1 | //CAN1
2 | #define GPIO_CAN1 GPIOD
3 | #define GPIO_Pin_CAN1_RX GPIO_Pin_0
4 | #define GPIO_Pin_CAN1_TX GPIO_Pin_1
5 |
6 | //CAN2
7 | #define GPIO_CAN2 GPIOB
8 | #define GPIO_Pin_CAN2_RX GPIO_Pin_12
9 | #define GPIO_Pin_CAN2_TX GPIO_Pin_6
10 |
11 |
12 | void CAN_init(void)
13 | {
14 | //Periph-Clock an
15 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1 | RCC_APB1Periph_CAN2, ENABLE);
16 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD, ENABLE);
17 |
18 | //CAN1
19 | GPIO_StructInit(&GPIO_InitStructure);
20 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN1_RX;
21 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
22 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
23 | GPIO_Init(GPIO_CAN1, &GPIO_InitStructure);
24 |
25 | GPIO_StructInit(&GPIO_InitStructure);
26 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN1_TX;
27 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
28 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
29 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
30 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
31 | GPIO_Init(GPIO_CAN1, &GPIO_InitStructure);
32 |
33 | GPIO_PinAFConfig(GPIO_CAN1, GPIO_PinSource0, GPIO_AF_CAN1);
34 | GPIO_PinAFConfig(GPIO_CAN1, GPIO_PinSource1, GPIO_AF_CAN1);
35 |
36 | //CAN2
37 | GPIO_StructInit(&GPIO_InitStructure);
38 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN2_RX;
39 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
40 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
41 | GPIO_Init(GPIO_CAN2, &GPIO_InitStructure);
42 |
43 | GPIO_StructInit(&GPIO_InitStructure);
44 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN2_TX;
45 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
46 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
47 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
48 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
49 | GPIO_Init(GPIO_CAN2, &GPIO_InitStructure);
50 |
51 | GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_CAN2);
52 | GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_CAN2);
53 | //
54 | //GPIOB->AFR[0]|=(0x09<<24);
55 | //GPIOB->AFR[1]|=(0x09<<16);
56 |
57 | CAN_DeInit(CAN1);
58 | CAN_DeInit(CAN2);
59 |
60 |
61 | //Merde: überprüfen für 42Mhz Clock APB1
62 | CAN_StructInit(&CAN_InitStructure);
63 | CAN_InitStructure.CAN_Prescaler = 4; //!< Specifies the length of a time quantum. It ranges from 1 to 1024.
64 | CAN_InitStructure.CAN_SJW = CAN_SJW_2tq; //!< Specifies the maximum number of time quanta the CAN hardware is allowed to lengthen or shorten a bit to perform resynchronization.
65 | CAN_InitStructure.CAN_BS1 = CAN_BS1_13tq; //!< Specifies the number of time quanta in Bit Segment 1.
66 | CAN_InitStructure.CAN_BS2 = CAN_BS2_7tq; //!< Specifies the number of time quanta in Bit Segment 2.
67 | // tq=4/42Mhz 1Bit=SJW+BS1+BS2 bei 500kbaud= 2µSek
68 |
69 | CAN_InitStructure.CAN_Mode = CAN_Mode_Normal; //!< Specifies the CAN operating mode.
70 | CAN_InitStructure.CAN_TTCM = DISABLE; //!< Enable or disable the time triggered communication mode.
71 | CAN_InitStructure.CAN_ABOM = DISABLE; //!< Enable or disable the automatic bus-off management.
72 | CAN_InitStructure.CAN_AWUM = DISABLE; //!< Enable or disable the automatic wake-up mode.
73 | CAN_InitStructure.CAN_NART = ENABLE; //!< Enable or disable the non-automatic retransmission mode.
74 | CAN_InitStructure.CAN_RFLM = DISABLE; //!< Enable or disable the Receive FIFO Locked mode.
75 | CAN_InitStructure.CAN_TXFP = DISABLE; //!< Enable or disable the transmit FIFO priority.
76 |
77 | CAN_Init(CAN1, &CAN_InitStructure);
78 | CAN_Init(CAN2, &CAN_InitStructure);
79 |
80 |
81 | // Can filter Init
82 | CAN_FilterInit(&CAN_FilterInitStructure);
83 | CAN_FilterInitStructure.CAN_FilterNumber = 0;
84 | CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
85 | CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
86 | CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0112<<5;
87 | CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
88 | CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0xFFFF;
89 | CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0xFFFF;
90 | CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
91 | CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
92 | CAN_FilterInit(&CAN_FilterInitStructure);
93 | }
