Communication problem Arduino Mega 2560 - PC
OP (Firma: lala) #3519819
Hello,
we have a project where we use an Arduino Mega 2560 for datalogging. The
arduino sends
periodically (2s cycle) a string containing different sensor values. On
the PC (Windows 7 and Windows XP) we use logview
for visualization (www.logview.info/) which works well for our purposes.
The stringformat
for logview is described here:
http://www.logview.info/cms/d_formatbeschreibung.phtml
Our problem is that logview hangs up from time to time. The serial
logging stops and logview can't
open the COM-Port anymore. The only solution is to unplug and reconnect
the USB-cable. Unfortunately, this
isn't an acceptable solution for us.
What we have tried so far:
- We removed all sensors/actors from the Arduino Mega 2560 and sent only
dummy strings over USB -> logview still hangs up
- We reduced the baudrate --> it seems, that the device doesn't hangs up
so often (but still hangs up)
- We used shorter USB-cables --> it seems, that the device doesn't hangs
up so often (but still hangs up)
- We used on the PC a simple PC-program writing serial data to a file
(instead of logview) --> also hangs up
- We connected an additional arduino USART/USB converter to the second
USART from the Arduino and sent the same strings over both UARTS. On PC
we watched both ports with logview and putty -> both hanged up
- We tested this also with different PC's.
You have any idea? We think that it could be
- problem with ground
- problem with windows
Best regards
#3519853
Is the Arduino powered over USB? If, try an USB-Hub with own power
source.
Maybe some voltage drop causes an reset?
Another point could be the Auto-Reset from the Arduino-Board. Try to put
an 120 Ohm Resistor (min 110, max 124 Ohm) between Reset and 5V or cut
the wire "Reset EN" on the board. (see:
http://playground.arduino.cc/Main/DisablingAutoResetOnSerialConnection )
When you say the device hangs up, do you mean that the arduino stops
working  or is it just the communication that breaks?
Gast #3520075
The arduino itself does not hang up: In the test where we sent the
output string over two UARTS they boths hang up independently (not at
the same time). So we can be sure that the arduino continues to send the
strings after hangup.
The only thing is that the COM-port on the PC is lost and our
visualization tool stops operating. When we unplug and reconnect the
USB-cable the visualization works again (without reseting the arduino).
Best regards
#3520179
Usually (that means you didn't do anything to avoid this) the arduino is
reseted every time a serial connection (over the usb-plug) is
established.
Can you confirm, that the arduino is not resetting when the connection
gets lost?
Gast #3520351
Ok, when rethinking the whole test scenario I am not able to confirm
that the arduino is not resetting. It may also be possible that the
arduino restarts, but this isn't a problem since the arduino starts
logging again immediately. But we will try to find out ...
We will also try to cut
the wire "Reset EN" and to run a long time test again - but this isn't a
good solution since the arduino isn't programmable any more (via remote
access).
best regards
Gast #3520554
I also have sometimes Problems with COM-Driver for Arduino and Windows.
I think, it is a Windows-related problem.
With Linux I talk directly over libusb, without a Com or TTY driver. And
there are no problems over several monthes.
