1 | /* beep - just what it sounds like, makes the console beep - but with
2 | * precision control. See the man page for details.
3 | *
4 | * Try beep -h for command line args
5 | *
6 | * This code is copyright (C) Johnathan Nightingale, 2000.
7 | *
8 | * This code may distributed only under the terms of the GNU Public License
9 | * which can be found at http://www.gnu.org/copyleft or in the file COPYING
10 | * supplied with this code.
11 | *
12 | * This code is not distributed with warranties of any kind, including implied
13 | * warranties of merchantability or fitness for a particular use or ability to
14 | * breed pandas in captivity, it just can't be done.
15 | *
16 | * Bug me, I like it: http://johnath.com/ or johnath@johnath.com
17 | */
18 |
19 | #include <fcntl.h>
20 | #include <getopt.h>
21 | #include <signal.h>
22 | #include <stdio.h>
23 | #include <stdlib.h>
24 | #include <string.h>
25 | #include <unistd.h>
26 | #include <sys/ioctl.h>
27 | #include <sys/types.h>
28 | #include <linux/kd.h>
29 |
30 | /* I don't know where this number comes from, I admit that freely. A
31 | wonderful human named Raine M. Ekman used it in a program that played
32 | a tune at the console, and apparently, it's how the kernel likes its
33 | sound requests to be phrased. If you see Raine, thank him for me.
34 |
35 | June 28, email from Peter Tirsek (peter at tirsek dot com):
36 |
37 | This number represents the fixed frequency of the original PC XT's
38 | timer chip (the 8254 AFAIR), which is approximately 1.193 MHz. This
39 | number is divided with the desired frequency to obtain a counter value,
40 | that is subsequently fed into the timer chip, tied to the PC speaker.
41 | The chip decreases this counter at every tick (1.193 MHz) and when it
42 | reaches zero, it toggles the state of the speaker (on/off, or in/out),
43 | resets the counter to the original value, and starts over. The end
44 | result of this is a tone at approximately the desired frequency. :)
45 | */
46 | #ifndef CLOCK_TICK_RATE
47 | #define CLOCK_TICK_RATE 1193180
48 | #endif
49 |
50 | #define VERSION_STRING "beep-1.2.2"
51 | char *copyright =
52 | "Copyright (C) Johnathan Nightingale, 2002. "
53 | "Use and Distribution subject to GPL. "
54 | "For information: http://www.gnu.org/copyleft/.";
55 |
56 | /* Meaningful Defaults */
57 | #define DEFAULT_FREQ 440.0 /* Middle A */
58 | #define DEFAULT_LENGTH 200 /* milliseconds */
59 | #define DEFAULT_REPS 1
60 | #define DEFAULT_DELAY 100 /* milliseconds */
61 | #define DEFAULT_END_DELAY NO_END_DELAY
62 | #define DEFAULT_STDIN_BEEP NO_STDIN_BEEP
63 |
64 | /* Other Constants */
65 | #define NO_END_DELAY 0
66 | #define YES_END_DELAY 1
67 |
68 | #define NO_STDIN_BEEP 0
69 | #define LINE_STDIN_BEEP 1
70 | #define CHAR_STDIN_BEEP 2
71 |
72 | typedef struct beep_parms_t {
73 | float freq; /* tone frequency (Hz) */
74 | int length; /* tone length (ms) */
75 | int reps; /* # of repetitions */
76 | int delay; /* delay between reps (ms) */
77 | int end_delay; /* do we delay after last rep? */
78 | int stdin_beep; /* are we using stdin triggers? We have three options:
79 | - just beep and terminate (default)
80 | - beep after a line of input
81 | - beep after a character of input
82 | In the latter two cases, pass the text back out again,
83 | so that beep can be tucked appropriately into a text-
84 | processing pipe.
85 | */
86 | struct beep_parms_t *next; /* in case -n/--new is used. */
87 | } beep_parms_t;
88 |
89 | /* Momma taught me never to use globals, but we need something the signal
90 | handlers can get at.*/
91 | int console_fd = -1;
92 |
93 | /* If we get interrupted, it would be nice to not leave the speaker beeping in
94 | perpetuity. */
95 | void handle_signal(int signum) {
96 | switch(signum) {
97 | case SIGINT:
98 | if(console_fd >= 0) {
99 | /* Kill the sound, quit gracefully */
100 | ioctl(console_fd, KIOCSOUND, 0);
101 | close(console_fd);
102 | exit(signum);
103 | } else {
104 | /* Just quit gracefully */
105 | exit(signum);
106 | }
107 | }
108 | }
109 |
110 | /* print usage and exit */
111 | void usage_bail(const char *executable_name) {
112 | printf("Usage:\n%s [-f freq] [-l length] [-r reps] [-d delay] "
113 | "[-D delay] [-s] [-c]\n",
114 | executable_name);
115 | printf("%s [Options...] [-n] [--new] [Options...] ... \n", executable_name);
116 | printf("%s [-h] [--help]\n", executable_name);
117 | printf("%s [-v] [-V] [--version]\n", executable_name);
118 | exit(1);
119 | }
120 |
121 |
122 | /* Parse the command line. argv should be untampered, as passed to main.
123 | * Beep parameters returned in result, subsequent parameters in argv will over-
124 | * ride previous ones.
125 | *
126 | * Currently valid parameters:
127 | * "-f <frequency in Hz>"
128 | * "-l <tone length in ms>"
129 | * "-r <repetitions>"
130 | * "-d <delay in ms>"
131 | * "-D <delay in ms>" (similar to -d, but delay after last repetition as well)
132 | * "-s" (beep after each line of input from stdin, echo line to stdout)
133 | * "-c" (beep after each char of input from stdin, echo char to stdout)
134 | * "-h/--help"
135 | * "-v/-V/--version"
136 | * "-n/--new"
137 | *
138 | * March 29, 2002 - Daniel Eisenbud points out that c should be int, not char,
139 | * for correctness on platforms with unsigned chars.
140 | */
141 | void parse_command_line(int argc, char **argv, beep_parms_t *result) {
142 | int c;
143 |
144 | struct option opt_list[4] = {{"help", 0, NULL, 'h'},
145 | {"version", 0, NULL, 'V'},
146 | {"new", 0, NULL, 'n'},
147 | {0,0,0,0}};
148 | while((c = getopt_long(argc, argv, "f:l:r:d:D:schvVn", opt_list, NULL))
149 | != EOF) {
150 | int argval = -1; /* handle parsed numbers for various arguments */
151 | float argfreq = -1;
152 | switch(c) {
153 | case 'f': /* freq */
154 | if(!sscanf(optarg, "%f", &argfreq) || (argfreq >= 20000 /* ack! */) ||
155 | (argfreq <= 0))
156 | usage_bail(argv[0]);
157 | else
158 | result->freq = argfreq;
159 | break;
160 | case 'l' : /* length */
161 | if(!sscanf(optarg, "%d", &argval) || (argval < 0))
162 | usage_bail(argv[0]);
163 | else
164 | result->length = argval;
165 | break;
166 | case 'r' : /* repetitions */
167 | if(!sscanf(optarg, "%d", &argval) || (argval < 0))
168 | usage_bail(argv[0]);
169 | else
170 | result->reps = argval;
171 | break;
172 | case 'd' : /* delay between reps - WITHOUT delay after last beep*/
173 | if(!sscanf(optarg, "%d", &argval) || (argval < 0))
174 | usage_bail(argv[0]);
175 | else {
176 | result->delay = argval;
177 | result->end_delay = NO_END_DELAY;
178 | }
179 | break;
180 | case 'D' : /* delay between reps - WITH delay after last beep */
181 | if(!sscanf(optarg, "%d", &argval) || (argval < 0))
182 | usage_bail(argv[0]);
183 | else {
184 | result->delay = argval;
185 | result->end_delay = YES_END_DELAY;
186 | }
187 | break;
188 | case 's' :
189 | result->stdin_beep = LINE_STDIN_BEEP;
190 | break;
191 | case 'c' :
192 | result->stdin_beep = CHAR_STDIN_BEEP;
193 | break;
194 | case 'v' :
195 | case 'V' : /* also --version */
196 | printf("%s\n",VERSION_STRING);
197 | exit(0);
198 | break;
199 | case 'n' : /* also --new - create another beep */
200 | result->next = (beep_parms_t *)malloc(sizeof(beep_parms_t));
201 | result->next->freq = DEFAULT_FREQ;
202 | result->next->length = DEFAULT_LENGTH;
203 | result->next->reps = DEFAULT_REPS;
204 | result->next->delay = DEFAULT_DELAY;
205 | result->next->end_delay = DEFAULT_END_DELAY;
206 | result->next->stdin_beep = DEFAULT_STDIN_BEEP;
207 | result->next->next = NULL;
208 | result = result->next; /* yes, I meant to do that. */
209 | break;
210 | case 'h' : /* notice that this is also --help */
211 | default :
212 | usage_bail(argv[0]);
213 | }
214 | }
215 | }
216 |
217 | void play_beep(beep_parms_t parms) {
218 | int i; /* loop counter */
219 |
220 | /* try to snag the console */
221 | if((console_fd = open("/dev/console", O_WRONLY)) == -1) {
222 | fprintf(stderr, "Could not open /dev/console for writing.\n");
223 | printf("\a"); /* Output the only beep we can, in an effort to fall back on usefulness */
224 | perror("open");
225 | exit(1);
226 | }
227 |
228 | /* Beep */
229 | for (i = 0; i < parms.reps; i++) { /* start beep */
230 | if(ioctl(console_fd, KIOCSOUND, (int)(CLOCK_TICK_RATE/parms.freq)) < 0) {
231 | printf("\a"); /* Output the only beep we can, in an effort to fall back on usefulness */
232 | perror("ioctl");
233 | }
234 | /* Look ma, I'm not ansi C compatible! */
235 | usleep(1000*parms.length); /* wait... */
236 | ioctl(console_fd, KIOCSOUND, 0); /* stop beep */
237 | if(parms.end_delay || (i+1 < parms.reps))
238 | usleep(1000*parms.delay); /* wait... */
239 | } /* repeat. */
240 |
241 | close(console_fd);
242 | }
243 |
244 |
245 |
246 | int main(int argc, char **argv) {
247 | char sin[4096], *ptr;
248 |
249 | beep_parms_t *parms = (beep_parms_t *)malloc(sizeof(beep_parms_t));
250 | parms->freq = DEFAULT_FREQ;
251 | parms->length = DEFAULT_LENGTH;
252 | parms->reps = DEFAULT_REPS;
253 | parms->delay = DEFAULT_DELAY;
254 | parms->end_delay = DEFAULT_END_DELAY;
255 | parms->stdin_beep = DEFAULT_STDIN_BEEP;
256 | parms->next = NULL;
257 |
258 | signal(SIGINT, handle_signal);
259 | parse_command_line(argc, argv, parms);
260 |
261 | /* this outermost while loop handles the possibility that -n/--new has been
262 | used, i.e. that we have multiple beeps specified. Each iteration will
263 | play, then free() one parms instance. */
264 | while(parms) {
265 | beep_parms_t *next = parms->next;
266 |
267 | if(parms->stdin_beep) {
268 | /* in this case, beep is probably part of a pipe, in which case POSIX
269 | says stdin and out should be fuly buffered. This however means very
270 | laggy performance with beep just twiddling it's thumbs until a buffer
271 | fills. Thus, kill the buffering. In some situations, this too won't
272 | be enough, namely if we're in the middle of a long pipe, and the
273 | processes feeding us stdin are buffered, we'll have to wait for them,
274 | not much to be done about that. */
275 | setvbuf(stdin, NULL, _IONBF, 0);
276 | setvbuf(stdout, NULL, _IONBF, 0);
277 | while(fgets(sin, 4096, stdin)) {
278 | if(parms->stdin_beep==CHAR_STDIN_BEEP) {
279 | for(ptr=sin;*ptr;ptr++) {
280 | putchar(*ptr);
281 | fflush(stdout);
282 | play_beep(*parms);
283 | }
284 | } else {
285 | fputs(sin, stdout);
286 | play_beep(*parms);
287 | }
288 | }
289 | } else {
290 | play_beep(*parms);
291 | }
292 |
293 | /* Junk each parms struct after playing it */
294 | free(parms);
295 | parms = next;
296 | }
297 |
298 | return EXIT_SUCCESS;
299 | }
