Hallo, eigentlich sagt der Titel schon alles, wo ist die Masse in LTSpice für den Mac? Bitte um einen Menüpfad dorthin. Danke schonmal! Jan
Verschoben durch Admin
Hallo Jan, du hast zwei Möglichkeiten. 1. F4 2. Rechte Maustaste -> Draft -> Net Name Diese kleine Hilfe habe ich mal für die LTspice Yahoo group geschrieben: Special hints for MAC-LTspice MAC-LTspice doesn't have a menu-bar with all these commands. Please use the function keys. It will need a little bit exercise until you can quickly work with this function-key method. F2 Get components F3 Draw wires F4 Label net F5 Delete F6 Copy F7 Move F8 Drag F9 Undo Shift F9 Redo Spacebar Zoom to full extent s Enter Spice Directive t Enter comment Draw a wire in the direction of 45 degree: F3 Now hold the Shift-key while drawing the wire with any angle .lib name or .lib ./name Normally .lib filename works. I remember one case when I needed .lib ./filename Dialog windows for the analysis .TRAN, AC, .NOISE, .DC, .TF, .OP Press the key s to get the dialog window for SPICE-lines. Now "right mouse click" in this dialog window. Follow "Help me edit -> op Analysis command". Polarized electrolytic cap? F2 polcap There are even more nice symbols in [Misc], e. g. a European resistor symbol. F2 "Misc" -> European Resistor My personal experience. MAC-LTspice is 64bit code and runs at least as fast as the WIN version. The only drawback is the slower speed when you zoom-in or zoom-out. Mike told me that he can't improve this the next few months. I missed the toolbar at the beginning. After I exercised the Fx function keys, I am quick with this Fx method too.
Hall Jan, 3 Möglichkeiten, wahrscheinlich wolltest du 2. 1. s .tran 10m 2. s Rechte Maustaste -> Help me edit -> Analysis Cmd 3. Rechte Maustaste - > Draft -> Spice Directive Dann weiter wie oben
entschuldigung, dass ich nochmal fragen muss. weis einer, wie man die simulation im Frequenzberich startet?
Dafür musst du ein entsprechendes "Analysis Cmd" wãhlen und in den Schaltplan einfügen. Es ist das .AC Kommando. Beispiel: Sweep von 1Hz bis 1Mega-Hertz mit 100 Punkten je Dekade .ac dec 100 1 1meg Nachtrag: Zum Starten der Simulation auf den "running man" klicken. Es gibt .TRAN .AC .DC .NOISE .TEMP .TF Groß- oder Kleinschreibung ist egal in LTspice.
> "G" wie Ground geht nicht?
Oh ich bin überrascht. g geht doch.
Danke!
LT Slice ist eines der wenigen programme, wo mir die windows version besser gefällt...
besser gefällt...
Das originale LTspice für Windows läuft auch auf dem MAC OS X mit
Wine/Winery. Selbst das update mit "Tools->Sync Release" klappt damit.
Helmut S. schrieb: >> LT Slice ist eines der wenigen programme, wo mir die windows version > besser gefällt... > > Das originale LTspice für Windows läuft auch auf dem MAC OS X mit > Wine/Winery. Selbst das update mit "Tools->Sync Release" klappt damit. Ja da geht aber superviel Leistung verloren. Es werden nichtmehr alle Kerne verwendt, usw.
Hab es gerade getestet.
Bei mir nutzt auch das LTspice Winery alle 4 Prozessoren auf dem MacBook
Air. Die Benchmark-Schaltung "bjt.cir" läuft damit sogar 10% schneller
als mit MAC-LTspice.
Andere Schaltungen laufen dagegen eher etwas schneller mit MAC-LTspice.
Beachte, dass zumindest im MacBbook Air die Anzahl der verwendeten
Prozessoren von der Lage und Größe des Programmfensters abhängt. Um den
Effekt auszuschalten am einfachsten auf Vollbild gehen mit der Anwendung
(grüner Knopf oben links).
Jan R. schrieb: > Helmut S. schrieb: > >> (grüner Knopf oben links). > > das ist Sarkasmus oder? Das war zugegebener Maßen etwas übertrieben. Ich wollte nur deutlich machen was ich mit maximalem Fenster meinte. ich weiß nicht ob es da noch einen besonderen Modus gibt um den Platz der Menüleiste unten auch noch für das Programmfenster zu bekommen. Allerdings das mit der Prozessorauslastung abhängig von der Größe des Programmfensters bzw. dessen Position das war ernst gemeint.
Helmut S. schrieb: > > Allerdings das mit der Prozessorauslastung abhängig von der Größe des > Programmfensters bzw. dessen Position das war ernst gemeint. Warum ist das so ??
Jan R. schrieb: > Helmut S. schrieb: >> >> Allerdings das mit der Prozessorauslastung abhängig von der Größe des >> Programmfensters bzw. dessen Position das war ernst gemeint. > > Warum ist das so? Vielleicht um die Rechenleistung besser auf alle Anwendungen/Fenster zu verteilen. Du könntest ja mal bei Apple nachfragen? :-)
