STM32. PinBitAbfrage gefällt dem Compiler nicht
Gast #3525865
Hallo!
Habe gerade etwas total komisches :)
Ich will PA0 abfragen.
//User taster lesen
if(GPIO_ReadInputData(GPIOA, GPIO_Pin_0)){
Ebene2();
Und der Compiler sagt mir:
main.c:142:4: error: too many arguments to function 'GPIO_ReadInputData'
Benutze die standert GPIO lib von ST. Dort steht:
  * @brief  Reads the specified input port pin.
  * @param  GPIOx: where x can be (A..K) to select the GPIO peripheral for STM32F405xx/407xx and STM32F415xx/417xx devices
  *                      x can be (A..I) to select the GPIO peripheral for STM32F42xxx/43xxx devices.
  *                      x can be (A, B, C, D and H) to select the GPIO peripheral for STM32F401xx devices.
  * @param  GPIO_Pin: specifies the port bit to read.
  *         This parameter can be GPIO_Pin_x where x can be (0..15).
  * @retval The input port pin value.
uint8_t GPIO_ReadInputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
  uint8_t bitstatus = 0x00;
  /* Check the parameters */
  assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
  assert_param(IS_GET_GPIO_PIN(GPIO_Pin));
Also, was für`n Kack? :)
Komischerweise funktioniert if(GPIO_ReadOutputDataBit(GPIOG,
GPIO_Pin_14)){
(Also OUTPUT lesen)
Danke
Grüße Alex S.
