1 | /*
2 | * Created on: 31.07.2013
3 | */
4 |
5 | #include <stdio.h>
6 | #include <string.h>
7 | #include <math.h>
8 | #include "system.h"
9 | #include "i2c_opencores.h"
10 | #include "unistd.h"
11 | #include "altera_avalon_pio_regs.h"
12 | #include "altera_avalon_uart_regs.h"
13 | // ESC[#;#H Moves the cursor to line #, column #
14 | #define ESC_TOP_LEFT "[1;0H"
15 | #define ESC_BOTTOM_LEFT "[2;0H"
16 | #define LCD_CLR "[2J" // ESC[2J Clear screen and home cursor
17 | #define LCD_CLR_LINE "[K" // ESC[K Clear to end of line
18 | #define ESC 0x1b // Integer ASCII value of the ESC character
19 |
20 | #define I2C_SPEED 400000
21 |
22 | #define BMP085_OVERSAMPLING 3
23 | #define BMP085_ADDRESS 0x77
24 | #define BMP085_CMD_ADDRESS 0xF4
25 | #define BMP085_PARAM_ADDRESS 0xAA
26 | #define BMP085_START_TEMP 0x2E
27 | #define BMP085_MEASURED_DATA 0xF6
28 | #define BMP085_PRESSURE_MEASURE_PRECISION (0x34+(BMP085_OVERSAMPLING<<6))
29 |
30 |
31 | #define P0 1013.25 //Pressure [hPA] @ NN
32 |
33 | short AC1 = 0, AC2 = 0, AC3 = 0, B1 = 0, B2 = 0, MB = 0, MC = 0, MD = 0;
34 | unsigned short AC4 = 0, AC5 = 0, AC6 = 0;
35 | long B5 = 0;
36 |
37 | FILE *lcd;
38 | FILE *uart;
39 |
40 | void get_Param(void);
41 | float get_Temp(void);
42 | float get_Height(void);
43 | float get_Height_average_10(void);
44 | void Display_Data(float Height_UNN, float Temperature);
45 |
46 | void ANT_config(void);
47 | void ANT_reset(void);
48 | void ANT_assignch(void);
49 | void ANT_setchid(void);
50 | void ANT_opench(void);
51 | void ANT_send_Test(void);
52 | void ANT_SEND(float Height_UNN,float Temperature);
53 |
54 |
55 | int main()
56 | {
57 | float Temperature = 0, Height_UNN = 0;
58 | char k = 4;
59 |
60 |
61 | I2C_init(I2C_BASE,ALT_CPU_FREQ,I2C_SPEED);
62 |
63 | get_Param();
64 | ANT_config();
65 |
66 | while(1)
67 | {
68 | k++;
69 | if (k >= 5)
70 | {
71 | Temperature = get_Temp();
72 | k = 0;
73 | }
74 | Height_UNN = get_Height_average_10();
75 | Display_Data(Height_UNN,Temperature);
76 | ANT_SEND(Height_UNN,Temperature);
77 | usleep(1000000);
78 | }
79 |
80 | fclose (lcd);
81 | return 0;
82 | }
83 |
84 | void Display_Data(float Height_UNN, float Temperature)
85 | {
86 | lcd = fopen ("/dev/LCD","w");
87 | if(lcd)
88 | {
89 | fprintf(lcd,"%c%s",ESC,LCD_CLR);
90 | //fprintf(lcd,"Temp = %.1f C Height = %.1f m", 1.1, 2.2);
91 | fprintf(lcd,"Temp = %.1f C\nHeight = %.1f m", Temperature, Height_UNN);
92 | fclose(lcd);
93 | }
94 | }
95 |
96 | void get_Param(void)
97 | {
98 | unsigned char data[22] = {0};
99 | char i = 0;
100 | char AOK = 1;
101 | FILE *fp;
102 | AOK = I2C_start(I2C_BASE,BMP085_ADDRESS,0); //set chip address and set to write
103 |
104 | fp = fopen("/dev/LCD","w");
105 | if (AOK == 0)
106 | fprintf(fp,"Adress OK");
107 | fclose(fp);
108 |
109 | I2C_write(I2C_BASE,BMP085_PARAM_ADDRESS,0);
110 | I2C_start(I2C_BASE,BMP085_ADDRESS,1); //set chip address in read mode
111 |
112 | for (i = 0;i < 21;i++)
113 | {
114 | data[(0 + (i))] = I2C_read(I2C_BASE,0); // memory array
115 | }
116 | data[(0 + (i))] = I2C_read(I2C_BASE,1); // last memory read
117 |
118 | AC1 = (data[0] << 8) | data[1];
119 | AC2 = (data[2] << 8) | data[3];
120 | AC3 = (data[4] << 8) | data[5];
121 | AC4 = (data[6] << 8) | data[7];
122 | AC5 = (data[8] << 8) | data[9];
123 | AC6 = (data[10] << 8) | data[11];
124 | B1 = (data[12] << 8) | data[13];
125 | B2 = (data[14] << 8) | data[15];
126 | MB = (data[16] << 8) | data[17];
127 | MC = (data[18] << 8) | data[19];
128 | MD = (data[20] << 8) | data[21];
129 | }
130 |
131 | float get_Temp(void)
132 | {
133 | float Temperature = 0;
134 | long X1 = 0 ,X2 = 0, Temp_Comp = 0;
135 | unsigned long Temp_Raw = 0;
136 |
137 | I2C_start(I2C_BASE,BMP085_ADDRESS,0);
138 | I2C_write(I2C_BASE,BMP085_CMD_ADDRESS,0);
139 | I2C_write(I2C_BASE,BMP085_START_TEMP,1);
140 | while(!(IORD_ALTERA_AVALON_PIO_DATA(GPIO_IN_BASE) & 0x80));
141 | I2C_start(I2C_BASE,BMP085_ADDRESS,0);
142 | I2C_write(I2C_BASE,BMP085_MEASURED_DATA,0);
143 | I2C_start(I2C_BASE,BMP085_ADDRESS,1);
144 |
145 | Temp_Raw = (I2C_read(I2C_BASE,0) << 8);
146 | Temp_Raw = (Temp_Raw | I2C_read(I2C_BASE,1));
147 |
148 | X1 = ((((long)Temp_Raw - (long)AC6) * (long)AC5) >> 15);
149 | X2 = (((long)MC << 11) / (X1 + (long)MD));
150 | B5 = (X1 + X2);
151 | Temp_Comp = ((B5 + 8) >> 4);
152 | Temperature =((float)Temp_Comp * 0.1);
153 |
154 | return Temperature;
155 | }
156 |
157 | float get_Height(void)
158 | {
159 | long X1 = 0, X2 = 0, X3 = 0, B3 = 0, B6 = 0, Press_Comp = 0;
160 | unsigned long B4 = 0, B7 = 0, Press_Raw = 0;
161 | float UNN = 0;
162 |
163 | I2C_start(I2C_BASE,BMP085_ADDRESS,0);
164 | I2C_write(I2C_BASE,BMP085_CMD_ADDRESS,0);
165 | I2C_write(I2C_BASE,BMP085_PRESSURE_MEASURE_PRECISION,1);
166 | while(!(IORD_ALTERA_AVALON_PIO_DATA(GPIO_IN_BASE) & 0x80));
167 | I2C_start(I2C_BASE,BMP085_ADDRESS,0);
168 | I2C_write(I2C_BASE,BMP085_MEASURED_DATA,0);
169 | I2C_start(I2C_BASE,BMP085_ADDRESS,1);
170 |
171 | Press_Raw = (I2C_read(I2C_BASE,0) << 16);
172 | Press_Raw = (Press_Raw | (I2C_read(I2C_BASE,0) << 8));
173 | Press_Raw = (Press_Raw | (I2C_read(I2C_BASE,1)));
174 | Press_Raw = (Press_Raw >> (8 - BMP085_OVERSAMPLING));
175 |
176 | B6 = (B5 - 4000);
177 | X1 = ((B6 * B6) >> 12);
178 | X1 *= B2;
179 | X1 >>= 11;
180 | X2 = (AC2 * B6);
181 | X2 >>= 11;
182 | X3 = (X1 + X2);
183 | B3 = ((((((long)AC1 << 2) + X3) << BMP085_OVERSAMPLING) + 2) >> 2);
184 | X1 = ((AC3 * B6) >> 13);
185 | X2 = ((B1 * ((B6 * B6) >> 12)) >> 16);
186 | X3 = (((X1 + X2) + 2) >> 2);
187 | B4 = ((AC4 * (unsigned long)(X3 + 32768)) >> 15);
188 | B7 = (((unsigned long)(Press_Raw - B3)) * (50000 >> BMP085_OVERSAMPLING));
189 | Press_Comp = 0;
190 | if (B7 < 0x80000000)
191 | {
192 | Press_Comp = (B7 << 1) / B4;
193 | }
194 | else
195 | {
196 | Press_Comp = (B7 / B4) << 1;
197 | }
198 | X1 = (Press_Comp >> 8);
199 | X1 *= X1;
200 | X1 = ((X1 * 3038) >> 16);
201 | X2 = (((-7357) * Press_Comp) >> 16);
202 | Press_Comp += (((X1 + X2 + 3791) >> 4));
203 | UNN = (44330.0 * (1.0 - (pow(((((float)Press_Comp / 100.0)) / P0),(1.0 / 5.255)))));
204 |
205 | return UNN;
206 |
207 | }
208 |
209 | float get_Height_average_10(void)
210 | {
211 | char z = 0;
212 | float Height_UNN_average_10 = 0, Height_UNN = 0;
213 |
214 | for(z = 0; z <= 24 ; z++)
215 | {
216 | Height_UNN += get_Height();
217 | }
218 | Height_UNN_average_10 = (Height_UNN / 25.0);
219 |
220 | return Height_UNN_average_10;
221 |
222 | }
223 |
224 | void ANT_config (void)
225 | {
226 | ANT_reset();
227 | usleep(1000000);
228 | ANT_assignch();
229 | usleep(1000000);
230 | ANT_setchid();
231 | usleep(1000000);
232 | ANT_opench();
233 | usleep(1000000);
234 | //ANT_send_Test();
235 | }
236 |
237 | // Resets module
238 | void ANT_reset (void)
239 | {
240 | unsigned char i;
241 | unsigned char setup[4];
242 |
243 | setup[0] = 0xa4; // SYNC Byte
244 | setup[1] = 0x01; // LENGTH Byte
245 | setup[2] = 0x4a; // ID Byte
246 | setup[3] = 0x00; // Data Byte N (N=LENGTH)
247 | setup[4] = 0xef; // Checksum
248 | uart = fopen("/dev/UART", "r+");
249 | if(uart)
250 | {
251 | for(i = 0 ; i < 5 ; i++)
252 | {
253 | putc(setup[i],uart);
254 | }
255 | }
256 | fclose(uart);
257 | }
258 |
259 | // Assigns CH=0, CH Type=10(TX), Net#=0
260 | void ANT_assignch (void)
261 | {
262 | unsigned char i;
263 | unsigned char setup[6];
264 |
265 | setup[0] = 0xa4;
266 | setup[1] = 0x03;
267 | setup[2] = 0x42;
268 | setup[3] = 0x00;
269 | setup[4] = 0x10;
270 | setup[5] = 0x00;
271 | setup[6] = 0xf5;
272 | uart = fopen("/dev/UART", "r+");
273 | if(uart)
274 | {
275 | for(i = 0 ; i < 7 ; i++)
276 | {
277 | putc(setup[i],uart);
278 | }
279 | }
280 | fclose(uart);
281 | }
282 |
283 | // Assigns Device#=3100, Device Type ID=01, Trans Type=01
284 | void ANT_setchid (void)
285 | {
286 | unsigned char i;
287 | unsigned char setup[8];
288 |
289 | setup[0] = 0xa4;
290 | setup[1] = 0x05;
291 | setup[2] = 0x51;
292 | setup[3] = 0x00;
293 | setup[4] = 0x31;
294 | setup[5] = 0x00;
295 | setup[6] = 0x01;
296 | setup[7] = 0x05;
297 | setup[8] = 0xc5;
298 | uart = fopen("/dev/UART", "r+");
299 | if(uart)
300 | {
301 | for(i = 0 ; i < 9 ; i++)
302 | {
303 | putc(setup[i],uart);
304 | }
305 | }
306 | fclose(uart);
307 | }
308 |
309 | // Opens CH 0
310 | void ANT_opench (void)
311 | {
312 | unsigned char i;
313 | unsigned char setup[4];
314 |
315 | setup[0] = 0xa4;
316 | setup[1] = 0x01;
317 | setup[2] = 0x4b;
318 | setup[3] = 0x00;
319 | setup[4] = 0xee;
320 | uart = fopen("/dev/UART", "r+");
321 | if(uart)
322 | {
323 | for(i = 0 ; i < 5 ; i++)
324 | {
325 | putc(setup[i],uart);
326 | }
327 | }
328 | fclose(uart);
329 | }
330 |
331 | void ANT_SEND(float Height_UNN,float Temperature)
332 | {
333 | unsigned char i;
334 | unsigned char txBuffer[32];
335 | unsigned char txBufferSize=0;
336 | unsigned char BUFFER[32]={0};
337 |
338 | sprintf(BUFFER,"%.1f%.1f",Temperature,Height_UNN);
339 | txBufferSize = strlen(BUFFER) + 4; // message plus sync, size and checksum
340 | txBuffer[0] = 0xa4; // sync byte
341 | txBuffer[1] = (unsigned char) strlen(BUFFER) - 1; // message size - command size (1)
342 | txBuffer[2] = 0x4e;
343 | for(i=0; i<strlen(BUFFER); i++)
344 | txBuffer[3+i] = BUFFER[i];
345 |
346 | // calculate the checksum
347 | for(i=0; i<txBufferSize - 1; ++i)
348 | txBuffer[txBufferSize - 1] = txBuffer[txBufferSize - 1] ^ txBuffer[i];
349 |
350 |
351 |
352 | uart = fopen("/dev/UART", "r+");
353 | if(uart)
354 | {
355 | for(i = 0 ; i < txBufferSize ; i++)
356 | {
357 | putc(txBuffer[i],uart);
358 | }
359 | }
360 | fclose(uart);
361 | }
362 | // Sends Data=AAAAAAAAAAAAAAAA
363 | void ANT_send_Test (void)
364 | {
365 | unsigned char i;
366 | unsigned char setup[12];
367 |
368 | setup[0] = 0xa4;
369 | setup[1] = 0x09;
370 | setup[2] = 0x4e;
371 | setup[3] = 0x00;
372 | setup[4] = 0xaa;
373 | setup[5] = 0xaa;
374 | setup[6] = 0xaa;
375 | setup[7] = 0xaa;
376 | setup[8] = 0xaa;
377 | setup[9] = 0xaa;
378 | setup[10] = 0xaa;
379 | setup[11] = 0xaa;
380 | setup[12] = 0xe3;
381 |
382 | uart = fopen("/dev/UART", "r+");
383 | if(uart)
384 | {
385 | for(i = 0 ; i < 13 ; i++)
386 | {
387 | putc(setup[i],uart);
388 | }
389 | }
390 | fclose(uart);
391 | }
