1 | #define F_CPU 2000000
2 |
3 | #include <avr/io.h>
4 | #include <avr/interrupt.h>
5 | #include <util/delay.h>
6 |
7 |
8 | #define LED_PORT PORTD
9 | #define LED0_PIN_bm PIN0_bm
10 | #define LED1_PIN_bm PIN1_bm
11 | #define LED2_PIN_bm PIN2_bm
12 | #define LED3_PIN_bm PIN3_bm
13 | #define LED4_PIN_bm PIN4_bm
14 |
15 | #define LED_bm LED0_PIN_bm | LED1_PIN_bm | LED2_PIN_bm | LED3_PIN_bm | LED4_PIN_bm
16 |
17 | #define BAUDRATE 38400
18 | #define RS232 USARTD1
19 | #define RS232_PORT PORTD
20 | #define RS232_RX_PIN_bm PIN6_bm
21 | #define RS232_TX_PIN_bm PIN7_bm
22 |
23 | void init_clock()
24 | {
25 | OSC.CTRL = OSC_RC2MEN_bm;
26 | OSC.PLLCTRL = OSC_PLLSRC_RC2M_gc;
27 | while(!(OSC.STATUS & OSC_RC2MRDY_bm));
28 | CCP = CCP_IOREG_gc;
29 | CLK.CTRL = CLK_SCLKSEL_RC2M_gc;
30 | }
31 |
32 | void init_leds()
33 | {
34 | PORTCFG.MPCMASK = LED_bm;
35 | LED_PORT.PIN0CTRL = PORT_OPC_PULLDOWN_gc;
36 | LED_PORT.DIR |= LED_bm;
37 | LED_PORT.OUT &= ~LED_bm;
38 | }
39 |
40 | void init_usart(void)
41 | {
42 | RS232.BAUDCTRLB = (unsigned char)((F_CPU/16/BAUDRATE-1)>>8);
43 | RS232.BAUDCTRLA = (unsigned char)((F_CPU/16/BAUDRATE-1));
44 | RS232.CTRLA = USART_RXCINTLVL_HI_gc;
45 | RS232.CTRLB = USART_TXEN_bm | USART_RXEN_bm;
46 | RS232.CTRLC = USART_CMODE_ASYNCHRONOUS_gc | USART_PMODE_DISABLED_gc | USART_CHSIZE_8BIT_gc;
47 | PORTD.DIR &= ~PIN6_bm;
48 | PORTD.DIR |= PIN7_bm;
49 | }
50 |
51 | int rxChar()
52 | {
53 | while(!(RS232.STATUS & USART_RXCIF_bm));
54 | return (int)RS232.DATA;
55 | }
56 |
57 | void init_timer()
58 | {
59 | TCC0.CTRLA = (TCC0.CTRLA & (~TC0_CLKSEL_gm)) | TC_CLKSEL_DIV8_gc;
60 | TCC0.CTRLB |= TC_WGMODE_NORMAL_gc;
61 | TCC0.PER = 0xffff;
62 | TCC0.CCA = 0x2000;
63 | TCC0.CCB = 0x4000;
64 | TCC0.CCC = 0x8000;
65 | TCC0.CCD = 0xC000;
66 | }
67 |
68 | void enable_timer()
69 | {
70 | TCC0.CTRLA = (TCC0.CTRLA & (~TC0_CLKSEL_gm)) | TC_CLKSEL_DIV8_gc;
71 | TCC0.INTCTRLA = TC_OVFINTLVL_HI_gc;
72 | TCC0.INTCTRLB = (TC_CCAINTLVL_MED_gc | TC_CCBINTLVL_MED_gc | TC_CCCINTLVL_MED_gc | TC_CCDINTLVL_MED_gc);
73 | TCC0.CTRLFSET = TC_CMD_RESET_gc;
74 | TCC0.INTFLAGS = TCC0.INTFLAGS;
75 | }
76 |
77 | void disable_timer()
78 | {
79 | TCC0.CTRLA = (TCC0.CTRLA & (~TC0_CLKSEL_gm)) | TC_CLKSEL_OFF_gc;
80 | TCC0.INTCTRLA = 0;
81 | TCC0.INTCTRLB = 0;
82 | }
83 |
84 | void reset()
85 | {
86 | LED_PORT.OUT &= ~(LED_bm);
87 | PMIC.CTRL = PMIC_HILVLEN_bm | PMIC_LOLVLEN_bm | PMIC_MEDLVLEN_bm;
88 | sei();
89 | }
90 |
91 | ISR(TCC0_CCA_vect)
92 | {
93 | LED_PORT.OUT &= ~(LED_bm);
94 | LED_PORT.OUT |= LED1_PIN_bm;
95 | }
96 |
97 | ISR(TCC0_CCB_vect)
98 | {
99 | LED_PORT.OUT &= ~(LED_bm);
100 | LED_PORT.OUT |= LED2_PIN_bm;
101 | }
102 |
103 | ISR(TCC0_CCC_vect)
104 | {
105 | LED_PORT.OUT &= ~(LED_bm);
106 | LED_PORT.OUT |= LED3_PIN_bm;
107 | }
108 |
109 | ISR(TCC0_CCD_vect)
110 | {
111 | LED_PORT.OUT &= ~(LED_bm);
112 | LED_PORT.OUT |= LED4_PIN_bm;
113 | }
114 |
115 | ISR(TCC0_OVF_vect)
116 | {
117 | LED_PORT.OUT &= ~(LED_bm);
118 | }
119 |
120 | int main(void)
121 | {
122 | init_clock();
123 | init_leds();
124 | init_usart();
125 | init_timer();
126 | enable_timer(0);
127 | reset(0);
128 |
129 | while(1)
130 | {
131 |
132 | #define TEST_CODE 3
133 | #if TEST_CODE == 1
134 |
135 | /*
136 | Timer aktivieren und deaktivieren funktioniert
137 | bei Verwendung nur dieses Codes einwandfrei
138 | */
139 | enable_timer(0);
140 | _delay_ms(500);
141 | LED_PORT.OUT &= ~(LED_bm);
142 | disable_timer();
143 | _delay_ms(2000);
144 |
145 | #elif TEST_CODE == 2
146 |
147 | /*
148 | Timer aktivieren und deaktivieren funktioniert
149 | bei Verwendung nur dieses Codes einwandfrei
150 | */
151 | static int ch = 'e';
152 | switch(ch)
153 | {
154 | case 'e':
155 | enable_timer();
156 | _delay_ms(500);
157 | break;
158 |
159 | case 'd':
160 | disable_timer();
161 | LED_PORT.OUT &= ~(LED_bm);
162 | _delay_ms(2000);
163 | break;
164 |
165 | default:
166 | ch = 0;
167 | break;
168 | }
169 | ch = (ch == 'e') ? 'd' : 'e';
170 |
171 | #elif TEST_CODE == 3
172 |
173 | int ch = rxChar();
174 | switch(ch)
175 | {
176 | case 'e':
177 | enable_timer();
178 | break;
179 |
180 | case 'd':
181 | disable_timer();
182 | LED_PORT.OUT &= ~(LED_bm);
183 | break;
184 |
185 | default:
186 | ch = 0;
187 | break;
188 | }
189 |
190 | #endif
191 | }
192 | return 0;
193 | }
