1 | #include <stm32f4xx.h>
2 | #include <stm32f4xx_gpio.h>
3 | #include <stm32f4xx_adc.h>
4 | #include <stm32f4xx_conf.h>
5 |
6 |
7 | uint16_t ADC_Val; //Stores the calculated ADC value
8 | ADC_InitTypeDef ADC_InitStructure;
9 | ADC_CommonInitTypeDef ADC_CommonInitStructure;
10 | GPIO_InitTypeDef GPIO_InitStructure;
11 |
12 | void ADC_Configuration(void)
13 | {
14 | /******************************************************************************/
15 | /* ADCs interface clock, pin and DMA configuration */
16 | /******************************************************************************/
17 |
18 | /* Enable peripheral clocks */
19 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 | RCC_APB2Periph_ADC3 , ENABLE);
20 |
21 | RCC_AHB1PeriphClockCmd(RCC_AHB1ENR_GPIOCEN,ENABLE);//Clock for the ADC port!! Do not forget about this one ;)
22 |
23 | /* Configure ADC Channel 12 pin as analog input */
24 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2;
25 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
26 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
27 | GPIO_Init(GPIOC, &GPIO_InitStructure);
28 |
29 | /* ADC Common configuration *************************************************/
30 | ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
31 | ADC_CommonInit(&ADC_CommonInitStructure);
32 |
33 | /* ADC1 regular channel 10 to 15 configuration ************************************/
34 | ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
35 | ADC_InitStructure.ADC_ScanConvMode = DISABLE;
36 | ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
37 |
38 | // ADC_InitStructure.ADC_DiscModeChannelCountConfig(1);
39 | ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
40 | ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
41 | ADC_Init(ADC1, &ADC_InitStructure);
42 | ADC_Init(ADC2, &ADC_InitStructure);
43 | ADC_Init(ADC3, &ADC_InitStructure);
44 |
45 |
46 |
47 | ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_480Cycles);
48 | ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 1, ADC_SampleTime_480Cycles);
49 | ADC_RegularChannelConfig(ADC3, ADC_Channel_12, 1, ADC_SampleTime_480Cycles);
50 |
51 |
52 | // ADC_DiscModeChannelCountConfig(ADC3, 1);
53 | // ADC_DiscModeCmd(ADC3, ENABLE);
54 |
55 |
56 | /* Enable ADC1 to ADC3*/
57 | ADC_Cmd(ADC1, ENABLE);
58 | ADC_Cmd(ADC2, ENABLE);
59 | ADC_Cmd(ADC3, ENABLE);
60 |
61 | }//end ADC_Configuration
62 |
63 | uint16_t Get_ADC_Value(uint8_t Channel)
64 | {
65 | switch(Channel)
66 | {
67 | case 10:
68 | ADC_SoftwareStartConv(ADC1);
69 | while(ADC_GetSoftwareStartConvStatus(ADC1) != RESET){ADC_Val = 0;}
70 | ADC_Val = ADC_GetConversionValue(ADC1);
71 | break;
72 | case 11:
73 | ADC_SoftwareStartConv(ADC2);
74 | while(ADC_GetSoftwareStartConvStatus(ADC2) != RESET){ADC_Val = 0;}
75 | ADC_Val = ADC_GetConversionValue(ADC2);
76 | break;
77 | case 12:
78 | ADC_SoftwareStartConv(ADC3);
79 | while(ADC_GetSoftwareStartConvStatus(ADC3) != RESET){ADC_Val = 0;}
80 | ADC_Val = ADC_GetConversionValue(ADC3);
81 | ADC_Val = ADC_GetConversionValue(ADC3);
82 | break;
83 | default:
84 | ADC_Val = 0;
85 | break;
86 | }
87 | return ADC_Val;
88 | }
89 |
90 | int main(void){
91 | volatile uint16_t aaa=0;
92 | ADC_Configuration();
93 |
94 |
95 |
96 | while(1==1){
97 | aaa=Get_ADC_Value(12);
98 |
99 |
100 |
101 |
102 | }
103 | }
