1 | */ RINGPUFFER: circbuf.h */
2 | #ifndef CIRCBUF_H_
3 | #define CIRCBUF_H_
4 |
5 | #include <stdbool.h>
6 | #include <avr/io.h>
7 | #include <stdlib.h>
8 | #include <avr/interrupt.h>
9 |
10 |
11 | #define buffer_size 16
12 |
13 | struct circ_buffer {
14 | uint8_t data[buffer_size];
15 | uint8_t read_ptr; // points to last input data
16 | uint8_t write_ptr; // always points to empty field
17 | };
18 |
19 | void buffer_init (struct circ_buffer *buf);
20 | void buffer_write(struct circ_buffer *buf, uint8_t byte);
21 | uint8_t buffer_read(struct circ_buffer *buf);
22 | uint8_t buffer_is_full (struct circ_buffer *buf);
23 | uint8_t buffer_is_empty (struct circ_buffer *buf);
24 |
25 | #endif /*CIRCBUF_H_*/
26 | /* END circbuf.h */
27 |
28 |
29 | /* RINGPUFFER FUNCTIONS circbuf.c*/
30 | #include "circbuf.h"
31 |
32 | void buffer_init (struct circ_buffer *buf) // Initialization of circular buffer values
33 | {
34 | buf->read_ptr=0;
35 | buf->write_ptr=0;
36 | }
37 |
38 | void buffer_write(struct circ_buffer *buf, uint8_t byte) // Write byte into buffer, increment fillcounter and write pointer
39 | {
40 | cli();
41 | buf->data[buf->write_ptr] = byte;
42 |
43 | if (buf->write_ptr >= buffer_size-1){
44 | buf->write_ptr = 0;
45 | }
46 | else{
47 | buf->write_ptr = buf->write_ptr + 1;
48 | }
49 | sei();
50 | }
51 |
52 | uint8_t buffer_read(struct circ_buffer *buf) // Read byte out of buffer, decrement fillcounter, increment read ptr
53 | {
54 | cli();
55 | uint8_t returnval =0;
56 |
57 | if (buf->read_ptr == buf->write_ptr){
58 | sei();
59 | return 0;
60 | }
61 | else
62 | {
63 | returnval= buf->data[buf->read_ptr];
64 |
65 | if (buf->read_ptr >= buffer_size-1){
66 | buf->read_ptr = 0;
67 | }
68 | else{
69 | buf->read_ptr = buf->read_ptr + 1;
70 | }
71 | sei();
72 | return returnval;
73 | }
74 |
75 | }
76 |
77 | uint8_t buffer_is_full (struct circ_buffer *buf)
78 | {
79 | if (buf->write_ptr + 1 == buf->read_ptr || buf->read_ptr == 0 && buf->write_ptr + 1 == buffer_size)
80 | return 1;
81 | else return 0;
82 | }
83 |
84 | uint8_t buffer_is_empty (struct circ_buffer *buf)
85 | {
86 | if (buf->read_ptr == buf->write_ptr) return 1;
87 | else return 0;
88 | }
89 |
90 | /* END RINGPUFFER FUNCTIONS circbuf.c */
91 |
92 |
93 |
94 | /* UART_functions.h */
95 |
96 | #ifndef _M_UART_functions_h_
97 | #define _M_UART_functions_h_
98 |
99 | #define F_CPU 20E6 //Systemtakt in Hz
100 | #include <util/delay.h>
101 |
102 | #include "circbuf.h"
103 |
104 | // FUNCTIONS
105 | void UART_Init();
106 | uint8_t uart_ReceiveByte( struct circ_buffer *buf );
107 | void uart_TransmitByte( struct circ_buffer *buf, uint8_t data );
108 |
109 | #endif /*_M_UART_functions_h_*/
110 |
111 | /* END UART_functions.h */
112 |
113 |
114 | /* UART_functions.c */
115 |
116 | #include <avr/io.h>
117 | #include <avr/interrupt.h>
118 | #include <stdlib.h>
119 |
120 | #include "UART_functions.h"
121 | #include <util/delay.h>
122 |
123 |
124 | void UART_Init()
125 | {
126 | // baud Calculation: baud = (fosc/ 16*Baudrate)-0.5
127 | // baud = (20 MHz / 16*9600)-0.5 = 129.708 --> = baud = 130
128 | unsigned int baud = 130;
129 |
130 | //* Set baud rate */
131 | UBRR0H = (unsigned char)(baud>>8);
132 | UBRR0L = (unsigned char)baud;
133 | /* Enable receiver and transmitter, Set Interrupts: RXCIE - RX-Complete */
134 | UCSR0B = (1<<RXEN0)|(1<<TXEN0)|(1<<RXCIE0);
135 | /* Set frame format: 8data, 2stop bit */
136 | UCSR0C = (1<<USBS0)|(3<<UCSZ00);
137 | }
138 |
139 | uint8_t uart_ReceiveByte( struct circ_buffer *buf )
140 | {
141 | while ( buffer_is_empty(buf) ); /* wait for incoming data */
142 | return buffer_read(buf); /* return data */
143 | }
144 |
145 |
146 | void uart_TransmitByte(struct circ_buffer *buf, uint8_t data )
147 | {
148 | while ( buffer_is_full(buf) );
149 | buffer_write(buf,data); /* store data in buffer */
150 |
151 | UCSR0B |= (1<<UDRIE0); // Enable UDRIE- UART Data Register empty Interrupt - UDRE-ISR is going to put data in UDR
152 | }
153 |
154 | /* END UART_functions.c */
155 |
156 |
157 | /* MAIN.c */
158 |
159 | #include <avr/io.h>
160 | #include <avr/interrupt.h>
161 | #include <stdlib.h>
162 | #include "stdbool.h"
163 | #include <string.h>
164 |
165 | #define F_CPU 20E6 //Systemtakt in Hz
166 |
167 | #include "UART_functions.h"
168 | #include "circbuf.h"
169 | #include <util/delay.h>
170 |
171 | // Global VARIABLES
172 | unsigned char byte_buffer;
173 | struct circ_buffer uart_rx_buffer; // Receive-Circular-Buffer
174 | struct circ_buffer uart_tx_buffer; // Send-Circular-Buffer
175 |
176 |
177 | // UART RX-Complete interrupt:
178 | // Receiving data + buffering (saving)
179 | ISR(USART0_RX_vect)
180 | {
181 | unsigned char data;
182 | data = UDR0;
183 | buffer_write(&uart_rx_buffer, data);
184 | }
185 |
186 | // UART Data register empty interrupt:
187 | // loading new data into UART sending register
188 | ISR(USART0_UDRE_vect)
189 | {
190 | if (!buffer_is_empty(&uart_tx_buffer)) // Is buffer filled?
191 | {
192 | UDR0 = buffer_read(&uart_tx_buffer);
193 | }
194 | else
195 | {
196 | UCSR0B &= ~(1<<UDRIE0); // Disable UDRIE- UART Data Register empty Interrupt
197 | }
198 | }
199 |
200 | int main(void)
201 | {
202 | /* Buffer Initialization */
203 | buffer_init(&uart_rx_buffer);
204 | buffer_init(&uart_tx_buffer);
205 |
206 | /* Variables */
207 | char controlbyte;
208 | uint8_t sendbuffer;
209 | uint32_t adcrec;
210 |
211 | /*********************** Initialization ***********************/
212 | //Port Directions
213 |
214 | DDRA= 0b11011011;
215 | DDRB= 0b10100110;
216 | DDRC= 0b01010001; // SPI Slave select, LEDs
217 | DDRD= 0b00001010; // UART
218 |
219 | UART_Init(); // UART initialization
220 | sei(); // Global Interrupt enable
221 |
222 | /*********** MAIN LOOP **************/
223 | while(1)
224 | {
225 |
226 | if (!buffer_is_empty(&uart_rx_buffer)) // Received Commands?
227 | {
228 | controlbyte = uart_ReceiveByte(&uart_rx_buffer);
229 |
230 | switch (controlbyte)
231 | {
232 | case 0xAA: {
233 | sendbuffer =00;
234 | uart_TransmitByte(&uart_tx_buffer, sendbuffer);
235 |
236 | adcrec = 0xFFABCDEF;
237 |
238 | sendbuffer =(adcrec >>24);
239 | uart_TransmitByte(&uart_tx_buffer, sendbuffer);
240 | sendbuffer =(adcrec >>16);
241 | uart_TransmitByte(&uart_tx_buffer, sendbuffer);
242 | sendbuffer =(adcrec >>8);
243 | uart_TransmitByte(&uart_tx_buffer, sendbuffer);
244 | sendbuffer =adcrec;
245 | uart_TransmitByte(&uart_tx_buffer, sendbuffer);
246 | sendbuffer =00;
247 | uart_TransmitByte(&uart_tx_buffer, sendbuffer);
248 | break;
249 | }
250 | case 0xBB: {
251 | break;
252 | }
253 | case 0xCC:{
254 | break;
255 | }
256 | }
257 | }
258 | }
259 | }
260 |
261 | /* END MAIN.C */
