Hi, Is the ST22 GPS receiver still available? Is so where can I source the ST22 GPS module? Regards Peter
Take a look at this thread: Beitrag "[V] Mini GPS Module - SkyTraq Venus 6 (22x22x8mm)" There you can find the sellers email address.
Hi, There are a number of options for microcontrollers on the RS site. Is this the correct item? http://uk.rs-online.com/web/p/microcontrollers/6963506/ RS Stock No.696-3506 Brand Atmel Mfr. Part No.ATMEGA88P-20AURoHS Status Compliant Cheers Peter
Hi, Have built my gps board, just waiting for the gps module, from usa. Connected li-ion battery (3.7v) plugged into usb. The red LED charge does not come on. Have checked board for solder bridges etc... Any ideas?? cheers Peter
Hi, From here http://www.mikrocontroller.net/articles/GPS_Logger_Mini With USB connected get 4.6 volts at battery connection, (with no battery)
Hi, Solved... The LED was wrong way round, as I did not understand the markings, on the device , Lesson learned. Thanks anyway Peter
Hi , Help! Trying to use Rawread.py (http://www.mikrocontroller.net/articles/GPS_Logger_Mini) Rawread v2, Python 2.7.6 OSX 10.9.1 User = Administrator 128Mb SD card unlocked -------------------------- Results Last login: Fri Feb 21 09:17:22 on ttys000 jrc-imac-2:~ prc$ ./rawread.py -c -f > Please eject the device if inserted and press enter... ERROR: Available devices could not be determined. Root permissions may be necessary to perform this task. No action will be performed. How else can I format the card for NoFs ?? Cheers Peter
