Ich will ein kleines Progi schreiben das auf einen Attiny85 drei PWM und
ein ADC - Pin steuert. Nun habe ich zwei kleine Progis geschriben die
einzeln einwandfrei funktionieren. Aber sobald ich sie zusammenfüge hab
reagier weder PWM noch ADC. Kann mir jemand sagen warum…
1 | /*
2 | * LED_PWM.c
3 | *
4 | * Created: 06.09.2013 13:13:37
5 | * Author: Mohan
6 | */
7 |
8 | #define F_CPU 1000000UL
9 |
10 | #include <avr/io.h>
11 | #include <util/delay.h>
12 | #include <avr/interrupt.h>
13 |
14 | int ADC_val;
15 |
16 | // re- / start interrupt
17 | void start_ADC(void)
18 | {
19 | ADCSRA |= (1 << ADSC);
20 | }
21 |
22 | int main(void)
23 | {
24 | // PORT init
25 | DDRB = (1 << DDB4) | (1 << DDB1) | (1 << DDB0);
26 | PORTB = 0x00;
27 |
28 | // set Bits for FPWM Timer0
29 | TCCR0A = (1 << COM0A1) | (1 << COM0B1) | (1 << WGM00) | (1 << WGM01);
30 |
31 | // set Bits for NPWM Timer1
32 | GTCCR = (1 << PWM1B) | (1<< COM1B0);
33 |
34 | // Set Timer0 interrupt Bit | Set Timer1 interrupt Bit
35 | TIMSK = (1 << TOIE0) | (1 << TOIE1);
36 |
37 | // FPWM VALUES
38 | OCR0A = 0;
39 | OCR0B = 0;
40 |
41 | DDRB = (1 << DDB4) | (1 << DDB1) | (1 << DDB0);
42 | PORTB = 0x13;
43 |
44 | // ADC init
45 | ADMUX = (1 << MUX0) | (1 << MUX1);
46 | ADCSRA = (1 << ADEN) | (1 << ADIE) | (1 << ADPS2) | (1 << ADPS0);
47 | DIDR0 = (1 << ADC3D);
48 |
49 | // NPWM VLUES
50 | OCR1B = 0;
51 | OCR1C = 255;
52 |
53 | // start Timers
54 | TCCR1 = (1 << CS10);
55 | TCCR0B = (1 << CS00);
56 |
57 | // start interrupts
58 | sei();
59 |
60 | start_ADC();
61 |
62 | while(1)
63 | {
64 |
65 | }
66 | }
67 |
68 | ISR(ADC_vect)
69 | {
70 | ADC_val = ADC;
71 | start_ADC();
72 | }
73 |
74 | // Timer1 interrupt
75 | ISR(TIMER1_OVF_vect)
76 | {
77 | OCR1B = 255; // grün
78 | }
79 |
80 | // Timer0 interrupt
81 | ISR(TIMER0_OVF_vect)
82 | {
83 | OCR0A = 255; // rot
84 | OCR0B = 255; // blau
85 | }
