Guten Abend Forum,
Ich habe folgenden Code auf einem STM32F407-Discovery-Board:
1 | #include "main.h"
2 | #include "stm32f4xx_i2c.h"
3 |
4 | GPIO_InitTypeDef GPIO_InitStructure;
5 |
6 | void init(void)
7 | {
8 | //Quelle: Elia's Electronics Blog
9 | GPIO_InitTypeDef GPIO_InitStruct;
10 | I2C_InitTypeDef I2C_InitStruct;
11 |
12 | // enable APB1 peripheral clock for I2C1
13 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
14 | // enable clock for SCL and SDA pins
15 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
16 |
17 | /* setup SCL and SDA pins
18 | * You can connect the I2C1 functions to two different
19 | * pins:
20 | * 1. SCL on PB6 or PB8
21 | * 2. SDA on PB7 or PB9
22 | */
23 | GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8; // we are going to use PB6 and PB9
24 | GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF; // set pins to alternate function
25 | GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; // set GPIO speed
26 | GPIO_InitStruct.GPIO_OType = GPIO_OType_OD; // set output to open drain --> the line has to be only pulled low, not driven high
27 | GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP; // enable pull up resistors
28 | GPIO_Init(GPIOB, &GPIO_InitStruct); // init GPIOB
29 |
30 | // Connect I2C1 pins to AF
31 | GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_I2C1); // SCL
32 | GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_I2C1); // SDA
33 |
34 | // configure I2C1
35 | I2C_InitStruct.I2C_ClockSpeed = 10000; // 10kHz
36 | I2C_InitStruct.I2C_Mode = I2C_Mode_I2C; // I2C mode
37 | I2C_InitStruct.I2C_DutyCycle = I2C_DutyCycle_2; // 50% duty cycle --> standard
38 | I2C_InitStruct.I2C_OwnAddress1 = 0x00; // own address, not relevant in master mode
39 | I2C_InitStruct.I2C_Ack = I2C_Ack_Disable; // disable acknowledge when reading (can be changed later on)
40 | I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; // set address length to 7 bit addresses
41 | I2C_Init(I2C1, &I2C_InitStruct); // init I2C1
42 |
43 | // enable I2C1
44 | I2C_Cmd(I2C1, ENABLE);
45 | }
46 |
47 | int main(void)
48 | {
49 | uint8_t feld1[1000];
50 | uint16_t m;
51 | init();
52 | for(m=0; m<1000; m++)
53 | {
54 | feld1[m]=0x00;
55 | }
56 | while (1)
57 | {
58 | }
59 | }
Entwicklungsumgebung ist KEIL µVision.
Das Problem ist, dass in I2C_Init(I2C1, &I2C_InitStruct) der
HardFault_Handler aufgerufen wird.
Woran liegt das? Wenn ich feld1 nur mit einer Länge von 100 anlege
passiert dieser Fehler nicht. Läuft da der Speicher für Variablen über
und überschreibt die i2c-init-Funktion? Wie groß ist denn dieser
Speicherbereich?
Floid
