1 | // ----------------------------------------------------------------------------
2 | // INCLUDES
3 | // ----------------------------------------------------------------------------
4 |
5 | #include <stdint.h>
6 | #include <avr/io.h>
7 | #include <avr/interrupt.h>
8 | #include <inttypes.h>
9 | #include <avr/wdt.h>
10 | #include <util/delay.h>
11 |
12 |
13 | // ----------------------------------------------------------------------------
14 | // DEFINES
15 | // ----------------------------------------------------------------------------
16 | #ifndef F_CPU
17 | #define F_CPU 8000000UL // processor clock frequency 8Mhz
18 | #endif
19 |
20 | #define REPEAT_START 41
21 | #define REPEAT_NEXT 83
22 |
23 | #define LED PD3
24 |
25 | // Port Defines
26 | #define PORTLED PORTD
27 |
28 | // --------------------------------------------------------------------------------------------
29 | // Funktionsdeklarationen
30 | // --------------------------------------------------------------------------------------------
31 | void init_ports(void); // Initialisiert die Ports, Enable global Interrupt
32 | void init_timer1(void); // Initialisiert den Timer1 16-bit
33 |
34 | uint8_t get_key_press_PIND_high( uint8_t key_mask );
35 | uint8_t get_key_state_PIND_high( uint8_t key_mask );
36 | uint8_t get_key_rpt_PIND_high( uint8_t key_mask );
37 | uint8_t get_key_short_PIND_high( uint8_t key_mask );
38 | uint8_t get_key_long_PIND_high( uint8_t key_mask );
39 |
40 |
41 | volatile uint8_t key_state_PIND_high; // debounced and non-inverted key state: bit = 1: key pressed, liest den Zustand eines Ports ein gemäß der Maske
42 | volatile uint8_t key_press_PIND_high; // key press detect active high
43 | volatile uint8_t key_rpt_PIND_high;
44 |
45 |
46 | //Timer1 16-bit Compare Match B Interrupt Service Routine
47 | ISR (TIMER1_COMPB_vect){
48 | static uint8_t u8Entprellcounter;
49 | u8Entprellcounter++;
50 | if (u8Entprellcounter >= 3){ // alle 12ms Entprellfunktionen aufrufen
51 | // Entprellen des PIND active high
52 | static uint8_t ct0_PIND_high, ct1_PIND_high, rpt_PIND_high;
53 | uint8_t i_PIND_high;
54 |
55 | i_PIND_high = key_state_PIND_high ^ PIND; // key changed?, not inverted!
56 | ct0_PIND_high = ~( ct0_PIND_high & i_PIND_high ); // reset or count ct0
57 | ct1_PIND_high = ct0_PIND_high ^ (ct1_PIND_high & i_PIND_high); // reset or count ct1
58 | i_PIND_high &= ct0_PIND_high & ct1_PIND_high; // count until roll over ?
59 | key_state_PIND_high ^= i_PIND_high; // then toggle debounced state
60 | key_press_PIND_high |= key_state_PIND_high & i_PIND_high; // 0->1: key press detect
61 |
62 | if( (key_state_PIND_high & (1<<PD0)) == 0 ) // check repeat function
63 | rpt_PIND_high = REPEAT_START; // start delay
64 | if( --rpt_PIND_high == 0 ){
65 | rpt_PIND_high = REPEAT_NEXT; // repeat delay
66 | key_rpt_PIND_high |= key_state_PIND_high & (1<<PD0);
67 | }
68 |
69 | u8Entprellcounter = 0; // Entprellcounter nullen
70 | }
71 |
72 |
73 | OCR1B = OCR1B+((F_CPU/8000000UL)*31999); // Compare Match Register wieder vorladen, erzeugt ein Compare Match jede 4ms
74 |
75 | }
76 |
77 |
78 | /*Hauptprogramm Aufgaben:
79 |
80 | Das Hauptprogramm
81 | */
82 | int main(void)
83 | {
84 | init_ports();
85 | init_timer1();
86 |
87 | // LED einschalten, dass man sieht, dass Spannung anliegt und µC läuft
88 | PORTLED &= ~( 1<<LED );
89 | _delay_ms(300);
90 | PORTLED |= ( 1<<LED );
91 |
92 | while (1){
93 |
94 | if( get_key_short_PIND_high( 1<<PD0 )){
95 | PORTLED &= ~( 1<<LED );
96 | _delay_ms(300);
97 | PORTLED |= ( 1<<LED );
98 | }
99 |
100 | if( get_key_long_PIND_high( 1<<PD0 )){
101 | PORTLED &= ~( 1<<LED );
102 | _delay_ms(1000);
103 | PORTLED |= ( 1<<LED );
104 | }
105 |
106 |
107 | } // Ende main loop
108 | } // Ende Hauptprogramm
109 |
110 |
111 |
112 | // ----------------------------------------------------------------------------
113 | // Funktionen
114 | // ----------------------------------------------------------------------------
115 |
116 | /*Funktion zum Initialisierein des µC*/
117 | void init_ports(void) {
118 |
119 | // ===========================================================================================
120 |
121 | DDRB = 0x00;
122 |
123 | DDRC = 0x00; // Datenrichtungsregister zunächst alle Eingang
124 |
125 | DDRD = 0x00; // Datenrichtungsregister zunächst alle Eingang
126 | DDRD |= (1 << DDD3); // LED als Ausgang
127 | PORTD |= (1 << PD1) | (1 << PD2) | (1 << PD3) | (1 << PD4); // Pullups einschalten, LED ausschalten
128 |
129 |
130 | sei(); // setzt globales Interrupt enable
131 |
132 | return;
133 | }
134 |
135 | void init_timer1(void) {
136 |
137 | OCR1B = ((F_CPU/8000000UL)*31999); // Berechnet den Compare Wert für 4ms bei max. 16Mhz Frequenz
138 | TIMSK |= (1 << OCIE1B);
139 | TCNT1 = 0;
140 | TCCR1B |= (1 << CS10); // kein Prescaler, Timer1 läuft maximal durch
141 |
142 | return;
143 | }
144 |
145 |
146 | // Funktion für Tastendruck-Erkennung Tasten gegen VCC
147 | uint8_t get_key_press_PIND_high( uint8_t key_mask ) {
148 | cli(); // read and clear atomic !
149 | key_mask &= key_press_PIND_high; // read key(s)
150 | key_press_PIND_high ^= key_mask; // clear key(s)
151 | sei();
152 | return key_mask;
153 | }
154 |
155 | uint8_t get_key_state_PIND_high( uint8_t key_mask ){
156 |
157 | key_mask &= key_state_PIND_high;
158 | return key_mask;
159 | }
160 |
161 | uint8_t get_key_rpt_PIND_high( uint8_t key_mask )
162 | {
163 | cli(); // read and clear atomic !
164 | key_mask &= key_rpt_PIND_high; // read key(s)
165 | key_rpt_PIND_high ^= key_mask; // clear key(s)
166 | sei();
167 | return key_mask;
168 | }
169 |
170 | uint8_t get_key_short_PIND_high( uint8_t key_mask )
171 | {
172 | cli(); // read key state and key press atomic !
173 | return get_key_press_PIND_high( ~key_state_PIND_high & key_mask );
174 | }
175 |
176 | uint8_t get_key_long_PIND_high( uint8_t key_mask )
177 | {
178 | return get_key_press_PIND_high( get_key_rpt_PIND_high( key_mask ));
179 | }
