1 | #define LCD_CLEAR 0x01 // clear display 0b 0000 0001
2 | #define LCD_HOME 0x02 // cursor home 0b 0000 0010
3 | #define LCD_ON 0x0C // cursor invisible 0b 0000 1100
4 | #define LCD_OFF 0x08 // display off 0b 0000 1000
5 | #define POS_01 0x80 // line 1 - column 0 0b 1000 0000
6 | #define POS_02 0xC0 // line 2 - column 0 0b 1100 0000
7 |
8 | #define LCDPORT PORTC // define port with LCD attached
9 | #define LCDDDR DDRC // and its data direction
10 |
11 | // define pins of LCD port
12 | #define LCD_PIN_RS 2
13 | #define LCD_PIN_E 3
14 | #define LCD_PIN_D4 4
15 | #define LCD_PIN_D5 5
16 | #define LCD_PIN_D6 6
17 | #define LCD_PIN_D7 7
18 |
19 | // DEFINITIONS
20 | #define sbi(PORT, bit) (PORT|=(1<<bit)) // set bit
21 | #define cbi(PORT, bit) (PORT&=~(1<<bit)) // claear bit
22 | #define tbi(PORT, bit) (PORT^=(1<<bit)) // toggle bit
23 |
24 | #define COMMAND 0
25 | #define DATA 1
26 |
27 | // Function: Toggle enable pin
28 | void toggle_enable_pin(void)
29 | {
30 | sbi(LCDPORT, LCD_PIN_E);
31 | cbi(LCDPORT, LCD_PIN_E);
32 | }
33 |
34 | // Send Byte to LCD Controller
35 | void lcd_send(unsigned char type, unsigned char c)
36 | {
37 | unsigned char sic_c; // Backup for c
38 | // send high nibble
39 | sic_c = c; // save original c
40 | sic_c &= ~0x0f; // set bit 0-3 == 0
41 | if (type==DATA)
42 | sic_c |= (1<<LCD_PIN_RS); // Data: RS = 1
43 | LCDPORT = sic_c; // send high nibble
44 | toggle_enable_pin();
45 | // send low nibble
46 | sic_c = c; // save original c
47 | sic_c = sic_c<<4; // exchange nibbles
48 | sic_c &= ~0x0f; // set bit 0-3 == 0
49 | if (type==DATA)
50 | sic_c |= (1<<LCD_PIN_RS); // Data: RS = 1
51 | LCDPORT = sic_c; // send low nibble
52 | toggle_enable_pin();
53 | _delay_ms(5); // Wait for LCD controller
54 | }
55 |
56 | // set cursor to line x and column y
57 | void lcd_set_cursor(uint8_t x, uint8_t y)
58 | {
59 | uint8_t i;
60 |
61 | switch (x)
62 | {
63 | case 1: i=0x80+0x00+y; break; // 1. line
64 | case 2: i=0x80+0x40+y; break; // 2. line
65 | default: return; // invalid line
66 | }
67 | lcd_send(COMMAND, i);
68 | }
69 |
70 | // Display String on LCD
71 | void lcd_write(char *t)
72 | {
73 | unsigned char i;
74 | for (i=0;i<255;i++)
75 | {
76 | if (t[i]==0) // End of String -> EXIT
77 | return;
78 | else
79 | lcd_send(DATA, t[i]);
80 | }
81 | }
82 |
83 |
84 | // initializing LCD Controller see data sheet for details
85 | void lcd_init()
86 | {
87 | // Set LCD port to Output
88 | LCDPORT = 0x00;
89 | LCDDDR = 0xFF;
90 |
91 | _delay_ms(50); // wait for LCD
92 |
93 | // 4-bit Modus config
94 | sbi(LCDPORT, LCD_PIN_D5);
95 | cbi(LCDPORT, LCD_PIN_D4);
96 |
97 | // 4-Bit mode start
98 | sbi(LCDPORT, LCD_PIN_E);
99 | cbi(LCDPORT, LCD_PIN_E);
100 | _delay_ms(5);
101 |
102 | // 2 Lines, 4-Bit Mode
103 | lcd_send(COMMAND, 0x28);
104 |
105 | lcd_send(COMMAND, LCD_OFF);
106 | lcd_send(COMMAND, LCD_CLEAR);
107 |
108 | lcd_send(COMMAND, 0x06);
109 | lcd_send(COMMAND, LCD_ON);
110 | }
