1 |
2 |
3 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
4 |
5 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
6 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
7 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
8 |
9 | uint32_t getValueADC1(void){
10 | /* convert the ADC value (from 0 to 0xFFF) to a voltage value (from 0V to 3.3V)*/
11 | return ADC_GetConversionValue(ADC1);
12 | }
13 | uint32_t getValueADC2(void){
14 | /* convert the ADC value (from 0 to 0xFFF) to a voltage value (from 0V to 3.3V)*/
15 | return ADC_GetConversionValue(ADC2);
16 | }
17 | uint32_t getValueADC3(void){
18 | /* convert the ADC value (from 0 to 0xFFF) to a voltage value (from 0V to 3.3V)*/
19 | return ADC_GetConversionValue(ADC3);
20 | }
21 |
22 | void ADC123_Config(void){
23 |
24 | /* Configure ADC1 Channel11 pin as analog input */
25 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
26 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
27 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
28 | GPIO_Init(GPIOC, &GPIO_InitStructure);
29 |
30 | /* Configure ADC2 Channel12 pin as analog input */
31 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
32 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
33 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
34 | GPIO_Init(GPIOC, &GPIO_InitStructure);
35 |
36 | /* Configure ADC3 Channel13 pin as analog input */
37 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
38 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
39 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
40 | GPIO_Init(GPIOC, &GPIO_InitStructure);
41 |
42 | /* ADC Common Init */
43 | ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
44 | ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div6;
45 | ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
46 | ADC_CommonInit(&ADC_CommonInitStructure);
47 |
48 | /* ADC Init */
49 | ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
50 | ADC_InitStructure.ADC_ScanConvMode = DISABLE;
51 | ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
52 | ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
53 | ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
54 | ADC_InitStructure.ADC_NbrOfConversion = 1;
55 |
56 | ADC_Init(ADC1, &ADC_InitStructure);
57 | ADC_Init(ADC2, &ADC_InitStructure);
58 | ADC_Init(ADC3, &ADC_InitStructure);
59 |
60 | /* ADC regular channel configuration */
61 | ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_3Cycles);
62 | ADC_RegularChannelConfig(ADC2, ADC_Channel_12, 1, ADC_SampleTime_3Cycles);
63 | ADC_RegularChannelConfig(ADC3, ADC_Channel_13, 1, ADC_SampleTime_3Cycles);
64 | /* Enable ADC */
65 | ADC_Cmd(ADC1, ENABLE);
66 | ADC_Cmd(ADC2, ENABLE);
67 | ADC_Cmd(ADC3, ENABLE);
68 |
69 | /* Start ADC Software Conversion */
70 | ADC_SoftwareStartConv(ADC1);
71 | ADC_SoftwareStartConv(ADC2);
72 | ADC_SoftwareStartConv(ADC3);
73 |
74 | }
