Guten Tag,
ja ich habe die Suche benutzt.
Jedoch habe ich immer noch ein kleines Verständnisproblem.
Ich benutze:
ATiny45
WinAVR / AVR Studio 6
Fuse eingestellt INTRCOSC_4MHZ_6CK_14CK_64MS
Makefile: F_CPU = 4000000 / OPT = s
In der Souce:
1 | C-Code
2 | #ifndef F_CPU
3 | #define F_CPU 4000000UL
4 | #endif
5 |
6 | #define timer0_start TCCR0B = 0x01 //keinen teiler 80 alle 10µs
7 | #define timer0_stopp TCCR0B = 0x00
8 | #define timer0 TCNT0
9 |
10 | #define timer1_start TCCR1 = 0x03 //64
11 | #define timer1_stopp TCCR1 = 0x00
12 | #define timer1 TCNT1
13 |
14 | #define RC5TIME 1.778e-3 // 1.778msec
15 | #define PULSE_MIN (uchar)(XTAL / 512 * RC5TIME * 0.4 + 0.5)
16 | #define PULSE_1_2 (uchar)(XTAL / 512 * RC5TIME * 0.8 + 0.5)
17 | #define PULSE_MAX (uchar)(XTAL / 512 * RC5TIME * 1.2 + 0.5)
18 | //min = 889µs/26 T/aufrufinterwall
19 |
20 |
21 |
22 | #include <avr/io.h>
23 | #include <stdint.h>
24 | #include <avr/interrupt.h>
25 | #include <util/delay.h>
26 | #include <stdbool.h>
27 | #include <avr/interrupt.h>
28 | #include <stdlib.h>
29 |
30 |
31 | #define uchar unsigned char
32 | #define uint unsigned int
33 |
34 | #define xRC5_IN PINB
35 | #define xRC5 PB2 // IR input low active
36 |
37 | #define XTAL 11.0592e6
38 |
39 | uchar rc5_bit; // bit value
40 | uchar rc5_time; // count bit time
41 | uint rc5_tmp; // shift bits in
42 | volatile uint rc5_data; // store result
43 |
44 | SIGNAL (SIG_OVERFLOW0)
45 | {
46 | PORTB |= (1<<PB4) ; // set
47 | //volatile uint tmp = rc5_tmp; // for faster access
48 |
49 | TCNT0 = -2; // 2 * 256 = 512 cycle
50 |
51 | if( ++rc5_time > PULSE_MAX ){ // count pulse time
52 | if( !(rc5_data & 0x4000) && rc5_data & 0x2000 ) // only if 14 bits received
53 | rc5_data = rc5_data;
54 | rc5_data = 0;
55 | }
56 |
57 | if( (rc5_bit ^ xRC5_IN) & 1<<xRC5 ){ // change detect
58 | rc5_bit = ~rc5_bit; // 0x00 -> 0xFF -> 0x00
59 |
60 | if( rc5_time < PULSE_MIN ) // to short
61 | rc5_data = 0;
62 |
63 | if( !rc5_data || rc5_time > PULSE_1_2 ){ // start or long pulse time
64 | if( !(rc5_data & 0x4000) ) // not to many bits
65 | rc5_data <<= 1; // shift
66 | if( !(rc5_bit & 1<<xRC5) ) // inverted bit
67 | rc5_data |= 1; // insert new bit
68 | rc5_time = 0; // count next pulse time
69 | }
70 | }
71 |
72 | rc5_tmp = rc5_data;
73 | PORTB &= ~(1<<PB4); //reset
74 | }
75 | int main(void)
76 | {
77 | DDRB = 0b111011; //Schieberegisterports als Ausgang PB2 di
78 | PORTB = 0b000100; // Pull up pb2 ein
79 | TCCR0B = 1<<CS02; //divide by 256
80 | TIMSK = 1<<TOIE0; //enable timer interrupt
81 | sei();
82 | }
83 | while(1)
84 | {
85 | asm("nop");
86 | }
Nun habe ich mit meinem Oszi PB4 untersucht und PB2.
Alle 280µs wird PB4, für 20µs high.
Eigentlich sollte er aber doch alle 16,384 sek aufgerufen werden?
Dies ist aber doch viel zu lang!
Wie dem auch sei.
Anschließend habe ich den Teiler auf 1 gestellt.
Nun wir die ISR alle 26µs aufgerufen.
Ich vermude das nun diese
#define PULSE_MIN (uchar)(XTAL / 512 RC5TIME 0.4 + 0.5)
#define PULSE_1_2 (uchar)(XTAL / 512 RC5TIME 0.8 + 0.5)
#define PULSE_MAX (uchar)(XTAL / 512 RC5TIME 1.2 + 0.5)
Werte nicht mehr stimmen.
Interpretiere ich das so richtig:?
#define PULSE_MIN sollte in etwa 889µs sein
#define PULSE_1_2 sollte in etwa 1778µs sein
#define PULSE_MAX ???? 24,889ms
Nun habe ich versucht diese Werte anzupassen.
Zeit : Aufrufinterwall
z.B.:
PULSE_MIN = 889 : 2 = 34
Das ausgelesene Ergebnis ist immer noch 0. :-(
Die ISR erkennt die Flankenwechsel.
Wenn ich rc5_bit an PB4 ausgebe, so entspricht dies genau dem PB2
Signal.
Zitat:"Danach muß man nur im Bitabstand weiter abtasten und voila, nach
14 Bitzeiten hat man alle Bits.
Damit es nun dabei nicht zu Zeitverschiebungen aufgrund zu hoher
Toleranzen kommt, wird bei jeder Flanke neu synchronisiert. Um die
Hilfsflanken auszublenden, werden nur Flanken, die nach 0,8 ... 1,2
Bitzeiten kommen ausgewertet."
Was ist mein Fehler.
Freue mich über jeden Tipp.
Vielen Dank
