1 | #include <stdio.h>
2 | #include <stdlib.h>
3 | #include <pic16f887.h>
4 | #include <xc.h>
5 |
6 | #define _XTAL_FREQ 4000000
7 |
8 | // CONFIG1
9 | #pragma config FOSC = INTRC_NOCLKOUT// Oscillator Selection bits (INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN)
10 | #pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
11 | #pragma config PWRTE = ON // Power-up Timer Enable bit (PWRT enabled)
12 | #pragma config MCLRE = ON // RE3/MCLR pin function select bit (RE3/MCLR pin function is MCLR)
13 | #pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
14 | #pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)
15 | #pragma config BOREN = ON // Brown Out Reset Selection bits (BOR enabled)
16 | #pragma config IESO = ON // Internal External Switchover bit (Internal/External Switchover mode is enabled)
17 | #pragma config FCMEN = ON // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is enabled)
18 | #pragma config LVP = OFF // Low Voltage Programming Enable bit (RB3 pin has digital I/O, HV on MCLR must be used for programming)
19 |
20 | // CONFIG2
21 | #pragma config BOR4V = BOR40V // Brown-out Reset Selection bit (Brown-out Reset set to 4.0V)
22 | #pragma config WRT = OFF // Flash Program Memory Self Write Enable bits (Write protection off)
23 |
24 | #define D7 RD3
25 | #define D6 RD2
26 | #define D5 RD1
27 | #define D4 RD0
28 |
29 | #define RS RC4
30 | #define EN RC6
31 |
32 | #define datenport PORTD
33 | #define RS RC4
34 | #define EN RC6
35 |
36 | int Durchlauf = 0;
37 |
38 | void STROBE(void)
39 | {
40 | EN = 1;
41 | __delay_us(2);
42 | EN = 0;
43 | }
44 |
45 | void main(void)
46 | {
47 | __delay_ms(20);
48 | TRISC = 0;
49 | TRISD = 0b00000000;
50 | EN = 0;
51 | RS = 0;
52 | datenport = 0;
53 |
54 | while(1)
55 | {
56 | while(Durchlauf == 0)
57 | {
58 |
59 | RS = 0; // Steuerbefehl
60 | __delay_us(50); // Wartezeit
61 | datenport = 0b00110000; // Interface auf 8 Bit setzen
62 | STROBE(); // Datenport einlesen
63 |
64 | __delay_ms(5); // Wartezeit
65 |
66 | RS = 0; // Steuerbefehl
67 | __delay_us(50); // Wartezeit
68 | datenport = 0b00110000; // Interface auf 8 Bit setzen
69 | STROBE(); // Datenport einlesen
70 |
71 | __delay_us(150); // Wartezeit
72 |
73 | RS = 0; // Steuerbefehl
74 | __delay_us(50); // Wartezeit
75 | datenport = 0b00110000; // Interface auf 8 Bit setzen
76 | STROBE(); // Datenport einlesen
77 |
78 | RS = 0; // Steuerbefehl
79 | __delay_us(50); // Wartezeit
80 | datenport = 0b00100000; // Interface auf 4 Bit setzen
81 | STROBE(); // Datenport einlesen
82 |
83 | RS = 0; // Steuerbefehl
84 | __delay_us(50); // Wartezeit
85 | datenport = 0b00100000; // 1. 2-Zeilen und 5x8 Punktmatrix
86 | STROBE(); // Datenport einlesen
87 |
88 | RS = 0; // Steuerbefehl
89 | __delay_us(50); // Wartezeit
90 | datenport = 0b10000000; // 2. 2-Zeilen und 5x8 Punktmatrix
91 | STROBE(); // Datenport einlesen
92 |
93 | RS = 0; // Steuerbefehl
94 | __delay_us(50); // Wartezeit
95 | datenport = 0b00000000; // 1. Display ausschalten
96 | STROBE(); // Datenport einlesen
97 |
98 | RS = 0; // Steuerbefehl
99 | __delay_us(50); // Wartezeit
100 | datenport = 0b10000000; // 2. Display ausschalten
101 | STROBE(); // Datenport einlesen
102 |
103 | RS = 0; // Steuerbefehl
104 | __delay_us(50); // Wartezeit
105 | datenport = 0b00000000; // 1. Textpuffer löschen
106 | STROBE(); // Datenport einlesen
107 |
108 | RS = 0; // Steuerbefehl
109 | __delay_us(50); // Wartezeit
110 | datenport = 0b00010000; // 2. Textpuffer löschen
111 | STROBE(); // Datenport einlesen
112 |
113 | RS = 0; // Steuerbefehl
114 | __delay_us(50); // Wartezeit
115 | datenport = 0b00000000; // 1.Cursorlaufrichtung rechts, kein Shift
116 | STROBE(); // Datenport einlesen
117 |
118 | RS = 0; // Steuerbefehl
119 | __delay_us(50); // Wartezeit
120 | datenport = 0b01100000; // 1.Cursorlaufrichtung rechts, kein Shift
121 | STROBE(); // Datenport einlesen
122 |
123 | RS = 0; // Steuerbefehl
124 | __delay_us(50); // Wartezeit
125 | datenport = 0b00000000; // 1. Cursor auf Startposition
126 | STROBE(); // Datenport einlesen
127 |
128 | RS = 0; // Steuerbefehl
129 | __delay_us(50); // Wartezeit
130 | datenport = 0b00100000; // 1. Cursor auf Startposition
131 | STROBE(); // Datenport einlesen
132 |
133 | RS = 0; // Steuerbefehl
134 | __delay_us(50); // Wartezeit
135 | datenport = 0b00000000; // 1.Display einschalten
136 | STROBE(); // Datenport einlesen
137 |
138 | RS = 0; // Steuerbefehl
139 | __delay_us(50); // Wartezeit
140 | datenport = 0b11110000; // 2.Display einschalten
141 | STROBE(); // Datenport einlesen
142 |
143 | Durchlauf = 1;
144 | }
145 | }
146 | }
