1 | /*---------------------------------------------------------------
2 | helper
3 | -----------------------------------------------------------------*/
4 |
5 | static uint8_t getSBoxValue(uint8_t num)
6 | {
7 | return SBox[num];
8 | }
9 |
10 | static uint8_t getRSBoxValue(uint8_t num)
11 | {
12 | return RSBox[num];
13 | }
14 |
15 | static uint32_t galoisMulti(uint8_t fact_1, uint8_t fact_2)
16 | {
17 | uint32_t product = 0;
18 | uint8_t i, hi_bit_set;
19 |
20 | //for(i = 0; i < 8; i++)
21 | for(i = 8; i > 0; i--)
22 | {
23 | if((fact_2 & 1) == 1)
24 | {
25 | product ^= fact_1;
26 | }
27 |
28 | hi_bit_set = fact_1 & 0x80;
29 | fact_1 <<= 1;
30 |
31 | if(hi_bit_set == 0x80)
32 | {
33 | fact_1 ^= 0x1B;
34 | }
35 |
36 | fact_2 >>= 1;
37 | }
38 |
39 | return product;
40 | }
41 |
42 | static void createRoundKey(uint8_t* expandedKey, uint8_t* roundKey)
43 | {
44 | uint8_t i, j;
45 |
46 | // Iterate over the columns
47 | for (i = 0; i < 4; i++)
48 | {
49 | // Iterate over the rows
50 | for (j = 0; j < 4; j++)
51 | {
52 | roundKey[(i + (j * 4))] = expandedKey[(i * 4) + j];
53 | }
54 | }
55 | }
56 |
57 | /*---------------------------------------------------------------
58 | Sub Bytes
59 | -----------------------------------------------------------------*/
60 |
61 | static void subBytes(uint8_t* block)
62 | {
63 | uint32_t i;
64 |
65 | for(i = 0; i < BLOCK_SIZE; i++)
66 | {
67 | block[i] = getSBoxValue(block[i]);
68 | }
69 | }
70 |
71 | static void iSubBytes(uint8_t* block)
72 | {
73 | uint32_t i;
74 |
75 | for(i = 0; i < BLOCK_SIZE; i++)
76 | {
77 | block[i] = getRSBoxValue(block[i]);
78 | }
79 | }
80 |
81 | /*---------------------------------------------------------------
82 | Shift Rows
83 | -----------------------------------------------------------------*/
84 |
85 | static void shiftRow(uint8_t* row, uint8_t rNumber)
86 | {
87 | uint8_t i, j, tmp;
88 |
89 | //for(i = 0; i < rNumber; i++)
90 | for(i = rNumber; i > 0; i--)
91 | {
92 | tmp = row[0];
93 |
94 | for(j = 0; j < 3; j++)
95 | {
96 | row[j] = row[j + 1];
97 | }
98 |
99 | row[3] = tmp;
100 | }
101 | }
102 |
103 | static void shiftRows(uint8_t* block)
104 | {
105 | uint8_t i;
106 |
107 | for(i = 1; i < 4; i++)
108 | {
109 | shiftRow(block + (i * 4), i);
110 | }
111 | }
112 |
113 | static void iShiftRow(uint8_t* row, uint8_t rNumber)
114 | {
115 | uint8_t i, j, tmp;
116 |
117 | //for(i = 0; i < rNumber; i++)
118 | for(i = rNumber; i > 0; i--)
119 | {
120 | tmp = row[3];
121 |
122 | for(j = 3; j > 0; j--)
123 | {
124 | row[j] = row[j - 1];
125 | }
126 |
127 | row[0] = tmp;
128 | }
129 | }
130 |
131 | static void iShiftRows(uint8_t* block)
132 | {
133 | uint8_t i;
134 |
135 | for(i = 1; i < 4; i++)
136 | {
137 | iShiftRow(block + (i * 4), i);
138 | }
139 | }
140 |
141 | /*---------------------------------------------------------------
142 | Mix Columns
143 | -----------------------------------------------------------------*/
144 |
145 | static void mixColumns(uint8_t* block)
146 | {
147 | uint32_t i, j;
148 | uint8_t columnNumber = 4;
149 | uint8_t tmp[16];
150 |
151 | for(i = 0; i < columnNumber; i++)
152 | {
153 | tmp[i] =
154 | galoisMulti( block[i], 0x02 ) ^ galoisMulti( block[columnNumber + i], 0x03 )
155 | ^ galoisMulti( block[2 * columnNumber + i], 0x01 ) ^ galoisMulti( block[3 * columnNumber + i], 0x01 );
156 | tmp[columnNumber + i] =
157 | galoisMulti( block[i], 0x01 ) ^ galoisMulti( block[columnNumber + i], 0x02 )
158 | ^ galoisMulti( block[2 * columnNumber + i], 0x03 ) ^ galoisMulti( block[3 * columnNumber + i], 0x01 );
159 | tmp[2 * columnNumber + i] =
160 | galoisMulti( block[i], 0x01 ) ^ galoisMulti( block[columnNumber + i], 0x01 )
161 | ^ galoisMulti( block[2 * columnNumber + i], 0x02 ) ^ galoisMulti( block[3 * columnNumber + i], 0x03 );
162 | tmp[3 * columnNumber + i] =
163 | galoisMulti( block[i], 0x03 ) ^ galoisMulti( block[columnNumber + i], 0x01 )
164 | ^ galoisMulti( block[2 * columnNumber + i], 0x01 ) ^ galoisMulti( block[3 * columnNumber + i], 0x02 );
165 | }
166 |
167 | //for (j = 0; j < BLOCK_SIZE; j++)
168 | for (j = BLOCK_SIZE; j > 0; j--)
169 | {
170 | block[j] = tmp[j] & 0xf0ff;
171 | }
172 | }
173 |
174 | static void iMixColumns(uint8_t* block)
175 | {
176 | uint32_t i, j;
177 | uint8_t columnNumber = 4;
178 | uint8_t tmp[16];
179 |
180 | for (i = 0; i < columnNumber; i++)
181 | {
182 | tmp[i] =
183 | galoisMulti(block[i], 0x0e) ^ galoisMulti(block[columnNumber + i], 0x0b)
184 | ^ galoisMulti(block[2 * columnNumber + i], 0x0d) ^ galoisMulti(block[3 * columnNumber + i], 0x09);
185 | tmp[columnNumber + i] =
186 | galoisMulti(block[i], 0x09) ^ galoisMulti(block[columnNumber + i], 0x0e )
187 | ^ galoisMulti(block[2 * columnNumber + i], 0x0b) ^ galoisMulti(block[3 * columnNumber + i], 0x0d);
188 | tmp[2 * columnNumber + i] =
189 | galoisMulti(block[i], 0x0d) ^ galoisMulti(block[columnNumber + i], 0x09)
190 | ^ galoisMulti(block[2 * columnNumber + i], 0x0e) ^ galoisMulti(block[3 * columnNumber + i], 0x0b);
191 | tmp[3 * columnNumber + i] =
192 | galoisMulti(block[i], 0x0b) ^ galoisMulti(block[columnNumber + i], 0x0d)
193 | ^ galoisMulti(block[2 * columnNumber + i], 0x09) ^ galoisMulti(block[3 * columnNumber + i], 0x0e);
194 | }
195 |
196 | //for (j = 0; j < BLOCK_SIZE; j++)
197 | for (j = BLOCK_SIZE; j > 0; j--)
198 | {
199 | block[j] = tmp[j] & 0xf0ff;
200 | }
201 | }
202 |
203 | /*---------------------------------------------------------------
204 | Add Round Key
205 | -----------------------------------------------------------------*/
206 |
207 | static void addRoundKey(uint8_t* text, uint8_t* roundKey )
208 | {
209 | uint8_t i;
210 |
211 | //for(i = 0; i < 16; i++)
212 | for(i = 16; i > 0; i--)
213 | {
214 | text[i] ^= roundKey[i];
215 | }
216 | }
217 |
218 | /*---------------------------------------------------------------
219 | Key expansion
220 | -----------------------------------------------------------------*/
221 |
222 | static void rotate(uint8_t* column)
223 | {
224 | uint8_t i, tmp;
225 |
226 | tmp = column[0];
227 |
228 | for(i = 0; i < 3; i++)
229 | {
230 | column[i] = column[i + 1];
231 | }
232 |
233 | column[3] = tmp;
234 | }
235 |
236 | static void keyScheduleCore(uint8_t* word, uint32_t rconIteration)
237 | {
238 | rotate( word );
239 | subBytes( word );
240 | word[0] ^= R_CON[rconIteration];
241 | }
242 |
243 | static void expandKey(uint8_t* expandedKey, uint32_t expandedKeySize, uint8_t* cipherKey, uint8_t keySize)
244 | {
245 | uint32_t i, currentSize = 0, rconIteration = 1;
246 | uint8_t tmp[4] = {0};
247 |
248 | //for(i = 0; i < keySize; i++)
249 | for(i = keySize; i > 0; i--)
250 | {
251 | expandedKey[i] = cipherKey[i];
252 | }
253 |
254 | currentSize += keySize;
255 |
256 |
257 | while(currentSize < expandedKeySize)
258 | {
259 | //asign the previous 4 byte to tmp
260 | for(i = 0; i < 4; i++)
261 | {
262 | tmp[i] = expandedKey[(currentSize - 4) + i];
263 | }
264 |
265 | // every 16, 24, 32 ... bytes call keyScheduleCore
266 | if((currentSize % keySize) == 0)
267 | {
268 | keyScheduleCore(tmp, rconIteration++);
269 | }
270 |
271 | if(keySize == Bits256 && ((currentSize % keySize) == 16))
272 | {
273 | //for(i = 0; i < 4; i++)
274 | for(i = 4; i > 0; i--)
275 | {
276 | tmp[i] = getSBoxValue(tmp[i]);
277 | }
278 | }
279 |
280 | for(i = 0; i < 4; i++)
281 | {
282 | expandedKey[currentSize] = expandedKey[currentSize - keySize] ^ tmp[i];
283 | currentSize++;
284 | }
285 | }
286 | }
287 |
288 | static void round(uint8_t* block, uint8_t* roundKey)
289 | {
290 | subBytes(block);
291 | shiftRows(block);
292 | mixColumns(block);
293 | addRoundKey(block, roundKey);
294 | }
295 |
296 | static void finalRound(uint8_t* block, uint8_t* roundKey)
297 | {
298 | subBytes(block);
299 | shiftRows(block);
300 | addRoundKey(block, roundKey);
301 | }
302 |
303 | /*---------------------------------------------------------------
304 | AES Encryption
305 | -----------------------------------------------------------------*/
306 |
307 | void aesEncrypt(uint8_t* block, uint8_t* cipherKey, uint8_t keySize)
308 | {
309 | uint8_t roundKey[16];
310 | uint8_t expandedKey[240] = { 0 };
311 | uint8_t i, expandedKeySize, rounds;
312 | expandedKeySize = GET_EXP_KEYSIZE(keySize);
313 |
314 | setLED(LED_YELLOW);
315 |
316 | expandKey(expandedKey, expandedKeySize, cipherKey, keySize);
317 |
318 | if(keySize == Bits128)
319 | rounds = 10;
320 | else if(keySize == Bits192)
321 | rounds = 12;
322 | else
323 | rounds = 14;
324 |
325 | createRoundKey(expandedKey, roundKey);
326 | addRoundKey(block, roundKey);
327 |
328 | for (i = 1; i < rounds; i++)
329 | {
330 | createRoundKey(expandedKey + 16 * i, roundKey);
331 | round(block, roundKey);
332 | }
333 |
334 | createRoundKey(expandedKey + 16 * rounds, roundKey);
335 | finalRound(block, roundKey);
336 |
337 | resetLED(LED_YELLOW);
338 | }
339 |
340 | /*---------------------------------------------------------------
341 | AES Decription
342 | -----------------------------------------------------------------*/
343 |
344 | void aesDecrypt(uint8_t* block, uint8_t* cipherKey, uint8_t keySize)
345 | {
346 | uint8_t roundKey[16];
347 | uint8_t expandedKey[240] = { 0 };
348 | uint8_t i, expandedKeySize, rounds;
349 | expandedKeySize = GET_EXP_KEYSIZE(keySize);
350 |
351 | setLED(LED_YELLOW);
352 |
353 | expandKey(expandedKey, expandedKeySize, cipherKey, keySize);
354 |
355 | if(keySize == 16)
356 | rounds = 10;
357 | else if(keySize == 24)
358 | rounds = 12;
359 | else
360 | rounds = 14;
361 |
362 | createRoundKey(expandedKey + 16 * rounds, roundKey);
363 | addRoundKey(block, roundKey);
364 | iShiftRows(block);
365 | iSubBytes(block);
366 |
367 | for (i = rounds - 1; i > 0; i--)
368 | {
369 | createRoundKey(expandedKey + 16 * i, roundKey);
370 | addRoundKey(block, roundKey);
371 | iMixColumns(block);
372 | iShiftRows(block);
373 | iSubBytes(block);
374 | }
375 |
376 | createRoundKey(expandedKey, roundKey);
377 | addRoundKey(block, roundKey);
378 |
379 | resetLED(LED_YELLOW);
380 | }
