1 | /******************************************************************************/
2 | /* Files to Include */
3 | /******************************************************************************/
4 | #ifdef __XC32
5 | #include <xc.h> /* Defines special funciton registers, CP0 regs */
6 | #endif
7 |
8 | #include <plib.h> /* Include to use PIC32 peripheral libraries */
9 | #include <stdint.h> /* For uint32_t definition */
10 | #include <stdbool.h> /* For true/false definition */
11 |
12 | #include "system.h" /* System funct/params, like osc/periph config */
13 | #include "user.h" /* User funct/params, such as InitApp */
14 |
15 | /******************************************************************************/
16 | /* Global Variable Declaration */
17 | /******************************************************************************/
18 |
19 | /* i.e. uint32_t <variable_name>; */
20 |
21 | /******************************************************************************/
22 | /* Main Program */
23 | /******************************************************************************/
24 |
25 |
26 | /*
27 | Jarvis Schultz and Jake Ware
28 | 2-3-2010
29 |
30 | Stepper Motor Control Code
31 |
32 | The primary purpose of this code is to drive a stepper motor. The stepper
33 | motor that we are working with is a 5V Bipolar stepper motor from Portescap
34 | (26M048B1B). The drive circuitry is basically one-half of an h-bridge attached
35 | to each of the four leads of the motor. Pins D0-D3 are used to control the
36 | transistors of the h-bridge. The motor driving is done with a timer interrupt
37 | service routine, and a companion code was written in processing that allows
38 | the user to communicate with the PIC and perform various motor control functions.
39 | In processing, the user has the following capabilities:
40 |
41 | 1) The ability to transmit some motor speed to the PIC, and the PIC will
42 | drive the motor at that speed until the user changes it (they
43 | can transmit a positive or a negative speed to change direction).
44 | 2) The ability to transmit a motor speed and number of steps to the PIC,
45 | and the PIC will drive the motor at the desired speed until the desired
46 | number of steps has been reached
47 | 3) The ability to send a command to stop the motor right where it is.
48 | */
49 |
50 |
51 | /** Includes ***************************************************/
52 | //#include "HardwareProfile.h"
53 | #include "stdlib.h"
54 | #include "string.h"
55 | #include "stdio.h"
56 |
57 | /** Global Variables ******************************************/
58 | int mot_speed = 0; // This variable is the current motor speed in steps/ second
59 | int number_steps = 0; // This variable is used for tracking how many steps the motor has taken
60 | int motor_phase = 0; // This variable can be any integer between 0 and 3, and will be used for
61 | // switching the control wires in the correct order
62 | char RS232_Out_Buffer[32]; // This array is used for temporarily storing data before sending
63 | // it to the PC; we will be sending current motor steps to the PC
64 | char RS232_In_Buffer[20] = "zzzzzzzzzzzzzzzzzzzz"; // This is an array that is initialized with
65 | // useless data in it; it is used for temporary
66 | // storage of data brought in from the PC on UART2
67 | int max_steps = 0; // This variable is used for position control, we initialize it at a random value
68 | int i = 1; // This is for marking the position in the RS232_In_Buffer that we are writing into.
69 |
70 |
71 | /** Defines ***************************************************/
72 | //#define phase_a
73 | //#define phase_b
74 | //#define phase_c
75 | //#define phase_d
76 | #define T3options T3_ON | T3_PS_1_256 | T3_SOURCE_INT // These are the setup options for timer three
77 | #define BAUDRATE 19200 //This is the rate that we will communicate over RS232 at
78 |
79 | //Outputs
80 |
81 |
82 | #define SLEEP LATEbits.LATE9 // PIN 19 // SLEEP Driver PUT of Power OFF when is "0": wait 1 ms for wake up
83 | #define STEP LATAbits.LATA10 // PIN 29 RA10 // STEP PIN DRIVER
84 | #define DIR LATAbits.LATA9 // PIN 28 RA9 // DIR PIN DRIVER
85 |
86 | //Communikation Ports
87 | // PIN 52 U1 RX (UC Side) Pin 53 U1 TX (UC SIDE) // Serial Port 1 "ZIGBEE"
88 | // Seriel Port 2 "MP3 PLAYER"
89 |
90 | // Interface Ports
91 | #define ON_OFF LATBbits.LATB7 //RB7 PIN27 // ON/ OFF Button
92 | #define SETUP LATBbits.LATB12 // RB12 PIN 41// SETUP BUTTON
93 | #define RFID LATBbits.LATB6 // RB6 PIN 26// MOTher MODUL RFID ID Button
94 |
95 | #define ON_OFF_LED LATBbits.LATB15 // PIN 44 // ON/OFF Status LED
96 | #define AUTO_MODE_LED LATBbits.LATB14 // PIN 43 // MOTHER MODUL or Automatic Mode Status LED
97 | #define RFID_CHECK_LED LATBbits.LATB13 // PIN 42 //RFID CHECK LED
98 |
99 |
100 | // Sensor Ports PUMP
101 | #define LOW_S LATEbits.LATE19 //RE9 PIN 19// LOW Calibration Switch
102 | #define HIGH_S LATEbits.LATE8 //RE8 PIN 18// High Calibration Switch
103 | #define Int_S_P LATAbits.LATA0 //RA0 PIN 17// Interrupt Switch Pressure Sensor
104 |
105 | // Heart Beat Output
106 | #define HEART LATBbits.LATB3 //RB3 PIN 22 // Output Port of the Heartbeat
107 |
108 |
109 |
110 | // RFID Reader PIns // Soft uArt
111 |
112 | #define SOFT_TX LATBbits.LATB2 //RB2//pin 23 TX
113 | #define SOFT_RX LATBbits.LATB1 //RB1//pin24 RX
114 |
115 |
116 |
117 | /** Function Declarations *************************************/
118 |
119 | // MP3 Player UART
120 |
121 | //Stepp Motor UART
122 | void initUART1(int pbClk); // Function for initializing UART1
123 | int GetSteps(void); // This function returns the current motor position in steps
124 | void SetSteps(int set_steps); // This function manually changes the number stored in the number of steps variable
125 | void SetSpeed(int motor_speed); // This function sets the motor speed at the desired speed and begins driving the motor
126 | void sendDataRS232(void); // Used for sending the current motor position to the PC using UART2
127 |
128 |
129 | /** Main Function: ********************************************/
130 | int main()
131 | {
132 |
133 | char data; // This variable is the current character in the RS232_In_Buffer
134 | char state; // This variable is the variable that determines which of the three cases the user has sent to the PIC
135 | char speedsign; // This variable determines which direction the motor should go
136 | int speed; // This is the speed of the motor that the user has sent to the PIC (in steps/ second)
137 | int steps; // If the user has sent a desired number of steps, this is the variable where it gets stored
138 |
139 | int dir; // This corresponds to the speedsign variable, but speedsign is a char, and this is an int
140 | int PbClk; // Frequency of the peripheral bus clock
141 | unsigned int count = 0; // This variable is for timing the sending of motor counts to PC
142 | int j = 1; // This is used for stepping through the RS232_In_Buffer array
143 | int imark; // This variable is for saving the location of a particular entry in the RS232_In_Buffer
144 | int n;
145 | // Let's set the integer pbClk to be the value of the frequency
146 | // of the peripheral bus clock
147 | PbClk = SYSTEMConfigPerformance(SYS_FREQ);
148 |
149 | // Let's set the pins D0-D3 to be low digital outputs:
150 | LATD |= 0b0000000000000000;
151 | TRISD &= 0b1111100111110000;
152 |
153 | LATA |= 0b0000000000000000;
154 | TRISA &= 0b1111111111110000;
155 |
156 | LATB |= 0b0000000000000000;
157 | TRISB &= 0b0000111111110100;
158 |
159 | LATE |= 0b0000000000000000;
160 | TRISE &= 0b1111110111110000;
161 |
162 | ON_OFF_LED = 1;
163 | AUTO_MODE_LED =1;
164 | RFID_CHECK_LED =1;
165 |
166 |
167 |
168 | // Initialize the LED's:
169 | //mInitAllLEDs();
170 |
171 | // Allow vector interrupts
172 | INTEnableSystemMultiVectoredInt();
173 |
174 | // Initialize UART Communication
175 |
176 | initUART1(PbClk);
177 |
178 |
179 | //putsUART2("Program Started\r\n");
180 |
181 | ON_OFF_LED = 0;
182 | AUTO_MODE_LED =0;
183 | RFID_CHECK_LED =0;
184 |
185 |
186 |
187 |
188 |
189 |
190 |
191 |
192 | while(1)
193 | {
194 |
195 |
196 | putsUART1("Run");
197 |
198 | ON_OFF_LED = 0;
199 | AUTO_MODE_LED =0;
200 | RFID_CHECK_LED =0;
201 |
202 |
203 | // This checks to see how many times we have gone through this while loop,
204 | // if it is a multiple of 1000, we transmit the current step count
205 |
206 | ON_OFF_LED = 1;
207 | AUTO_MODE_LED =0;
208 | RFID_CHECK_LED =1;
209 | }
210 |
211 | }
212 |
213 |
214 |
215 |
216 |
217 |
218 |
219 | /** User Called Functions ************************/
220 | // Following function returns the number of
221 | // steps that the motor has taken:
222 | int GetSteps(void)
223 | {
224 | return number_steps;
225 | }
226 |
227 |
228 | // Next function allows to user to re-set a "home" position by
229 | // manually changing the number of steps:
230 | void SetSteps(int set_steps)
231 | {
232 | INTEnable(INT_T3, 0);
233 | number_steps = set_steps;
234 | INTEnable(INT_T3, 1);
235 | }
236 |
237 |
238 | // This function allows the user to specify the desired motor speed:
239 | void SetSpeed(int motor_speed) // motor speed in steps/s
240 | {
241 | if (motor_speed == 0)
242 | {
243 | // Turn off timer if motor is stopped:
244 | T3CONbits.ON = 0;
245 | // Also, let's turn off all of the phases:
246 | //phase_a = 0;
247 | //phase_b = 0;
248 | //phase_c = 0;
249 | //phase_d = 0;
250 | STEP = 0;
251 | }
252 | else
253 | {
254 | mot_speed = motor_speed;
255 | int Per;
256 | Per = (80000000/abs(mot_speed))/256-1; // set the value in the period register
257 | OpenTimer3(T3options, Per);
258 | mT3SetIntPriority( 7); // set Timer3 Interrupt Priority
259 | mT3ClearIntFlag(); // clear interrupt flag
260 | mT3IntEnable( 1); // enable timer3 interrupts
261 | }
262 | }
263 |
264 |
265 |
266 | // This function is used for sending the current number of steps
267 | // that the motor has taken back to the PC:
268 | void sendDataRS232()
269 | {
270 | sprintf(RS232_Out_Buffer,"%d\n",number_steps);
271 |
272 | putsUART1(RS232_Out_Buffer);
273 | }
274 |
275 |
276 |
277 | void initUART1(int pbClk)
278 | {
279 | // define setup Configuration 1 for OpenUARTx
280 | // Module Enable
281 | // Work in IDLE mode
282 | // Communication through usual pins
283 | // Disable wake-up
284 | // Loop back disabled
285 | // Input to Capture module from ICx pin
286 | // no parity 8 bit
287 | // 1 stop bit
288 | // IRDA encoder and decoder disabled
289 | // CTS and RTS pins are disabled
290 | // UxRX idle state is '1'
291 | // 16x baud clock - normal speed
292 | #define config1 UART_EN | UART_IDLE_CON | UART_RX_TX | UART_DIS_WAKE | UART_DIS_LOOPBACK | UART_DIS_ABAUD | UART_NO_PAR_8BIT | UART_1STOPBIT | UART_IRDA_DIS | UART_DIS_BCLK_CTS_RTS| UART_NORMAL_RX | UART_BRGH_SIXTEEN
293 |
294 | // define setup Configuration 2 for OpenUARTx
295 | // IrDA encoded UxTX idle state is '0'
296 | // Enable UxRX pin
297 | // Enable UxTX pin
298 | // Interrupt on transfer of every character to TSR
299 | // Interrupt on every char received
300 | // Disable 9-bit address detect
301 | // Rx Buffer Over run status bit clear
302 | #define config2 UART_TX_PIN_LOW | UART_RX_ENABLE | UART_TX_ENABLE | UART_INT_TX | UART_INT_RX_CHAR | UART_ADR_DETECT_DIS | UART_RX_OVERRUN_CLEAR
303 |
304 | // Open UART2 with config1 and config2
305 | OpenUART1( config1, config2, pbClk/16/BAUDRATE-1); // calculate actual BAUD generate value.
306 |
307 |
308 | }
