Hallo, ich bin blutiger Anfänger was Mikrocontroller anbelangt, daher meine Frage zur "Output Control". Ich verstehe nicht ganz, wofür ich PIO_SODR bzw. PIO_CODR brauche. Im Datenblatt ist es erklärt, verstehe es aber nicht, da ich keinen Bezug dazu habe: ----------------------------------------------------------------------- When the I/0 line is assigned to a peripheral function, i.e. the corresponding bit in PIO_PSR is at 0, the drive of the I/O line is controlled by the peripheral. Peripheral A or B or C or D depending on the value in PIO_ABCDSR1 and PIO_ABCDSR2 (ABCD Select Registers determineswhether the pin is driven or not. When the I/O line is controlled by the PIO controller, the pin can be configured to be driven. This is done by writing PIO_OER (Output Enable Register) and PIO_ODR (Output Disable Register). The results of these write operations are detected in PIO_OSR (Output Status Register). When a bit in this register is at 0, the corresponding I/O line is used as an input only. When the bit is at 1, the corresponding I/O line is driven by the PIO controller. The level driven on an I/O line can be determined by writing in PIO_SODR (Set Output Data Register) and PIO_CODR (Clear Output Data Register). These write operations respectively set and clear PIO_ODSR (Output Data Status Register), which represents the data driven on the I/O lines. Writing in PIO_OER and PIO_ODR manages PIO_OSR whether the pin is configured to be controlled by the PIO controller or assigned to a peripheral function. This enables configuration of the I/O line prior to setting it to be managed by the PIO Controller. Similarly, writing in PIO_SODR and PIO_CODR effects PIO_ODSR. This is important as it defines the first level driven on the I/O line. -------------------------------------------------------------------- Danke x8x8x
Marco B. schrieb: > Ich verstehe nicht ganz, wofür ich PIO_SODR bzw. PIO_CODR brauche. Um einzelne Portpins (effektiv) setzen oder löschen zu können, ohne dass man zuvor das ganze Register manuell zurücklesen müsste. Ist also in etwa das, was beim AVR die Befehle SBI und CBI machen.
