 | avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
9 | To disable this feature, specify the -D option.
10 | avrdude: erasing chip
11 | avrdude: reading input file "dist/Debug/Arduino-Linux-x86/firmware.hex"
12 | avrdude: writing flash (20000 bytes):
13 |
14 | Writing | ####################### | 45% 2.80savrdude: stk500v2_ReceiveMessage(): timeout
15 | Writing | ####################### | 46% 7.04savrdude: stk500v2_ReceiveMessage(): timeout
16 | Writing | ######################## | 48% 11.29savrdude: stk500v2_ReceiveMessage(): timeout
17 | Writing | ######################### | 49% 15.52savrdude: stk500v2_ReceiveMessage(): timeout
18 | Writing | ######################### | 50% 19.76savrdude: stk500v2_ReceiveMessage(): timeout
19 | Writing | ########################## | 51% 23.98savrdude: stk500v2_ReceiveMessage(): timeout
20 | Writing | ########################### | 53% 28.23savrdude: stk500v2_ReceiveMessage(): timeout
21 | Writing | ########################### | 54% 32.46savrdude: stk500v2_ReceiveMessage(): timeout
22 | Writing | ############################ | 55% 36.68savrdude: stk500v2_ReceiveMessage(): timeout
23 | Writing | ############################ | 56% 40.92savrdude: stk500v2_ReceiveMessage(): timeout
24 | Writing | ############################# | 58% 45.17savrdude: stk500v2_ReceiveMessage(): timeout
25 | Writing | ############################## | 59% 49.40savrdude: stk500v2_ReceiveMessage(): timeout
26 | Writing | ############################## | 60% 53.62savrdude: stk500v2_ReceiveMessage(): timeout
27 | Writing | ############################### | 62% 57.87savrdude: stk500v2_ReceiveMessage(): timeout
28 | Writing | ################################ | 63% 62.11savrdude: stk500v2_ReceiveMessage(): timeout
29 | Writing | ################################ | 64% 66.33savrdude: stk500v2_ReceiveMessage(): timeout
30 | Writing | ################################# | 65% 70.56savrdude: stk500v2_ReceiveMessage(): timeout
31 | Writing | ################################## | 67% 74.81savrdude: stk500v2_ReceiveMessage(): timeout
32 | Writing | ################################## | 68% 79.05savrdude: stk500v2_ReceiveMessage(): timeout
33 | Writing | ################################### | 69% 83.27savrdude: stk500v2_ReceiveMessage(): timeout
34 | Writing | ########################################### | 85% 88.15savrdude: stk500v2_ReceiveMessage(): timeout
35 | Writing | ############################################ | 87% 92.47savrdude: stk500v2_ReceiveMessage(): timeout
36 | Writing | ############################################ | 88% 96.71savrdude: stk500v2_ReceiveMessage(): timeout
37 | Writing | ############################################# | 89% 100.94savrdude: stk500v2_ReceiveMessage(): timeout
38 | Writing | ############################################# | 90% 105.16savrdude: stk500v2_ReceiveMessage(): timeout
39 | Writing | ############################################## | 92% 109.41savrdude: stk500v2_ReceiveMessage(): timeout
40 | Writing | ############################################### | 93% 113.65savrdude: stk500v2_ReceiveMessage(): timeout
41 | Writing | ############################################### | 94% 117.87savrdude: stk500v2_ReceiveMessage(): timeout
42 | Writing | ################################################ | 96% 122.12savrdude: stk500v2_ReceiveMessage(): timeout
43 | Writing | ################################################# | 97% 126.35savrdude: stk500v2_ReceiveMessage(): timeout
44 | Writing | ################################################## | 99% 130.63savrdude: stk500v2_ReceiveMessage(): timeout
45 | Writing | ################################################## | 100% 134.86s
46 |
47 | avrdude: 20000 bytes of flash written
48 | avrdude: verifying flash memory against dist/Debug/Arduino-Linux-x86/firmware.hex:
49 | avrdude: load data flash data from input file dist/Debug/Arduino-Linux-x86/firmware.hex:
50 | avrdude: input file dist/Debug/Arduino-Linux-x86/firmware.hex contains 20000 bytes
51 | avrdude: reading on-chip flash data:
52 |
53 | Reading | | 0% 0.00savrdude: stk500v2_ReceiveMessage(): timeout
54 | Reading | ################################################## | 100% 7.74s
55 |
56 | avrdude: verifying ...
57 | avrdude: verification error, first mismatch at byte 0x0000
58 | 0x69 != 0x00
59 | avrdude: verification error; content mismatch
60 |
61 | avrdude: safemode: lfuse changed! Was ff, and is now 0
62 | Would you like this fuse to be changed back? [y/n] n
63 | avrdude: safemode: hfuse changed! Was d6, and is now 0
64 | Would you like this fuse to be changed back? [y/n] n
65 | avrdude: safemode: efuse changed! Was 5, and is now 0
66 | Would you like this fuse to be changed back? [y/n] n
67 | avrdude: safemode: Fuses OK
68 |
69 | avrdude done. Thank you.
70 |
71 | make: *** [upload] Fehler 1
72 |
73 | RUN FINISHED; exit value 2; real time: 3m 42s; user: 210ms; system: 60ms
